Slate can now be found on HACS! Just make sure you enable the viewing of Themes in your HACS config. There aren’t really any additional updates to this theme for the time being, but you’ll be ready if anything changes.
Simply add these lines under your HACS configuration:
It’s great theme, I love it. But i have a problem with zone icons on map. They are based on primary-text-color. Is there a way to set them to another color? Because I use white color and white icons on white map, it’s hard to see them. Or if is there way to set whole map to “night” mode?
I really like your theme and have used it as a basis for a few tweaks I’ve made.
I wanted the on/off states to be a little brighter (like the base ui) and just today I realized the accent color is the color used for the notification indicator. So I changed that color to not use the same as the primary color in order to be able to see when it’s notifying.
The one thing I haven’t figured out how to change is the color of URL’s. Unclicked URL’s are dark blue and clicked URL’s are dark purple so as you can imagine they are exceptionally hard to see on a dark background.
Does anyone know a way to change the colors of those items?
