I spent quite a while trying different ideas to get a working & fully local license plate setup and I am quite happy with this one so I am sharing a guide on how to do this.
Prerequisites
- You must have CodeProject.AI setup with the license plate plugin installed, that is outside the scope of this guide.
- Frigate+ is recommended for its built in license plate detection, however this can definitely work without Frigate+ with some modifications that are called out in the comments
Preliminary Info
The approach in this guide requires using a python script to run some of the logic because it would be much more difficult to do in a Home Assistant automation. This script is called directly from home assistant.
Python Script
- Create a folder to hold your scripts (if you don’t already have one) inside of the Home Assistant
/configdirectory. For this guide I will call mine/config/bashscript - Create a file called
license_plate.pyin/config/bashscript
The contents of the file should be
import datetime
import io
import json
import requests
import sys
from PIL import Image
# host for frigate instance
FRIGATE_HOST = "http://10.0.0.0:5000"
# host for CodeProject.AI instance
CODE_PROJECT_HOST = "http://10.0.0.0:4100"
event_id = sys.argv[1]
json = requests.get(f"{FRIGATE_HOST}/api/events/{event_id}").json()
camera = json["camera"]
# get clean snapshot if event has bended otherwise get snapshot without bounding boxes
if json["end_time"]:
img_bytes = requests.get(f"{FRIGATE_HOST}/clips/{camera}-{event_id}-clean.png").content
else:
img_bytes = requests.get(f"{FRIGATE_HOST}/api/events/{event_id}/snapshot.jpg?bbox=0").content
img = Image.open(io.BytesIO(img_bytes))
attributes = json["data"]["attributes"]
# Checks to ensure that license plate is detected
# this will need to be removed if not using a model that detects license plates (like frigate+)
if not attributes:
with open("/config/bashscript/detected_plates.log", "a") as log:
log.write(f"[{datetime.datetime.now()}]: {camera} - could not find license plate in {json}\n")
exit(0)
box = attributes[0]["box"]
detect = requests.get(f"{FRIGATE_HOST}/api/config").json()["cameras"][camera]["detect"]
known_res = (detect["width"], detect["height"])
# find coordinates of image to send to detector
x_mid = (box[0] + (box[2] / 2)) * known_res[0]
y_max = (box[1] + box[3]) * known_res[1]
cropped_image = img.crop((max(0, x_mid - 150), 0, min(known_res[0], x_mid + 150), known_res[1]))
cropped_image.save("/config/bashscript/crop.jpg")
# you will likely need to create multiple iterations for each vehicle
# 0/8/B for example are often mixed up
known_plates = {
# Bob's Car
"ABC128": "Bob's Car",
"ABC12B": "Bob's Car",
# Steve's Truck
"123TR0": "Steve's Truck",
"123TRO": "Steve's Truck",
with open('/config/bashscript/crop.jpg', 'rb') as fp:
response = requests.post(
f'{CODE_PROJECT_HOST}/v1/image/alpr',
files=dict(upload=fp),
print(response.json())
plates = response.json()
plate = None
if len(plates["predictions"]) > 0 and plates["predictions"][0].get("plate"):
plate = str(plates["predictions"][0]["plate"]).replace(" ", "")
score = plates["predictions"][0]["confidence"]
print(f"Checking plate: {plate} in {known_plates.keys()}")
log.write(f"[{datetime.datetime.now()}]: {camera} - detected {plate} as {known_plates.get(plate)} with a score of {score}\n")
if plate in known_plates.keys():
print(f"{camera} - Found a known plate: {known_plates[plate]}")
else:
plate = None
else:
log.write(f"[{datetime.datetime.now()}]: {camera} - No plates detected in run: {plates}\n")
if plate is None:
print(f"No valid results found: {plates['predictions']}")
sys.exit()
vehicle_name = known_plates[plate]
# Add Sub Label To Car Event
requests.post(f"{FRIGATE_HOST}/api/events/{event_id}/sub_label", json={"subLabel": vehicle_name, "subLabelScore": round(score, 2)})
There are a few things to note here:
- CodeProject.AI port might be different depending on where and how it is setup
- Some characters are commonly mixed up like 0/O and 8/B, these variations should be added so this works more reliably.
- This will create a file
detected_plates.logwhich will provide info on what plates are detected and if it matches a known plate - The latest image sent to ALPR will be saved as
Home Assistant Configuration
The next step is adding this python script to the Home Assistant configuration.yaml file. This is done via the shell_command type:
shell_command:
# run license plate inference for vehicle
check_license_plate: python3 /config/bashscript/license_plate.py "{{ event_id }}"
Home Assistant Automation
The final step is setting up the Home Assistant automation, this will run on a car event only when it has a license plate attribute detected. It will then run 3 iterations of checking for the license plate and stop when a license plate is detected.
This single automation will run on all cameras that detect a car with a license plate in the zones defined, so if you have a driveway zone specified for the garage and driveway camera it will run on both.
alias: >-
Outside - Driveway - Frigate Try To Read License Plate - License Plate
Seen
description: ""
- platform: mqtt
topic: frigate/events
payload: license_plate
# will just want to check that the label == "car" if not using a model that supports license_plate
value_template: "{{ value_json[\"after\"][\"current_attributes\"][0]['label'] }}"
variables:
after_zones: "{{ trigger.payload_json[\"after\"][\"entered_zones\"] }}"
before_zones: "{{ trigger.payload_json[\"before\"][\"entered_zones\"] }}"
current_zones: "{{ trigger.payload_json[\"after\"][\"current_zones\"] }}"
camera: "{{ trigger.payload_json[\"after\"][\"camera\"] }}"
id: "{{ trigger.payload_json[\"after\"][\"id\"] }}"
label: "{{ trigger.payload_json[\"after\"][\"label\"] }}"
condition:
- condition: and
conditions:
# setup zones that you want to look for cars with license plates for detection
- condition: template
value_template: >-
{{ ["street", "driveway"] | select("in", after_zones) | list | length
> 0 }}
alias: Has been in the street
value_template: "{{ [\"driveway\"] | select(\"in\", current_zones) | list | length > 0 }}"
alias: Was in the street and is now in the driveway
value_template: "{{ trigger.payload_json['after']['sub_label'] is none }}"
- choose:
- conditions:
- condition: trigger
sequence:
- service: shell_command.check_license_plate
data_template:
event_id: "{{id}}"
camera: "{{camera}}"
- repeat:
count: 2
sequence:
- wait_for_trigger:
- platform: mqtt
payload: "{{ trigger.payload_json['after']['id'] }}"
value_template: "{{ value_json['after']['id'] }}"
timeout:
hours: 0
minutes: 10
seconds: 0
milliseconds: 0
continue_on_timeout: false
value_template: >-
{{ wait.trigger.payload_json['after']['sub_label'] is none
data_template:
event_id: "{{id}}"
default: []
trace:
stored_traces: 20
mode: parallel
max: 10
