I managed to downgrade to 9.2 but the usb ports are not availble anymore.
My cc2531 Zigbee Stick and the RFlink device are not workong and also not visible under the System-> Hardware point.
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:172
First occurred: 28. Oktober 2022 um 23:40:10 (1 occurrences)
Last logged: 28. Oktober 2022 um 23:40:10
Error setting up entry TI CC2531 USB CDC, s/n: __0X00124B0018E1AA81 - Texas Instruments for zha
File “/usr/local/lib/python3.10/site-packages/serial/serialposix.py”, line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1AA81-if00’
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 365, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/zha/init.py”, line 112, in async_setup_entry
await zha_gateway.async_initialize()
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 185, in async_initialize
raise exc
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 172, in async_initialize
self.application_controller = await app_controller_cls.new(
File “/usr/local/lib/python3.10/site-packages/zigpy/application.py”, line 144, in new
await app.startup(auto_form=auto_form)
File “/usr/local/lib/python3.10/site-packages/zigpy/application.py”, line 124, in startup
await self.connect()
File “/usr/local/lib/python3.10/site-packages/zigpy_znp/zigbee/application.py”, line 106, in connect
await znp.connect()
File “/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py”, line 700, in connect
self._uart = await uart.connect(self._config[conf.CONF_DEVICE], self)
File “/usr/local/lib/python3.10/site-packages/zigpy_znp/uart.py”, line 170, in connect
_, protocol = await zigpy.serial.create_serial_connection(
File “/usr/local/lib/python3.10/site-packages/zigpy/serial.py”, line 37, in create_serial_connection
transport, protocol = await pyserial_asyncio.create_serial_connection(
File “/usr/local/lib/python3.10/site-packages/serial_asyncio/init.py”, line 448, in create_serial_connection
serial_instance = serial.serial_for_url(*args, **kwargs)
File “/usr/local/lib/python3.10/site-packages/serial/init.py”, line 90, in serial_for_url
instance.open()
File “/usr/local/lib/python3.10/site-packages/serial/serialposix.py”, line 325, in open
raise SerialException(msg.errno, “could not open port {}: {}”.format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1AA81-if00: [Errno 2] No such file or directory: ‘/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1AA81-if00’
