Growatt Inverter not work
Reading Growatt Inverter via Home Assistant does not work.
Not sure if this is any help but I only got my integration to work (first the app and device) by using the server-us
If however you managed to get the inverter data live/visible into the app then this should work too imo
Try to increase logging to find out what error pops-up.
Hi @PeetHome & @vingerha ,
Firstly, let me say ā€œhiā€, I’m Chris aka ā€˜muppet3000’ who maintains the Growatt Integration for Home Assistant.
Secondly, sorry for the massive cross-post on all the forum topics with ā€˜Growatt’ in the title, it was just easier to copy/paste this everywhere.
Thirdly, I didn’t realise how many forum posts there were for Growatt and the Integration!!! I must admit I find the forums very difficult to follow and navigate so I don’t spend much time here.
I mainly wanted to post to draw everyone’s attention to the following info:
1 - I’ve started maintaining the Integration primarily as a ā€˜custom integration’ which you can find here
2 - There’s a handy Info page for the custom integration here
3 - I will periodically roll up changes from the custom integration into the Core one in Home Assistant but this will not be very regularly
4 - There’s a prioritised list of bugs/feature requests that I’m working on here
5 - There’s a more thorough reasoning for my decision to move this into a custom integration here
6 - One thing that’s missing from the Feature Requests etc. is the addition to configure systems - I’m working on it, but it’s a background task until I have added support for all the different types of systems - Add ideas here if you have thoughts on what you’d like to be able to do.
7 - If you want to log issues or feature requests please do it here - Only there and in the Home Assistant Core repo will I actually see them, like I said I don’t actively monitor the forums, so the official repos are the best places!
8 - Please don’t assume that I’ve read this thread in a huge amount of detail, if feature requests etc. that have been requested in this thread are still relevant, please log them over on the new git repo here and I’ll get them prioritised - PLEASE read through the issues already logged first to check you’re not duplicating requests.
I hope all that makes sense, I’ve marked this thread as ā€˜watching’ so I’ll get notifications if people respond etc. but getting hold of me via the git repo issues section is the best way.
C
Hallo,muppet3000 ich habe einen 1 Stk. Growatt SPA 7000TL3 BH 7kW Batteriewechselrichter 3-phasig, AC-gekoppelt, Hochvolt-Batterie inklusive Smart Meter TPM-E 3-phasig.
Leider geht in Home Assistant dieser Wechselrichter nicht.
Meine Frage ist, ob Sie mir helfen kƶnnen.
Mit freundlichen Grüßen
Alles auf Englisch… this is an English-only forum
Hello, muppet3000 I have a 1 piece Growatt SPA 7000TL3 BH 7kW battery inverter 3-phase, AC-coupled, high-voltage battery including Smart Meter TPM-E 3-phase.
Unfortunately, this inverter does not work in Home Assistant.
My question is if you can help me.
Best regards
Hi @Timo-Kleinert112 currently the AC-Coupled type inverter is not supported by the Integration.
It was on the roadmap, however with all the troubles we’ve had with the growatt integration I’m planning on phasing it out and replacing it with Grott, which works with all inverters and I’m in the process of writing a new HA integration for.
As soon as that’s available, I’ll update here and help people to get it working.
Danke für die Antwort.
I have just installed Home Assistant so completely new. I tried to integrated Growatt however the server URL option is not present in the list Sign In can this URL please add. None of the others worked which I assume would be the case. the server api link doesn’t work when i try to get to the website. I’m assuming they’ve undertaken some changes.
Hi @FraternityOf.Tech as stated in my earlier message to @Timo-Kleinert112 , the Growatt API has become increasingly difficult to use and integrate against.
I have finally published the new Grott based integration and people have began to use it with good results.
Can I direct you towards this integration instead: GitHub - muppet3000/homeassistant-grott: Home Assistant Integration for Grott - MQTT as I’m going to be removing the Growatt Server API plugin from HA Core soon and even trying to deprecate my HACS integration (GitHub - muppet3000/homeassistant-growatt_server_api: Home Assistant Integration for Growatt - Upstream repo for the growatt_server integration that is part of the Core Home Assistant repository) too.
Greetings,
I’m trying to read the battery charge of a GROWATT-ARK-HV-12.8 battery.
The problem is, that the data read by grott only contains SOC=0 (State of Charge), although I know that the battery is close to fully charged.
