Hi @nick2525: do you confirm what app you used? Mine rm4pro work only with broadlink app (not with e-control).
Now I’m going to try, but first I would like to be sure that I’m doing correct tests.
Thank you
Thank you
I use IHS, https://play.google.com/store/apps/details?id=cn.com.broadlink.econtrol.plus&hl=en_US&gl=US
Thanks! Unfortunatelly my broadlink can’t connect to IHC.
I’m trying your steps with broadlink app…
I putted wifi id and password on broadlink after reset it.
Exit from app and connect rm4pro to home assistant: It works because had yello led when activate remote.learn command.
I received some code on file broadlink_remote_XXXXXXX_codes… It’s this
"Cancello1": {
"Open/Close": [
"JgD8ACcAAfITBgkAAeMrAAHhLwAB4i4AAeMsAAHkLAAB4y0AAeMtAAHjLQAB4i4AAeIuAAHhLwAB4i4AAeEuAAHiLgAB4i4AAeIuAAHiLgAB4i4AAeIuAAHiLgAB4i4AAeEuAAHjLQAB4i8AAeEuAAHhLwAB4S8AAeIuAAHhLgAB4y0AAeItAAHjLgAB4y0AAeEvAAHiLgAB5RUAAfksAAH1EgAKRw8ACC0SAAHqKQAB5BQABA4NAAIFGwAB9iAAAe8MCBMAA/coAAHqJAAB6SoAAeMrAAHmLAAB5CwAAecmAAHmKwAB4y4AAfAdAAHnLAAB4y0AAeslAAHsDAANBQAAAAAAAAAAAAA=",
"JgCaABQAAeUtAAHmKgAB4ywAAeQsAAHjMAAB3y4AAeIvAAHhLgAB4S8AAeIuAAHhLwAB4S4AAeIuAAHiLgAB4i4AAeIuAAHiLgAB4i4AAeIuAAHhLgAB4i4AAeQsboth AAHiLgAB4ywAAeQuAAHhLgAB5ioAAeQsAAHmKgAB5ikAAecpAAHlLAAB4hUABhwWDwoACiQnAAHmKwAB4iwADQUAAAAAAAAAAAAAAAA="
But I tried to copy both code after b64: whit or without “”: Nothing happened.
What happens when you try the code. Is there an error in the log. Does the rmpro blink. Does the rmpro work to control the device outside of home assistant?
Hi everybody.
Now I’m going to test.
I tried via script and also via services and manual service call.
When I call learn or send command, on Rm4pro, I have amber led for approx 1 second.
entity_id: remote.broirrf
device: open_dk
command: b64:“JgD8ACcAAfITBgkAAeMrAAHhLwAB4i4AAeMsAAHkLAAB4y0AAeMtAAHjLQAB4i4AAeIuAAHhLwAB4i4AAeEuAAHiLgAB4i4AAeIuAAHiLgAB4i4AAeIuAAHiLgAB4i4AAeEuAAHjLQAB4i8AAeEuAAHhLwAB4S8AAeIuAAHhLgAB4y0AAeItAAHjLgAB4y0AAeEvAAHiLgAB5RUAAfksAAH1EgAKRw8ACC0SAAHqKQAB5BQABA4NAAIFGwAB9iAAAe8MCBMAA/coAAHqJAAB6SoAAeMrAAHmLAAB5CwAAecmAAHmKwAB4y4AAfAdAAHnLAAB4y0AAeslAAHsDAANBQAAAAAAAAAAAAA=”,"JgCaABQAAeUtAAHmKgAB4ywAAeQsAAHjMAAB3y4AAeIvAAHhLgAB4S8AAeIuAAHhLwAB4S4AAeIuAAHiLgAB4i4AAeIuAAHiLgAB4i4AAeIuAAHhLgAB4i4AAeQsAAHiLgAB4ywAAeQuAAHhLgAB5ioAAeQsAAHmKgAB5ikAAecpAAHlLAAB4hUABhwWDwoACiQnAAHmKwAB4iwADQUAAAAAAAAAAAAAAAA=
num_repeats: 1
delay_secs: 1
hold_secs: 1
press: call services
I Had amber led ON for 1 second on rm4pro
I Setted config.yaml
logger:
default: info
logs:
homeassistant.components.modbus: warn
pymodbus.client: warn
I have no message on logs (only messages “Config entry for ipp not ready yet. Retrying in 5 seconds” becuase my printer is off)
Regarding last question: I tried to setup broadlink via app Broadlink and all work. Rf code to open external gate in 433mhz, and also IR command to control TV or Climate or HiFi. With HA is going to work only IR section. No RF.
Thanks a lot
If the rmpro can control the gate via the app correctly and the amber light blinks when you send RF code via home assistant, then my guess is the RF code is incorrect. Relearn the code a few times you will see each time the code is slightly different. Focus on tap the RF button on remote very briefly when learning.
