HA + KNX + Omada Network - Connection Issues at KNX Integration
I have issues to get a stable connection between HA and my MDT IP Router.
Issue:
  • Connection can be configured and works
  • But after a changing time, the IP Router will not be available anymore (even the HTTP page does not respond)
History:
  1. Everything in the same VLAN, IGMP Snooping off, MDT Router with software version which was preinstalled
  2. SW update on MDT IP Router
  3. Splitted up to two VLANs to separate KNX IP with ACL rules configured
  4. IGMP Snooping enabled
In all configurations I have the same issue.
KNX Log can be found in the next message because of maximum text length.
Can anybody support me at this topic?
FYI: I got a MagentaTV box in the past which used IPTV over multicast (IGMP).
This box was not able to play more than several seconds of TV. It seems that multicast can be an issue on Omada networks, but not sure if this is the reason here too.
The connection is sometime up for multiple days or weeks, sometimes only for minutes or hours.
I can not see any pattern here.
KNX Integration config:
  • Tunneling
    • Type: TCP
    • Host IP: 10.10.2.2
    • Port: 3671
  • Default GA: 1.3.1
  • Multicast group: 224.0.23.12
  • Multicast port: 3671
  • Local IP: 0.0.0.0
  • Status updater: enabled
  • Max telegrams per second: 20
KNX Secure is not enabled at the IP Router and integration.
Diagnostic information:
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2022.7.6",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.10.5",
    "docker": true,
    "arch": "x86_64",
    "timezone": "Europe/Berlin",
    "os_name": "Linux",
    "os_version": "5.15.45",
    "supervisor": "2022.07.0",
    "host_os": "Home Assistant OS 8.2",
    "docker_version": "20.10.14",
    "chassis": "vm",
    "run_as_root": true
  "custom_components": {
    "hacs": {
      "version": "1.26.2",
      "requirements": [
        "aiogithubapi>=22.2.4"
    "nodered": {
      "version": "1.0.9",
      "requirements": []
    "waste_collection_schedule": {
      "version": "1.23.0",
      "requirements": [
        "icalendar",
        "recurring_ical_events",
        "icalevents",
        "bs4"
    "linkplay": {
      "version": "3.1.8",
      "requirements": [
        "async-upnp-client>=0.27",
        "validators~=0.12",
        "chardet>=4.0.0"
    "localtuya": {
      "version": "4.0.1",
      "requirements": []
    "ical": {
      "version": "1.3",
      "requirements": [
        "icalendar==4.0.7"
    "browser_mod": {
      "version": "1.5.3",
      "requirements": []
    "reversotts": {
      "version": "1.0.2",
      "requirements": [
        "pyttsreverso==0.4"
  "integration_manifest": {
    "domain": "knx",
    "name": "KNX",
    "config_flow": true,
    "documentation": "https://www.home-assistant.io/integrations/knx",
    "requirements": [
      "xknx==0.21.5"
    "codeowners": [
      "@Julius2342",
      "@farmio",
      "@marvin-w"
    "quality_scale": "platinum",
    "iot_class": "local_push",
    "loggers": [
      "xknx"
    "is_built_in": true
  "data": {
    "xknx": {
      "version": "0.21.5",
      "current_address": "1.3.1"
    "config_entry_data": {
      "individual_address": "1.3.1",
      "multicast_group": "224.0.23.12",
      "multicast_port": 3671,
      "state_updater": true,
      "rate_limit": 20,
      "connection_type": "tunneling_tcp",
      "local_ip": null,
      "host": "10.10.2.2",
      "port": 3671,
      "route_back": false
    "configuration_yaml": {
      "binary_sensor": [
          "name": "WC Pr\u00e4senz",
          "state_address": "0/3/25",
          "device_class": "presence"
          "name": "Bad Pr\u00e4senz",
          "state_address": "0/3/26",
      "sensor": [
          "name": "WC Helligkeit",
          "state_address": "4/3/100",
          "state_class": "measurement",
          "type": "illuminance"
          "name": "WC Temperatur",
          "state_address": "4/3/101",
          "type": "temperature"
          "name": "WC Lautst\u00e4rke setzen",
          "state_address": "5/3/103",
          "type": "percent"
          "name": "Bad Helligkeit",
          "state_address": "4/3/120",
          "name": "Bad Temperatur",
          "state_address": "4/3/121",
          "name": "Bad Temperatur Fu\u00dfboden",
          "state_address": "4/3/122",
          "name": "Bad Temperatur Badewanne",
          "state_address": "4/3/123",
          "name": "Bad Temperatur Dusche Kopfbrause",
          "state_address": "4/3/124",
          "name": "Bad Temperatur Dusche Handbrause",
          "state_address": "4/3/125",
      "light": [
          "name": "WC Licht schalten",
          "address": "2/3/100",
          "state_address": "2/3/101"
          "name": "Bad Stripes",
          "address": "2/3/130",
          "state_address": "2/3/131",
          "hue_address": "2/3/132",
          "hue_state_address": "2/3/133",
          "saturation_address": "2/3/134",
          "saturation_state_address": "2/3/135",
          "brightness_address": "2/3/136",
          "brightness_state_address": "2/3/137"
    "configuration_error": null
Thanks a lot.