I’m helping a relative on this, so there might be other Growatt devices other than the battery sending data as well.
I suspect the problem is that the specific layout used is not yet supported by grott, but I’m not sure.
I see different kinds of layouts in the grott log:
T060104XSPH (for this I copied the T060104SPH layout from the examples folder and renamed it)
	 - Growatt packet received:
		  <socket.socket fd=4, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('172.24.0.2', 35088), raddr=('47.91.67.66', 5279)>
	 - Growatt original Data:
		 \x00\x5f\x00\x06\x03\x3f\x01\x04\x1f\x35\x2b\x41\x22\x3e\x43\x77\x36\x5a\x77
		 \x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72
		 \x2c\x2f\x27\x42\x36\x75\x41\x5f\x47\x50\x74\x74\x47\x72\x6f\x77\x61\x74\x74
		 \x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x76\x7d\x7f\x4c\x74\x63\x74\x62
		 \x9c\x70\x23\x72\x69\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x54\x74\x47\x72\x6f
		 \x77\x61\x74\x74\x47\x72\x6f\x77\x08\x60\x7e\xe7\x72\x38\x77\x61\x74\x74\x47
		 \x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74
		 \x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77
		 \x61\x74\x74\x47\x72\x6f\x77\x60\x70\x74\x41\x6b\x0a\x77\x9b\x74\x74\x47\x72
		 \x6f\x77\x4c\xad\x74\x47\x72\x6f\x77\x61\x2e\x38\x47\x72\x6f\x68\x61\x74\x2f
		 \xe4\x72\x6f\x77\x50\x74\x74\x23\x14\x6f\x77\x61\x6b\x74\x47\xf4\xe9\x77\x61
		 \x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f
		 \x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\xc6
		 \x72\x6f\x77\x61\x74\x23\x4d\xd2\x6c\x85\x60\x23\x74\xbd\x73\x58\x65\xef\x74
		 \x74\x47\x79\x6f\xd6\x61\x10\x7f\x5f\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77
		 \x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x4c\x6a\x66\x4f\x6c\x37\x79\x7f\x77
		 \x26\x76\x71\x75\x70\x47\x9f\x6e\x75\x64\x60\x74\x17\x72\x6a\x77\x36\x74\x71
		 \x47\x72\x6f\xf7\x61\x74\x70\x22\x76\x8e\x77\x59\x74\x74\x38\x69\x6f\x77\x13
		 \xac\x77\xaf\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x71
		 \x77\x61\x2e\xd9\x47\x72\x6f\x68\x61\x74\x2d\xb7\x72\x6f\x77\x61\x74\x74\x47
		 \x72\x6f\x77\x61\x74\x74\x46\x72\x6c\xe4\x0d\x74\x75\x47\x71\xa8\xbd\x70\x8b
		 \x65\xb8\x63\x90\x66\x9e\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77
		 \x61\x74\x74\x47\x23\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72
		 \x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74
		 \x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61
		 \x74\x74\x47\x72\x6f\x77\x61\x75\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f
		 \x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47
		 \x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x75\xbf\x7f\x2d\x74\x72
		 \x74\x74\x46\x60\x6a\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x8d\x90
		 \xfa\x49\x74\x74\x46\xe2\x90\x88\xf7\x98\xe2\xab\xe4\x83\xe1\x8d\xe2\x98\xd1
		 \x9e\xf9\x9b\xf7\x98\xe2\xab\xe4\x83\xe1\x8d\x74\x74\x47\x72\x7c\xfd\x71\x72
		 \x74\x6e\x72\x6f\x04\xd4\x64\x6c\x47\x5b\x6f\x77\x61\x74\x64\x0f\x72\x46\x77
		 \x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x75\x77\x61\x27\x04\x44\x89
		 \x31\xd4\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74
		 \x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6e\xdb\x61\xbc\x75\xf7
		 \x72\x6f\x7d\xff\x6d\x10\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74
		 \x74\x47\x72\x6f\x77\x61\x74\x74\x59\x72\x6f\x2d\xcc\x74\x74\x47\x4a\x6f\x77
		 \x1e\x6f\x74\x47\x00\xb7\x77\x61\x74\x75\x47\x72\x6f\x77\x61\x74\x74\x47\x72
