Hi @Hellis81, could you please share with us you laptop model and the numeric values you have for the different statuses you already mapped?
I also have an issue with statuses on my laptop and will try to find some time to work at this, so any additional info is welcome.
Well.
I have only managed to get On AC and Discharging, the other states in the value map is just placeholders for now.
I’m actually not sure Discharging is correct.
I tried it unplugged and battery was somewhere in the middle and I got Discharging, so that seems correct.
But now I have it at 100% and if I unplug it I still get Discharging. I expected it to display something else but it didn’t.
Perhaps this computer only has two states?
This is what the device says in HA:
20JH003EMX
by LENOVO
On the computer it says Yoga 370. There is nothing as far as I can see on the underside.
20JH003EMX is precise model Yoga 370 is line number not specifying configuration and destination country market
also see git hub i send you few tips there
I created new dev version supporting the perf counter integration could I ask you please to test it ?
it is stable for me at least but need to test it in different environments to be sure
Backup the old version pls. so you can go back if not stable
I can’t get it to boot up.
[20220927T093637]-MAIN ->LOADED Start
[20220927T093637]-MAIN ->Setting Loaded
[20220927T093637]-MAIN ->UI Set
[20220927T093637]-MAIN-configuration.yaml LOADED
[20220927T093637]-MAIN-Sync Timer Registered
[20220927T093637]-MAIN ->LOADED Done
[20220927T093753]-MAIN ->CLOSING TO TRAY
[20220927T105127]-MAIN-Registration Clicked
[20220927T105127]-MAIN-URL:https://SOMETHING
[20220927T105130]-System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
---> System.IO.IOException: Received an unexpected EOF or 0 bytes from the transport stream.
at System.Net.Security.SslStream.<FillHandshakeBufferAsync>g__InternalFillHandshakeBufferAsync|189_0[TIOAdapter](TIOAdapter adap, ValueTask`1 task, Int32 minSize)
at System.Net.Security.SslStream.ReceiveBlobAsync[TIOAdapter](TIOAdapter adapter)
at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm)
at System.Net.Http.ConnectHelper.EstablishSslConnectionAsync(SslClientAuthenticationOptions sslOptions, HttpRequestMessage request, Boolean async, Stream stream, CancellationToken cancellationToken)
--- End of inner exception stack trace ---
at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.AddHttp11ConnectionAsync(HttpRequestMessage request)
at System.Threading.Tasks.TaskCompletionSourceWithCancellation`1.WaitWithCancellation(CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.GetHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken)
at System.Net.Http.HttpMessageHandlerStage.Send(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.DiagnosticsHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken)
at System.Net.Http.SocketsHttpHandler.Send(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpClientHandler.Send(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpMessageInvoker.Send(HttpRequestMessage request, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.Send(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationToken cancellationToken)
at System.Net.Http.HttpClient.Send(HttpRequestMessage request)
at HA_Desktop_Companion.Libraries.HAApi_v2.validateHaUrl()
at HA_Desktop_Companion.MainWindow.registrationAsync_Click(Object sender, RoutedEventArgs e)
at System.Threading.Tasks.Task.<>c.<ThrowAsync>b__128_0(Object state)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
at MS.Internal.CulturePreservingExecutionContext.CallbackWra
[20220927T105144]-MAIN ->LOADED Start
[20220927T105144]-MAIN ->Setting Loaded
[20220927T105144]-MAIN ->UI Set
[20220927T105145]-MAIN-configuration.yaml LOADED
[20220927T105145]-MAIN-Sync Timer Registered
[20220927T105145]-MAIN ->LOADED Done
[20220927T105202]-MAIN-Registration Clicked
[20220927T105202]-MAIN-URL:SOMETHING
[20220927T105213]-System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
at System.Threading.Execu
[20220927T105230]-MAIN ->LOADED Start
[20220927T105230]-MAIN ->Setting Loaded
[20220927T105230]-MAIN ->UI Set
[20220927T105230]-MAIN-configuration.yaml LOADED
[20220927T105230]-MAIN-Sync Timer Registered
[20220927T105230]-MAIN ->LOADED Done
[20220927T105251]-MAIN-Registration Clicked
[20220927T105251]-MAIN-URL:SOMETHING
[20220927T105319]-System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
[20220927T110055]-MAIN ->LOADED Start
[20220927T110055]-MAIN ->Setting Loaded
[20220927T110055]-MAIN ->UI Set
[20220927T110055]-MAIN-configuration.yaml LOADED
[20220927T110055]-MAIN-Sync Timer Registered
[20220927T110055]-MAIN ->LOADED Done
[20220927T110110]-MAIN-Registration Clicked
[20220927T110110]-MAIN-URL:https://SOMETHING
[20220927T110138]-System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
--- End of stack trace from previous location ---
at System.Th
[20220927T110147]-MAIN ->LOADED Start
[20220927T110148]-MAIN ->Setting Loaded
[20220927T110148]-MAIN ->UI Set
[20220927T110148]-MAIN-configuration.yaml LOADED
[20220927T110148]-MAIN-Sync Timer Registered
[20220927T110148]-MAIN ->LOADED Done
[20220927T110159]-MAIN-Registration Clicked
[20220927T110159]-MAIN-URL:SOMETHING
[20220927T110205]-System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception.
The old version works.
That is wierd it is again a ssl tls error I think i am not getting the difference correctly when communicating with nabucassa, also request class was not touched in any ways just data provider i will try to troubleshoot when I will have some time
Still developing just struggling with stabylity of app on difrent platform any testing or contribution is welcome
Could you check latest build again ?, it seems almost like something bad is happening on netvork maybe some work WPN or proxy is in play here, could oyu test latest build ower for example mobile hotspot ?
I have tested one of the pre releases since then and it’s working fine.
Only issue I have is when I restart the computer I get a crash but that could be because I have four different versions on the computer and one of them does not work (old version).
But the version I have is very stable
Cn you please try to clean everithing and test latest version as you can cause for me are all verions stable if everithing will bestable for some time i will put out another stable release and will start refactoring stuffs. Thanks in adwance
If anyone still Watching this thread. for example @Hellis81 Finally had some time do i finally doen it
*it need testting please read release notes.
I can’t run this due to .NET.
But I downloaded the previous version from February and will give that a try.
You need to test nev one i will try to compile selfcontained version tomorow i forget abouth this. since most of time i am testing it on all my devices i dont vant to copy 200MB binaries around :(.
inally managed to add some simple status info
BTW push notifications now supports Sounds
Finally Almost version 1 Release Stable Release 0.0.4 · GamerClassN7/HA_Desktop_Companion · GitHub I manage to resolve almost all the bugs i am shure thad new will be found
@EdwardTFN, @Hellis81, @parautenbach
Finally i was able to make app really stable.
- Better logging
- Striping of sensitive info from log’s
- Auto Update Right From GitHub
- and more
You can download latest version (0.0.9) here from GitHub Release 0.0.9 · GamerClassN7/HA_Desktop_Companion · GitHub
where do I find the token ?