Kind regards,
Daxi
KNX Log Part 1:
2022-07-26 09:48:18 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 0610020800081000
2022-07-26 09:48:18 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658821698.2167552:
2022-07-26 09:49:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 09:49:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658821744.6633298:
2022-07-26 09:49:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
2022-07-26 09:49:28 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658821768.2424989:
<KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="CONNECTIONSTATE_REQUEST" Reserve="0" TotalLength="16" />
 body="<ConnectionStateRequest communication_channel_id="16", control_endpoint="0.0.0.0:0/tcp" />" />
2022-07-26 09:49:28 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 0610020800081000
2022-07-26 09:49:28 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658821768.2440615:
<KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="CONNECTIONSTATE_RESPONSE" Reserve="0" TotalLength="8" />
 body="<ConnectionStateResponse communication_channel_id="16" status_code="ErrorCode.E_NO_ERROR" />" />
2022-07-26 09:50:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 09:50:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658821804.6589453:
<KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" Reserve="0" TotalLength="23" />
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.6")" dst_addr="GroupAddress("0/0/4")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />" />" />
2022-07-26 09:50:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
2022-07-26 09:50:38 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658821838.263795:
2022-07-26 09:50:38 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 0610020800081000
2022-07-26 09:50:38 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658821838.265663:
2022-07-26 09:51:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 09:51:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658821864.654608:
2022-07-26 09:51:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
2022-07-26 09:51:30 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce01378236403008025a2
2022-07-26 09:51:30 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658821890.858205:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.120")" dst_addr="GroupAddress("4/3/100")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x25,0xa2]" />" />" />" />" />
2022-07-26 09:51:30 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.120" destination_address="4/3/100" payload="<GroupValueWrite value="<DPTArray value="[0x25,0xa2]" />" />" />
2022-07-26 09:51:48 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658821908.2842393:
2022-07-26 09:51:48 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 0610020800081000
2022-07-26 09:51:48 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658821908.2859213:
2022-07-26 09:52:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 09:52:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658821924.6503093:
2022-07-26 09:52:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
2022-07-26 09:52:58 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658821978.3404396:
2022-07-26 09:52:58 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 0610020800081000
2022-07-26 09:52:58 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658821978.34214:
2022-07-26 09:53:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 09:53:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658821984.6470857:
2022-07-26 09:53:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
2022-07-26 09:54:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 09:54:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822044.6427062:
2022-07-26 09:54:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
2022-07-26 09:54:08 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822048.346983:
2022-07-26 09:54:08 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 0610020800081000
2022-07-26 09:54:08 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822048.3490624:
2022-07-26 09:55:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 09:55:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822104.6376507:
2022-07-26 09:55:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
2022-07-26 09:55:18 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822118.3638296:
2022-07-26 09:55:18 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 0610020800081000
2022-07-26 09:55:18 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822118.3658843:
2022-07-26 09:55:51 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0137823640300802562
2022-07-26 09:55:51 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822151.1924117:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.120")" dst_addr="GroupAddress("4/3/100")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x25,0x62]" />" />" />" />" />
2022-07-26 09:55:51 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.120" destination_address="4/3/100" payload="<GroupValueWrite value="<DPTArray value="[0x25,0x62]" />" />" />
2022-07-26 09:56:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce013060004030080003f
2022-07-26 09:56:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822164.6348634:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.6")" dst_addr="GroupAddress("0/0/4")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x3f]" />" />" />" />" />
2022-07-26 09:56:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x3f]" />" />" />
2022-07-26 09:56:28 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822188.373903:
2022-07-26 09:56:28 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 0610020800081000
2022-07-26 09:56:28 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822188.3753715:
2022-07-26 09:57:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 09:57:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822224.7946928:
2022-07-26 09:57:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
2022-07-26 09:57:31 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200018041000002900bce01305000304008049391e
2022-07-26 09:57:31 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822251.2532046:
<KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" Reserve="0" TotalLength="24" />
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.5")" dst_addr="GroupAddress("0/0/3")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x49,0x39,0x1e]" />" />" />" />" />
2022-07-26 09:57:31 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.5" destination_address="0/0/3" payload="<GroupValueWrite value="<DPTArray value="[0x49,0x39,0x1e]" />" />" />
2022-07-26 09:57:31 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200018041000002900bce0130500020400801a0716
2022-07-26 09:57:31 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822251.4527204:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.5")" dst_addr="GroupAddress("0/0/2")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x1a,0x7,0x16]" />" />" />" />" />
2022-07-26 09:57:31 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.5" destination_address="0/0/2" payload="<GroupValueWrite value="<DPTArray value="[0x1a,0x7,0x16]" />" />" />