		 \x6f\xd2\x34
	 - Grott automatic protocol detection
	 - Grott data record length 839
	 - layout   :  T060104XSPH
	 - no matching record layout found, try generic
	 - Record layout used :  T06NNNNXSPH
	 - Growatt data decrypted V2
	 - Grott Growatt data decrypted
	 - Growatt plain data:
		 005f0006033f010458474436434a3730443500000000000000000000000000000000000000004
		 3584636423233303031000000000000000000000000000000000000000017090b0b060c0303e8
		 046400060000000000000000002000000000000000000000000069140aa000570000000000000
		 00000000000000000000000000000000000000000000000000000000000000000000000000000
		 000000000001040006196500fa0000000000002dd90000000000005a4c0000001f00005ba3000
		 00031000064660000001f00008686000000000000000000000000000000000000000000000000
		 000000000000000000000000000000810000000000570aa003f2015700fa0137128e0000000b0
		 0a100640b1800000000000000000000000000000000000000000b1809380d430d380549011001
		 0400ed010205140050000500570005000000800000046504e1003800007f1b000072d803e8000
		 0000000000000000000000000001e00005aad0000001f000059f0000000000000000000000000
		 00010003936c00010003c7ca11ff11ff11ff11ff0000000000000000000000000000000000510
		 00000000000000000000000000000000000000000100000000000000000000000000000000000
		 0000000000007d0084c0006000000000000000000000000000000000000000000011205000000
		 000000000000000000ffff8d2800000190ffff96ec96ec96ec96ec96ec96ec96ec96ec96ec96e
		 c96ec00000000138a10060029000073b510180029000000001048002900000000000000000000
		 0000001a0000537003fb5ea300000000000000000000000000000000000000000000000000000
		 00000001ac00c801b000000a9e19640000000000000000000000000000000000000000001e000
		 05aad0000003800007f1b000072d80000000100000000000000000000a555
	 - Growatt new layout processing
		 - decrypt       :  True
		 - offset        :  6
		 - record layout :  T06NNNNXSPH
	 - Grott data record date/time processing started
	 - date-time:  2023-09-11T11:06:12
	 - Grott values retrieved:
		 -  datalogserial        :  XGD6CJ70D5
		 -  pvserial             :  CXF6B23001
		 -  pvstatus             :  6
		 -  pvpowerin            :  0.0
		 -  pv1voltage           :  0.0
		 -  pv1current           :  0.0
		 -  pv1watt              :  209715.2
		 -  pv2voltage           :  0.0
		 -  pv2current           :  0.0
		 -  pv2watt              :  0.0
		 -  pvpowerout           :  0.0
		 -  pvfrequentie         :  0.0
		 -  pvgridvoltage        :  0.0
		 -  pvgridcurrent        :  0.0
		 -  pvgridpower          :  1703936.6
		 -  pvgridvoltage2       :  650.1
		 -  pvgridcurrent2       :  25.0
		 -  pvgridpower2         :  0.0
		 -  pvgridvoltage3       :  0.0
		 -  pvgridcurrent3       :  1173.7
		 -  pvgridpower3         :  0.0
		 -  totworktime          :  446.0
		 -  eactoday             :  203161.6
		 -  pvenergytoday        :  203161.6
		 -  eactotal             :  153740902.4
		 -  epvtotal             :  2038644.6
		 -  epv1today            :  168440627.2
		 -  epv1total            :  203161.6
		 -  epv2today            :  225692876.8
		 -  epv2total            :  0.0
		 -  pvtemperature        :  0.0
		 -  pvipmtemperature     :  1.1
		 -  pvboosttemp          :  16.1
		 -  bat_dsp              :  284.0
		 -  eacharge_today       :  8867048.0
		 -  eacharge_total       :  1703959.7
		 -  batterytype          :  5
		 -  uwsysworkmode        :  56
		 -  systemfaultword0     :  0
		 -  systemfaultword1     :  32539
		 -  systemfaultword2     :  0
		 -  systemfaultword3     :  29400
		 -  systemfaultword4     :  1000
