Everything works however I can’t update now.
is the “default_config:” line present in your config.yaml? It has to be there for updater to work. Otherwise, make sure you have a line that simply says “updater:”
Yes it the first line of code on my configuration.yaml
ha su repair allowed me to update my software.
Perhaps the 0.117.5 image for rpi4 is not ready yet. You really should stop posting photos of text.
how do i revert?
What’s wrong with posting photos of text?
It has been discussed numerous tmes. Text is text, copy and paste it. People can then use the search function to find a similar problem.
I mean you haven’t even included the full page.
Is the system still working? It just looks like it failed to update to 0.117.5.
I can’t copy paste because that screen is a monitor for the RPi4.
The system isn’t working. HA crashed and won’t start.
so does that kernel error repeat on each boot?
i reverted:
20-11-07 01:14:11 INFO (MainThread) [supervisor.core] Starting repair of Supervisor Environment
20-11-07 01:14:11 INFO (SyncWorker_3) [supervisor.docker] Prune stale containers
20-11-07 01:14:11 INFO (SyncWorker_3) [supervisor.docker] Prune stale images
20-11-07 01:14:14 INFO (SyncWorker_3) [supervisor.docker] Prune stale builds
20-11-07 01:14:14 INFO (SyncWorker_3) [supervisor.docker] Prune stale volumes
20-11-07 01:14:14 INFO (SyncWorker_3) [supervisor.docker] Prune stale networks
20-11-07 01:14:14 INFO (SyncWorker_3) [supervisor.docker] Fix stale container on hassio network
20-11-07 01:14:14 INFO (SyncWorker_3) [supervisor.docker] Fix stale container on host network
20-11-07 01:14:14 INFO (MainThread) [supervisor.addons] Found 3 add-ons to repair
20-11-07 01:14:14 INFO (MainThread) [supervisor.addons] Repairing for add-on: a0d7b954_ssh
20-11-07 01:14:14 INFO (SyncWorker_7) [supervisor.docker.interface] Downloading docker image hassioaddons/ssh-aarch64 with tag 7.7.0.
20-11-07 01:14:54 INFO (MainThread) [supervisor.addons] Repairing for add-on: core_check_config
20-11-07 01:14:54 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-addon-check_config with tag 3.6.0.
20-11-07 01:15:25 INFO (MainThread) [supervisor.addons] Repairing for add-on: cebe7a76_hassio_google_drive_backup
20-11-07 01:15:25 INFO (SyncWorker_7) [supervisor.docker.interface] Downloading docker image sabeechen/hassio-google-drive-backup-aarch64 with tag 0.102.0.
20-11-07 01:15:26 INFO (MainThread) [supervisor.homeassistant.core] Repair Home Assistant 0.117.5
20-11-07 01:15:26 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 0.117.5.
20-11-07 01:15:30 ERROR (SyncWorker_4) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:0.117.5 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:0.117.5: No such image: homeassistant/raspberrypi4-64-homeassistant:0.117.5").
20-11-07 01:15:30 INFO (SyncWorker_4) [supervisor.docker.interface] This error is often caused by not having enough disk space available. Available space in /data is: 203.5 GiB
20-11-07 01:15:30 ERROR (MainThread) [supervisor.homeassistant.core] Repairing of Home Assistant failed
20-11-07 01:15:30 INFO (MainThread) [supervisor.supervisor] Repairing Supervisor 2020.11.0
20-11-07 01:15:30 INFO (MainThread) [supervisor.core] Finished repair of Supervisor Environment
20-11-07 01:17:32 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-11-07 01:17:32 ERROR (SyncWorker_1) [supervisor.docker] Image homeassistant/raspberrypi4-64-homeassistant not exists for homeassistant
20-11-07 01:17:57 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 0.117.5
20-11-07 01:17:57 INFO (SyncWorker_5) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:0.117.5 to homeassistant/raspberrypi4-64-homeassistant:0.117.5
20-11-07 01:17:57 INFO (SyncWorker_5) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 0.117.5.
