Hello all. I started working with HA after the Insteon shutdown. Thanks to getting help here on the forums and HA upgrades for Insteon, I had it working well. This morning I allowed the latest update to install and now I am unable to access the HA log in screen in a browser. I restarted HA and watched the progress. There is an error saying “failed to start wait until kernel time synchronized” and instructions to “See ‘systemctl status systemd-time-wait-sync.service’ for details.” I tried typing that into the command line but it’s not recognized. Sadly, due to my inexperience I failed to take any snapshots of my VM. I’m running virtual box on a Windows 10 laptop. I was able to connect to HA before the installation of the update.
I read some of the previous posts on this error. Some people report hardware issues like wifi connection and a bad SD card having something to do with the failed to start error but I don’t have an SD card in this machine and everything else seems to be working fine.
Any suggestions would be appreciated.
Update 1. I followed the cli command instructions below from callumw in this post:
login
nmcli
nmcli connection show
nmcli con edit “Home Assistant OS default” # or whatever your HA instance is called
activate
After that I was able to access the HA UI in the browser. Then I tried to follow the instructions for checking Settings | System | Network, but found that most of the options under System are unavailable. The exceptions are Backups, Analytics, and Storage. The others return an error stating “Error while loading page system_health” or other page name. I also get that same error when clicking my user name at the bottom of the HA vertical nav pane.
Searching in Settings for Restart I was able to click to restart the server but nothing changed.
Trying to figure out what to do next.
Update 2: I was able restore a backup, reverting to HA Core 2022.5.4. That allowed me to get into the network and other settings that were not working. As described in the other post I referenced, the IPv4 setting was disabled. I changed it to DHCP but I’m not sure if it took because there was an error message saying to check the supervisor log. I don’t know how to get to that as it doesn’t seem to be under the Logbook menu option. I ran an HA backup and took a snapshot of the VM in Virtual Box. Remote access is working again. HA is prompting to update to Core version 6.5.
Update 3: I powered down the VM and restarted it. It started successfully with no “failed to start wait until kernel time” error. I allowed HA to update to 6.5. Everything seems to be working correctly. The network interface setting is on DHCP. I powered off the VM and restarted it. There were no startup errors. IPv4 is still set to DHCP. Remote access is working. Everything seems to be working correctly again.