		 -  systemfaultword5     :  0
		 -  systemfaultword6     :  0
		 -  systemfaultword7     :  0
		 -  pdischarge1          :  0.0
		 -  p1charge1            :  0.0
		 -  vbat                 :  3.0
		 -  SOC                  :  0
		 -  pactouserr           :  152128716.8
		 -  pactousertot         :  0.0
		 -  pactogridr           :  0.0
		 -  pactogridtot         :  6553.9
		 -  plocaloadr           :  335190886.3
		 -  plocaloadtot         :  0.0
		 -  spdspstatus          :  0.0
		 -  spbusvolt            :  0.0
		 -  etouser_tod          :  530841.6
		 -  etouser_tot          :  0.0
		 -  etogrid_tod          :  0.0
		 -  etogrid_tot          :  0.0
		 -  edischarge1_tod      :  0.0
		 -  edischarge1_tot      :  0.0
		 -  eharge1_tod          :  0.0
		 -  eharge1_tot          :  0.0
		 -  elocalload_tod       :  0.0
		 -  elocalload_tot       :  0.0
	 - MQTT jsonmsg:
			 {"device": "CXF6B23001", "time": "2023-09-11T11:06:12", "buffered": "no",
			 "values": {"datalogserial": "XGD6CJ70D5", "pvserial": "CXF6B23001",
			 "pvstatus": 6, "pvpowerin": 0, "pv1voltage": 0, "pv1current": 0, "pv1watt":
			 2097152, "pv2voltage": 0, "pv2current": 0, "pv2watt": 0, "pvpowerout": 0,
			 "pvfrequentie": 0, "pvgridvoltage": 0, "pvgridcurrent": 0, "pvgridpower":
			 17039366, "pvgridvoltage2": 6501, "pvgridcurrent2": 250, "pvgridpower2": 0,
			 "pvgridvoltage3": 0, "pvgridcurrent3": 11737, "pvgridpower3": 0,
			 "totworktime": 3211264, "eactoday": 2031616, "pvenergytoday": 2031616,
			 "eactotal": 1537409024, "epvtotal": 20386446, "epv1today": 1684406272,
			 "epv1total": 2031616, "epv2today": 2256928768, "epv2total": 0,
			 "pvtemperature": 0, "pvipmtemperature": 11, "pvboosttemp": 161, "bat_dsp":
			 2840, "eacharge_today": 88670480, "eacharge_total": 17039597, "batterytype":
			 5, "uwsysworkmode": 56, "systemfaultword0": 0, "systemfaultword1": 32539,
			 "systemfaultword2": 0, "systemfaultword3": 29400, "systemfaultword4": 1000,
			 "systemfaultword5": 0, "systemfaultword6": 0, "systemfaultword7": 0,
			 "pdischarge1": 0, "p1charge1": 0, "vbat": 30, "SOC": 0, "pactouserr":
			 1521287168, "pactousertot": 0, "pactogridr": 0, "pactogridtot": 65539,
			 "plocaloadr": 3351908863, "plocaloadtot": 0, "spdspstatus": 0, "spbusvolt":
			 0, "etouser_tod": 5308416, "etouser_tot": 0, "etogrid_tod": 0,
			 "etogrid_tot": 0, "edischarge1_tod": 0, "edischarge1_tot": 0, "eharge1_tod":
			 0, "eharge1_tot": 0, "elocalload_tod": 0, "elocalload_tot": 0}}
	 - Grott MQTT topic used : energy/growatt
	 - MQTT message message sent
T060119SPH
		 \x00\x01\x00\x06\x00\x38\x01\x19\x1f\x35\x2b\x41\x22\x3e\x43\x77\x36\x5a\x77
		 \x6f\x63\x61\x60\x2c\x1f\x2a\x37\x2f\x39\x2c\x2c\x1f\x2a\x37\x2f\x39\x2c\x2c
		 \x1f\x2a\x37\x2f\x39\x60\xcf
	 - Grott data record length 64
	 - layout   :  T060119SPH
	 - Record layout used :  T060119SPH
		 000100060038011958474436434a3730443500000000000000000000000000000000000000000
		 0140014585858585858585858585858585858585858585814bb
	 - Grott data ack record or data record not defined no processing done
T060116SPH
		 \x00\x06\x00\x06\x03\x3f\x01\x03\x1f\x35\x2b\x41\x22\x3e\x43\x77\x36\x5a\x77
		 \x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x76\x7d\x7f\x4c\x76\x43\x74\x61
		 \x74\x74\x3b\x72\x6e\x5e\x29\x74\x74\x47\x4e\x6f\x13\x46\x64\x74\x47\x69\x37
		 \x77\x61\x2d\x3c\x76\x5c\x5f\x77\x3b\x30\x35\x06\x72\x6a\x77\x63\x74\x74\x42
		 \x0a\x6f\x4b\x61\x48\x74\x23\x72\x0b\x77\x61\x37\x2c\x01\x44\x2d\x45\x52\x44