2022-07-26 09:57:31 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 06100420001d041000002900bce0130500010900807a071a49391e4180
2022-07-26 09:57:31 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822251.6535:
<KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" Reserve="0" TotalLength="29" />
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.5")" dst_addr="GroupAddress("0/0/1")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x7a,0x7,0x1a,0x49,0x39,0x1e,0x41,0x80]" />" />" />" />" />
2022-07-26 09:57:31 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.5" destination_address="0/0/1" payload="<GroupValueWrite value="<DPTArray value="[0x7a,0x7,0x1a,0x49,0x39,0x1e,0x41,0x80]" />" />" />
2022-07-26 09:57:38 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822258.3828812:
2022-07-26 09:57:38 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 0610020800081000
2022-07-26 09:57:38 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822258.3849907:
2022-07-26 09:58:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 09:58:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822284.6260176:
2022-07-26 09:58:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
2022-07-26 09:58:27 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0137823640300802523
2022-07-26 09:58:27 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822307.7834005:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.120")" dst_addr="GroupAddress("4/3/100")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x25,0x23]" />" />" />" />" />
2022-07-26 09:58:27 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.120" destination_address="4/3/100" payload="<GroupValueWrite value="<DPTArray value="[0x25,0x23]" />" />" />
2022-07-26 09:58:48 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822328.3951764:
2022-07-26 09:58:48 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 0610020800081000
2022-07-26 09:58:48 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822328.6070352:
KNX Log Part 2:
2022-07-26 09:59:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 09:59:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822344.621364:
2022-07-26 09:59:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
2022-07-26 09:59:19 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 0/3/25 for WC Präsenz - State
2022-07-26 09:59:19 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 0/3/26 for Bad Präsenz - State
2022-07-26 09:59:19 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="0/3/25" payload="<GroupValueRead />" />
2022-07-26 09:59:19 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822359.095487:
<KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" Reserve="0" TotalLength="21" />
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="18" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("0/3/25")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:19 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce013010319010000
2022-07-26 09:59:19 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822359.1148903:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("0/3/25")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:19 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="0/3/26" payload="<GroupValueRead />" />
2022-07-26 09:59:19 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822359.1476643:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="19" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("0/3/26")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:19 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce01301031a010000
2022-07-26 09:59:19 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822359.167363:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("0/3/26")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 0/3/25
2022-07-26 09:59:21 WARNING (MainThread) [xknx.log] Could not sync group address '0/3/25' (WC Präsenz - State)
2022-07-26 09:59:21 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 0/3/26
2022-07-26 09:59:21 WARNING (MainThread) [xknx.log] Could not sync group address '0/3/26' (Bad Präsenz - State)
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 2/3/131 for Bad Stripes - State
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 2/3/137 for Bad Stripes - Brightness
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="2/3/131" payload="<GroupValueRead />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822361.098836:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="20" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("2/3/131")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce013011383010000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.1181037:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("2/3/131")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="2/3/137" payload="<GroupValueRead />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822361.1507874:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="21" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("2/3/137")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002900bce013971383010040
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.198966:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.151")" dst_addr="GroupAddress("2/3/131")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTBinary value="0" />" />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.151" destination_address="2/3/131" payload="<GroupValueResponse value="<DPTBinary value="0" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce013011389010000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.384669:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("2/3/137")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 2/3/133 for Bad Stripes - Hue
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="2/3/133" payload="<GroupValueRead />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822361.3863833:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="22" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("2/3/133")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce013011385010000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.4053879:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("2/3/133")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200016041000002900bce01397138902004000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.4673636:
<KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="TUNNELLING_REQUEST" Reserve="0" TotalLength="22" />
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.151")" dst_addr="GroupAddress("2/3/137")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0x0]" />" />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.151" destination_address="2/3/137" payload="<GroupValueResponse value="<DPTArray value="[0x0]" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 2/3/135 for Bad Stripes - Saturation
