Grow room control with Home Assistant - share your knowledge
Hello everybody!
In the last days and weeks, I was contacted several times about the possibilties Home Assistant could offer for people who want to grow their own weed at home. The starting point for these questions was the recent legalization of weed for recreational use/growth in Germany (1st of April 2024 - no april fools, it’s real). Right now, the growth of weed is legal in the three biggest markets for Home Assistant: Germany, the Netherlands and the United States.
So I thought, why not bring people together and open up a topic about all the things one should or could know, about using Home Assistant to monitor and control your grow room, tent or cabinet. This is not meant to be a thread where you talk about your highs or how much you harvested, it’s about the technical challenges and possibilities! If people would like to share their experiences, pitfalls and tricks, others might be able to avoid all the obstacles, that could come up or even help!
Legal notice - important, please read!
As in the above countries growing weed for recreational and personal use is legal, this topic is strictly limited to this! Here is no room for illegal commercial grows or mass production questions. If you have those, please look elsewhere for support, this topic is aimed strictly at people who want to grow weed for themselves!
That’s why it’s common in this area, to regulate such topics:
  • If your light uses more than 400W (combined, if more than one light) or you use additional CO₂, it will be deemed commercial growth and therefor won’t be tolerated in this topic!
  • If your question(s) point in the direction, that you’re doing this for your livelihood, the posts will be removed!
  • If you insist on bringing up illegal topics, your posts will be removed!
  • If growing weed is illegal in your country, please abide to your local laws! And don’t tell us about it. If we know, you’re doing something illegal, we need to remove your post(s). Don’t ask, don’t tell! :wink:
Let me make this crystal clear: this is a topic for the technical side of a grow-room! This is not a topic where you talk about how high you drove the night before (which btw is disgusting - don’t smoke and drive!)!
Legal things aside, let’s take a look at the fun side of a grow-room and how Home Assistant could help here.
I was made aware of a very cool configuration for ESPHome and an 8-channel-relay board, to monitor and control light, ventilation (inside and outside), temperature, humidity and tada by measuring the weight of the plant pots, the humidity inside your grow medium (soil, hydroponics, whatever). Sounds cool, doesn’t it? It is, trust me, I’ve seen it in action! Only problem, I couldn’t get hold of the author of this configuration, so we’ll have to wait, until I can ask for his permission. Stay tuned, I’m working on it! :slight_smile:
But there are a lot more things to discuss, so please get in and share your knowledge about how you automated your grow room! :slight_smile: All input is welcome and much appreciated!
Some threads to start:
SanLight controlled via ESP
This is a great post on how you can DIY the dimmer control of your SanLight with ESPHome.
Mars Hydro LED lights
Feature request to get control for Mars Hydro lights into core HA.
Growlight with PWM (Mars Hydro as well)
Using an ESP to control your grow light
More specifically, portions of the United States. Only 19 states allow growing it legally. Ironically, there are also 19 states where it is also still legal to marry your first cousin as well… soooooo, yeah.
But, I’m actually kind of interested to see where this goes as I have pitched to my company (an online nursery/plant seller) that we need more automation in our business and of course HA comes to mind as we have many grow rooms, greenhouses, etc that we BARELY track and monitor. While it’s not weed in particular, I think a lot of the same concepts carry over.
Hello everyone,
I wanted to share my experience with automating my hydroponic tower, which might be helpful to those in the grow room community. Although I only grow fruits and vegetables in my 3D-printed hydroponic tower, the principles could be beneficial for broader applications.
The main idea is to have components that can communicate with Home Assistant, regardless of the protocol used.
I’ve automated the lights and the pump using IKEA smart plugs (though any smart plug would work, IKEA’s are affordable if you already have other IKEA devices at home). I monitor the water temperature, pH, EC, and other parameters using a Wifi Water Quality Monitor PH-W3988, that operates under Tuya. With some configurations and using Tuya local, I can retrieve the sensor data into Home Assistant. This monitor is relatively inexpensive (around €40), which is great for those like me who aren’t very knowledgeable about electronics, but there are probably more cost-effective solutions available.
Here’s what my dashboard looks like:
  • On the left: the sensors
  • In the center: the visualization of the light and watering schedules for my tower and mini greenhouse; I can also manually activate/deactivate the pump and lights by clicking on the corresponding parts of the drawing
  • On the right: the activation/deactivation and adjustment of the automations
This setup allows me to schedule the lights and watering times and durations and receive alerts if the pH, EC, or other indicators are out of range.
Hope this help
Cerize
That looks fantastic. Im trying to do that with my Grow Tent would it be possible to share the code (yaml)
An important metric for growing any type of plant is vapor pressure deficit. This is used to optimize the nutrient uptake for the plant. Optimum values vary depending on the plant and its growth cycle.