20-11-07 01:18:01 ERROR (SyncWorker_5) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:0.117.5 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:0.117.5: No such image: homeassistant/raspberrypi4-64-homeassistant:0.117.5").
20-11-07 01:18:01 INFO (SyncWorker_5) [supervisor.docker.interface] This error is often caused by not having enough disk space available. Available space in /data is: 203.5 GiB
20-11-07 01:18:01 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
20-11-07 01:41:12 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-11-07 01:41:12 ERROR (SyncWorker_7) [supervisor.docker] Image homeassistant/raspberrypi4-64-homeassistant not exists for homeassistant
20-11-07 02:05:11 INFO (MainThread) [supervisor.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
20-11-07 02:22:45 INFO (MainThread) [supervisor.core] Starting repair of Supervisor Environment
20-11-07 02:22:45 INFO (SyncWorker_6) [supervisor.docker] Prune stale containers
20-11-07 02:22:45 INFO (SyncWorker_6) [supervisor.docker] Prune stale images
20-11-07 02:22:48 INFO (SyncWorker_6) [supervisor.docker] Prune stale builds
20-11-07 02:22:48 INFO (SyncWorker_6) [supervisor.docker] Prune stale volumes
20-11-07 02:22:48 INFO (SyncWorker_6) [supervisor.docker] Prune stale networks
20-11-07 02:22:48 INFO (SyncWorker_6) [supervisor.docker] Fix stale container on hassio network
20-11-07 02:22:48 INFO (SyncWorker_6) [supervisor.docker] Fix stale container on host network
20-11-07 02:22:48 INFO (MainThread) [supervisor.addons] Found 3 add-ons to repair
20-11-07 02:22:48 INFO (MainThread) [supervisor.addons] Repairing for add-on: a0d7b954_ssh
20-11-07 02:22:48 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image hassioaddons/ssh-aarch64 with tag 7.7.0.
20-11-07 02:23:30 INFO (MainThread) [supervisor.addons] Repairing for add-on: core_check_config
20-11-07 02:23:30 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-addon-check_config with tag 3.6.0.
20-11-07 02:24:02 INFO (MainThread) [supervisor.addons] Repairing for add-on: cebe7a76_hassio_google_drive_backup
20-11-07 02:24:02 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image sabeechen/hassio-google-drive-backup-aarch64 with tag 0.102.0.
20-11-07 02:24:03 INFO (MainThread) [supervisor.homeassistant.core] Repair Home Assistant 0.117.5
20-11-07 02:24:03 INFO (SyncWorker_7) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 0.117.5.
20-11-07 02:24:06 ERROR (SyncWorker_7) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:0.117.5 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi4-64-homeassistant:0.117.5: No such image: homeassistant/raspberrypi4-64-homeassistant:0.117.5").
20-11-07 02:24:06 INFO (SyncWorker_7) [supervisor.docker.interface] This error is often caused by not having enough disk space available. Available space in /data is: 203.5 GiB
20-11-07 02:24:06 ERROR (MainThread) [supervisor.homeassistant.core] Repairing of Home Assistant failed
20-11-07 02:24:06 INFO (MainThread) [supervisor.supervisor] Repairing Supervisor 2020.11.0
20-11-07 02:24:07 INFO (MainThread) [supervisor.core] Finished repair of Supervisor Environment
20-11-07 03:05:12 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
20-11-07 03:05:12 INFO (MainThread) [supervisor.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
20-11-07 03:11:52 INFO (MainThread) [supervisor.host.info] Updating local host information
20-11-07 03:11:52 INFO (MainThread) [supervisor.host.services] Updating service information
20-11-07 03:11:52 INFO (MainThread) [supervisor.host.network] Updating local network information
20-11-07 03:11:53 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-11-07 03:32:13 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 0.117.4
So, all working?
All of my zigbee devices are unavailable and how do I know when I can upgrade?
Now all of my zwave devices also unavailable
That would be a new thread.