Today it’s impossible to learn anything.
I had setted log to debug. I gave that message into log history
-Logger: homeassistant.components.broadlink.remote
-Source: components/broadlink/remote.py:299
-Integration: Broadlink (documentation, [issues]-(https://github.com/home-assistant/home-assistant/issues?-q=is%3Aissue+is%3Aopen+label%3A"integration%3A+broadlink"))
-First occurred: 23:03:23 (1 occurrences)
-Last logged: 23:03:23
-Failed to learn ‘Open’: No code received
Whit short press…
Whit long press, nothing changed…
I’m going to sleep… One clear night = one clear day after…
Thank you
How? I have been messing with it for days and no RF for my RM4 Pro in Home Assistant.
Hey Jonathan - How far have you got with it? Can you detail the process you’ve taken? Are you using the RM4 Pro or a different model? What app are you using on your phone to setup the RM pro?
Hi Oliver, thanks for the response!
So I have been down a few different paths. No matter what, whenever I try to get the RM4 Pro into RF mode it gets locked out of HA (Real bitch move of broadlink imho lol). I ended up flashing a Sonoff RF Bridge with Tasmota/Portisch and grabbing the RF codes of my remotes from there. So where I am now is I have the RF codes I would like my RM4 Pro to send from Home Assistant to control my roller shades but have not had any success yet.
Here is the switch I created in configuration.yaml
switch:
- platform: broadlink
host: 192.168.1.103
mac: '24:DF:A7:D3:20:66'
switches:
shade_up:
friendly_name: "Up"
command_on: "AAB037050809A606540140028012F2C092B2A3B2A3B2B2B2A3B2A3A3A3B2A3A3B2B2A3A3A3A3A3B2B2B2A3A3A3A3A3A3A3B2A3A3B2B2B2A3A3B255"
command_off: "AAB037050809A606540140028012F2C092B2A3B2A3B2B2B2A3B2A3A3A3B2A3A3B2B2A3A3A3A3A3B2B2B2A3A3A3A3A3A3A3B2A3A3B2B2B2A3A3B255"
shade_down:
friendly_name: "Down"
command_on: "AAB037050809B00640015402761270C092B2A3B2A3B2B2B2A3B2A3A3A3B2A3A3B2B2A3A3A3B2A3A3A3B2A3A3A3A3A3A3A3B2A3A3B2A3B2B2B2B255"
command_off: "AAB037050809B00640015402761270C092B2A3B2A3B2B2B2A3B2A3A3A3B2A3A3B2B2A3A3A3B2A3A3A3B2A3A3A3A3A3A3A3B2A3A3B2A3B2B2B2B255"
shade_stop:
friendly_name: "Stop"
command_on: "AAB037050809A606540140028012F2C092B2A3B2A3B2B2B2A3B2A3A3A3B2A3A3B2B2A3A3A3B2A3B2A3B2A3A3A3A3A3A3A3B2A3A3B2A3B2A3B2B255"
command_off: "AAB037050809A606540140028012F2C092B2A3B2A3B2B2B2A3B2A3A3A3B2A3A3B2B2A3A3A3B2A3B2A3B2A3A3A3A3A3A3A3B2A3A3B2A3B2A3B2B255"
Got ya. So i’m assuming your using the broadlink manager android app to do the initial setup of the RM4 pro?
(You can’t really be using the e-control/IHC apps unlikely as they dont work with the RM4 model) Is that correct?
I am using the broadlink manager ios app to add the RM4 Pro to wifi. I stop as soon as wifi is connected and the integration shows up in Home Assistant. I have the integration showing up in home assistant.
correct.
Also on my rm4pro other apps didn’t work.
I tried other times but never able to read rf code from my remote gate opening.
If your both using the broadlink app on Android… Have you both gone to ‘settings’ in the app and then turned off the following:
broadlink app -> home -> click on your rm4 pro --> “Skip firmware update!” -> top right button ‘…’ button -> bottom of the settings menu “Lock Device” -> Unlock.
This allowed the app and HA to work at the same time and kept the RM4 Pro online during learning commands. I don’t believe anywhere on the internet seems to detail this in their guides…
Let me know if this helped.
Hi.
Even I stopped the procedure on broadlink app (to put only WiFi setup into rm4pro) I haven’t device on broadlink app.
Maybe this is mine problem?
In many guide I found that requirement…
Thank you
My process was:
From that point any previous guide should work. If you can see the rm4 pro enabled in HA and the broadlink app can see the rm4 then you should be in a good place. The steps have to be followed to the dot. Or else it just wont work i found.
If you havn’t got the device in the broadlink app how do you know the rm4 it talking to anything? Once you are using the app, you’ll need to set the app to unlocked too as mentioned. Without using the app then i doubt you’ll broadlink will be doing anything!
Get it working?
Can the broadlink rm pro listen for RF commands or only send them? Thanks!