		 \x44\x76\x63\x68\x81\xec\x74\x75\x47\x28\x6f\x77\x61\x74\x54\x67\x3c\x0a\x02
		 \x04\x54\x31\x29\x17\x1d\x10\x08\x11\x54\x67\x72\x6e\x79\xec\x74\x74\x40\x95
		 \x6f\x7e\x61\x7f\x74\x4c\x72\x6a\x77\x77\x74\x75\x4a\x48\x7e\x92\x73\xb4\x67
		 \xfd\x7e\x8c\x63\x5a\x66\x28\x53\x22\x6f\x77\x61\x74\x74\x47\x72\x6f\x7a\x5b
		 \x65\x6a\x54\x24\x7c\xeb\x61\x60\x74\x53\x72\x7b\x77\x75\x74\x60\x47\x66\x6f
		 \x73\x61\x70\x74\x47\x72\x6f\x77\x61\x74\x74\x56\x6c\x6f\x77\x38\x3c\x35\x06
		 \x42\x5b\x47\x57\x44\x41\x47\x72\x6e\x46\x61\x70\x74\x47\x61\xf3\x77\x49\x65
		 \x6a\x57\xbc\x61\x76\x6f\x25\x74\x53\x72\x7b\x67\x36\x7b\xe4\x47\x5a\x6f\x77
		 \x61\x74\x74\x47\x72\x6f\x77\x61\x74\x77\x47\x72\x6e\xc3\x61\x8b\x3a\x67\x72
		 \x90\x39\x41\x74\x8b\x09\x52\x6f\x88\x2f\x54\x65\x40\x84\xe2\x66\x66\x65\x73
		 \x47\x72\x6f\x77\x61\x74\x77\xaf\x76\x0b\x77\xa9\x74\x74\x47\x72\x6f\x45\x60
		 \xa2\x76\x78\x72\x6f\x77\x61\x66\x71\x43\x3e\x6d\xcb\x65\x38\x76\x1f\x72\x6f
		 \x77\x61\x74\x74\x47\x73\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47
		 \x74\x47\x72\x6f\x77\x61\x74\x74\x47\x71\x6f\x77\x61\x7e\x74\x4d\x72\x0b\x77
		 \x05\x74\x75\x47\x72\x6f\x13\x61\x10\x74\x47\x72\x6e\x77\x61\x74\x74\x47\x72
		 \x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x75\x74
		 \x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x05
		 \x74\x7e\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f
		 \x72\x0b\x77\x05\x74\x75\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74
		 \x6f\x77\x60\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x76\x0a\x73\x80\x35\x25
		 \x0d\x41\x5f\x47\x51\x44\x46\x75\x43\x5b\x47\x51\x36\x23\x47\x72\x6f\x77\x61
		 \x61\x74\x74\x47\x72\x6f\x77\x61\x25\x36\x06\x13\x4f\x05\x3b\x31\x35\x26\x52
		 \x63\xf0\xfa
	 - layout   :  T060103XSPH
	 - Record layout used :  T060103XSPH
		 00060006033f010358474436434a3730443500000000000000000000000000000000000000004
		 3584636423233303031000000000000000000000000000000000000000017090b0b042c030000
		 007c000129480000003c0064271000001b5800005948312e30005a44414100050002000005780
		 03c003c006400640000435846364232333030311107f68d0001005a0000000020204e65756520
		 456e6572676965202000010e8d000007e70009000b000b0005001600010d3a11e512c013ba0ce
		 3143b125c145000000000000000000d3a111e1356139c00140014001400140014001400040004
		 0000000000000000111e0000594841413034303630350000013100040000139c0028111e10ce0
		 e010e510014001410570f900028000000000000000000000003000001b400ff4e2000ff4e2000
		 ff4e2000ff4e201107f68d1107110700000000000003e8046400c800000000003201d6023f000
		 000001205044c02bc044c02580000000000000001000000000000000000000000000000000000
		 0000000000000000000000000000000000000000000000030000000a000a00640064000100000
		 06400640000000100000000000000000000000000000000000000000000000100000000000000
		 00000000000000000000000064000a00000000000000000000000000000000000000000000000
		 00000000000000000000000000064006400010000000000000000000000000000000000000000
		 00000000000000000000000000000000000000000000000000000000000000000001000000000
		 00000000000046504e141514a3330303030323231343030425700000000000000000000000000
		 0000000000000000000000000000000005142416120725a454161200c879b
T060119SPH
		  <socket.socket fd=4, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('172.24.0.2', 52996), raddr=('47.91.67.66', 5279)>
		 \x00\x01\x00\x06\x00\x25\x01\x19\x1f\x35\x2b\x41\x22\x3e\x43\x77\x36\x5a\x77
		 \x6f\x73\x61\x75\x45\xf6\x66
	 - Grott data record length 45
So only packets with the layout T060104XSPH are actually processed.
