HA_Desktop_Companion
you should see device with your computer name
I was just about to edit my post to say that the self contained version runs.
It registers, but I don’t see any discovered integration.
EDIT: yes I do. Wasn’t expecting it to be in Mobile App.
Ahh… so it’s a mobile app… OK. Yeah there it is!
Thank you so much!!
Lenovo has some mighty CPU coolers I see
Dammit.
Screenshot 2022-08-16 at 22-45-43 Settings – Home Assistant
I use native API so no integration is needed devise should appear under mobile app since all native API devices are classified as companio apps
Unfortunately each device can have different HW ID Address for their Probes i will try to log onto it in next couple of hours
Did you click register ? can you please post output of your log file ?
Yes it registered. Just took a bit of time to populate the entities. Not quite there yet:
Don’t worry.
It’s my work computer. I have no use for this entity
In case anyone else has the issue that you can’t place the shortcut in the autostart folder due to restrictions on the computer then you can do it in Regedit.
Either:
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
or
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run ← this one was also restricted for me.
You are on PC Right i will need to write fix for it
Regarding CPU Temperature can you run in cmd this
wmic /namespace:\\root\cimv2 PATH Win32_PerfFormattedData_Counters_ThermalZoneInformation and sent outcome in this thread soi can find walid address for your manufacturer ?
Hellis81Can i ask you for output of this command ass well ?
I will try to implement it in to autoregistration :slight_smile:
Caption  Description  Frequency_Object  Frequency_PerfTime  Frequency_Sys100NS  HighPrecisionTemperature  Name       PercentPassiveLimit  Temperature  ThrottleReasons  Timestamp_Object  Timestamp_PerfTime  Timestamp_Sys100NS
        3322                      \_TZ.THM0  100                  332          0
C:\Users\tomlu>wmic /namespace:\\root\cimv2 PATH Win32_PerfFormattedData_Counters_ThermalZoneInformation
No Instance(s) Available.
Which is weird because I’m looking a the temperature with Libre HW Monitor.
LIbre HW Monitor can have specific per provider apis that is what i sayed before cyn you prowide som info abouth your build ?
HI can you both try to download new versions ? when started click register button device will be reconfigured in HA.
Who is your motherboard manufacturer ?
From where? The link you posted before?
Yeah it is same version just different build :slight_smile:
Few New Sensors :slight_smile:
WIP