You can find charts as well as detailed explanations on the subject online. As for home assistant you’ll need a temperature and humidity sensor. Then with the help of a template sensor, create a VPD sensor for your grow. You’ll find examples and further discussion in this post.
I check my VPD using this.
Ive been working on changing my grow automation to something Home Assistant compatible. I’m making good progress but starting from scratch with hardware and code.
My setup is 7 gallon RDWC. The stands in the photos are for each bucket. Each stand has a Raspberry PI that has a USB ph probe, Each reader and soon to be added dissolved oxygen. There are 2 dosing pumps on the stand that dispense the pH up/down solution.
I also added control for motorized valves for draining and filling each bucket.
The code all works. Just testing edge cases and making some improvements as I think of them. It has a full websocket and API. The intent was to build the HA custom integration once I was fully operational. As the web interface gets more and more complete the HA integration will really be for the notifications if and if the meters or water sensors detect an issue.
I’m actively using the below GitHub to host the application. I also have an image for the raspberry pi.
Hope other people can enjoy and geek out on this too
I’m happy to share any of it if someone wanted to build one. Would help to have access to a 3D printer. Some of the components don’t have enclosures.
I’m limited to posting 1 photo :frowning:
Hi I have the same equipment. How did you get the PH-W3988 to show the sensors. my local tuya just show temp
what is it using fir hardware? Has anyone taken a look? If we can flash the PH-W3988 that would be NICE! be even better if we could create a cloudcutter profile or use Ltchiptool.
How accurate is the PH-W3988?
Did you set your DP Instructions? DP channels are DP 8 for Nutrient Temp, DP 102 for PH, DP 107 for TDS, DP110 for EC DP 116 for Proportion, DP113 for Salinity.
Might be some more Info here. Tuya: 8in1 ph, ec meter: Only one displayed in HA · Issue #94318 · home-assistant/core · GitHub
When I started out on my Home assistant journey, I thought I would need to learn some electronics, which I soon found out I was never going to get my head around. So my setup is unashamedly bought Here’s my kit run down;
AC Infinty T4 Fan
AC Infinity Controller 67
Migro Array2 x2
NFT424
Bluelab Guardian WiFi
Dehumidifier
Humidifier
Circulation pump
NFT pump
Shelly 0-10v gen3 dimmer
Meross WiFi plugs
Tapo Indoor Cam and plugs
Ecowitt GW1100 weather station
For the fan control, I leave that to the controller 67, but I have installed this integration;
This gives me access to the temperature and humidity sensor which can then turn on/off the heater, dehumidifier and humidifier.
My lights are controlled from the Shelly Dimmer and have sunset and sunrise up to a target %.
The BlueLab Guardian was integrated using this integration;
The NFT pump stays in, but the circulation pump comes on for 10mins every 30mins.
Hello Guys im right on building an Integration for Automated Grow Control with Home-Assistant we have some little bugs but in total it’s working.
Hope you have fun with and can enjoy more control over your plants .
Happy growing
Little late to the conversation, I just wanted to add my 2 cents. I JUST got into both home assistant and growing. I am starting to grow gourmet mushrooms but a lot of the concepts are the same. Below is my setup and it was fairly simple to add an automation to turn the humidifier on at 90% and off at 95%.
Hey there,
i just released an early version of the brokkoli suite, a plant fork to add more sensors, helpers and alot of other stuff to home assistant to better manage your crops.
For an ultrasonic sensor for nutrient reservoir level measurements, check out my GitHub;
So I have an integrated hydroponic system in Home Assistant. It is very advanced I have been adding to it for 3 years. It consists of custom developed ESP boards, it has a 12 Channel Nutrient Doser Mixer, 2 grow tents. PH, EC, and ORP sensors and dosers for the reservoirs to control PH, and ORP. Temperature control of the reservoirs, Environmental temperature control of the tent thru Ecoflow Wave heat pump. Media moisture, temperature, and EC sensing. Pictures to follow, I have integrated allot of sensors, and devices into this system. If you have any questions on anything I probably have tried it or done it.
The ultrasonic is decent level sensor a better one is a scale. They are the most accurate I find. The ultrasonic is a good sensor my only complaint is to get a really good sensor you have to spend some real money. The worst level sensor is by far the laser sensor. The problem with the ultrasonics, and DME sensors (Distance MeasurEment) is the volume of solution depends on the shape of the container it is in. The scale doesn’t have this issue; it only needs to be zero tared and then spanned to a desired level. The equation for level on a scale is linear interpolation. Where the DME sensor requires you to measure the container, and use a formula to convert the column height into a volume. This works but it is difficult for odd shaped items.
So you need a optocoupler to convert the ESP PWM to a 0-10v PWM signal.