As the records with the layout T060103XSPH seem to be of about the same size as the T060104XSPH records, I’d suspect that they might contain the battery data I am looking for.
The grott config looks like this:
# Specify grott monitor configuration
# Defaults are described
# Remove # and update the value to enable the setting
# Last updated: 2022-11-04
# Version 2.7.0
[Generic]
# Specify verbose for extended messaging
#verbose = True
# Specify minrecl for debugging purposes only (default = 100)
minrecl = 1
# Specify mode (sniff or proxy)(> 2.1.0 proxy is default)
#mode = proxy
# Specify port and IP address to listen to (only proxy), default port 5279, 0.0.0.0 ==> own ip address
#ip = 0.0.0.0
#port = 5279
# To blocks commands from outside (to channge inverter and shine devices settings) specify blockcmd = True,
# Specify noipf = True if you still want be able to set the destination ip addres from growatt server (advice
# only to use this for a short time)
#blockcmd = True
#noipf = True
# Time = auto/server parameter enable/disable date/time retrieval from data record (server), default is
# auto: grott decides which time is used (data record if valid otherwise Server)
# If time = server Grott server time is alwas used
#time = auto
# Sendbuf = True / False parameter to enable  / disable sending historical (buffered) data. Default is sendbuf = True.
#sendbuf = True
# Compat is True and valoffset needs to be set if offset / growatt protocol has been changed.
#compat = False
#valueoffset = 6
# Specify inverter id (not necessary in version >2.1.0 if compat = false!)
#inverterid = ABC1234567
# Specify the type of the inverter (default/sph/spf/max)
invtype = sph
# Decrypt is False if growatt communication is not encrypted (older inverters), (not necessary in version
# >2.1.0 if compat = false!)
#decrypt = True
[Growatt]
# Server name/IP address and port of Growatt server
# specify only if the IP address of server.growatt.com is changed
# The address as of Nov 2022 is 47.91.67.66
#ip = server.growatt.com
#ip = 47.91.67.66
#port = 5279
[MQTT]
# Mqtt parameters definitions
# Be aware nomqtt = True means no MQTT processing will be done!!!!!!
#nomqtt = False
ip = 192.168.2.22
port = 1883
topic= energy/growatt
auth = True
user = ***
password = ***
[PVOutput]
# PVOutput parameters definitions
#pvoutput = True
#apikey = yourapikey
# Data upload limit (in minutes)
#pvuplimit = 5
# Use this if you have one inverter
#systemid = 12345
# Use this if you have multiple inverters
#pvinverters = 2
#systemid1 = 12345
#inverterid1 = inverter1
#systemid2 = 67890
#inverterid2 = inverter2
#systemid99 = 99999
#inverterid99 = inverter99
[influx]
# Influxdb parameters definitions
#influx = False
#influx2 = False
#dbname = grottdb
#ip = localhost
#port = 8086
#user = grott
#password = growatt2020
#token  = "influx_token"
#org  = "grottorg"
#bucket = "grottdb"
[extension]
# grott extension parameters definitions
#extension = True
#extname = grottext
#extvar = {"var1": "var1_content", "var2": "var2_content"}
The last ~10000 lines of the log file: \x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72\x6f\x77\x61\x74\x74\x47\x72 - Pastebin.com
I’d greatly appreciate any help, thanks!
i have a Growatt TLX-2000. Works fine with a Waveshare RS485 to ETH and the SOLAX AddOn.
SADMSG
Hi!
I have a Growatt MID-25 with APX battery. The integration works really well, great job with it! So much better to have the graphs and numbers in HA than on growatt WebUI :slight_smile:
I have electric price by the hour. Is there a way to tell my inverter to charge the battery when the cost is low and also use battery when cost are high or even on the grid when price is really high?
