Today I wanted to integrate Ikea Tradfri into HA. It discovered it by itself, but when inserting the security code I got from the back of the gateway (also checked with QR), it gives me the message: “Timeout Validating the Code”.
I’m having the same issue. IKEA Tradfri integration was working perfectly, but since two days ago the devices could not be found. I removed the integration and added it again, resulting in the security key time-out error.
I tried to restore a back-up of 2 weeks ago, and then the devices worked for a few minutes, after which they stopped working again. Restored to the most recent back-up again and still having the same issues.
I found the problem.
In the /config/.storage/core.config_entries was still a part pointing to the (deleted) Tradfri integration.
I did delete this, restarted home assistant and everything as ok.
Same here, since the 1.14.1 Gateway release (on 0.116.4). Nobbled HomeKit and the Tradfri integration. Initially just reloading the integration worked. Then it stopped, and didn’t give the option. Eventually finds it automatically, but just times out.
Edit: Tried adding the integration again manually (with IP, despite the auto-discovery)… and it came back. Not confident it’ll stay… but working for now.
I have made a new installation (new docker container) with the latest version of HA. So no old stuff not completely removed. Trying to enter the security key results in a time-out. When I stop the new container and start the old one (version 0.107.7) I can use the Tradfri stuff again