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="2/3/135" payload="<GroupValueRead />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822361.4693723:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="23" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("2/3/135")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce013011387010000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.490274:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("2/3/135")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200016041000002900bce01397138502004000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.5319028:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.151")" dst_addr="GroupAddress("2/3/133")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0x0]" />" />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.151" destination_address="2/3/133" payload="<GroupValueResponse value="<DPTArray value="[0x0]" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 4/3/101 for WC Temperatur - Value
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="4/3/101" payload="<GroupValueRead />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822361.5329401:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="24" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/101")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce013012365010000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.553919:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/101")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0137823650300400d8c
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.5905104:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.120")" dst_addr="GroupAddress("4/3/101")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0xd,0x8c]" />" />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.120" destination_address="4/3/101" payload="<GroupValueResponse value="<DPTArray value="[0xd,0x8c]" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 4/3/121 for Bad Temperatur - Value
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="4/3/121" payload="<GroupValueRead />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822361.5917718:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="25" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/121")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce013012379010000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.6128623:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/121")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200016041000002900bce013971387020040ff
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.6321177:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.151")" dst_addr="GroupAddress("2/3/135")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0xff]" />" />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.151" destination_address="2/3/135" payload="<GroupValueResponse value="<DPTArray value="[0xff]" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 4/3/122 for Bad Temperatur FuĂźboden - Value
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="4/3/122" payload="<GroupValueRead />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822361.6441453:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="26" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/122")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0138c23790300400d19
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.6554306:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.140")" dst_addr="GroupAddress("4/3/121")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0xd,0x19]" />" />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.140" destination_address="4/3/121" payload="<GroupValueResponse value="<DPTArray value="[0xd,0x19]" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce01301237a010000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.6780314:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/122")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 4/3/123 for Bad Temperatur Badewanne - Value
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="4/3/123" payload="<GroupValueRead />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822361.6950428:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="27" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/123")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0138f237a0300400d00
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.7112708:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.143")" dst_addr="GroupAddress("4/3/122")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0xd,0x0]" />" />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.143" destination_address="4/3/122" payload="<GroupValueResponse value="<DPTArray value="[0xd,0x0]" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce01301237b010000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.7337112:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/123")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 4/3/124 for Bad Temperatur Dusche Kopfbrause - Value
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="4/3/124" payload="<GroupValueRead />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822361.7462273:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="28" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/124")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce01301237c010000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.765217:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/124")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0138f237b0300400cf1
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.7864163:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.143")" dst_addr="GroupAddress("4/3/123")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0xc,0xf1]" />" />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.143" destination_address="4/3/123" payload="<GroupValueResponse value="<DPTArray value="[0xc,0xf1]" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 4/3/125 for Bad Temperatur Dusche Handbrause - Value
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="4/3/125" payload="<GroupValueRead />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822361.7972765:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="29" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/125")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce01390237c0300400d37
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.809296:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.144")" dst_addr="GroupAddress("4/3/124")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0xd,0x37]" />" />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.144" destination_address="4/3/124" payload="<GroupValueResponse value="<DPTArray value="[0xd,0x37]" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce01301237d010000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.8318448:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("4/3/125")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.state_updater] StateUpdater reading 5/3/103 for WC Lautstärke setzen - Value
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Outgoing" source_address="1.3.1" destination_address="5/3/103" payload="<GroupValueRead />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822361.8500793:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="30" cemi="<CEMIFrame code="L_DATA_REQ" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("5/3/103")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce01390237d0300400d14
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.8649318:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.144")" dst_addr="GroupAddress("4/3/125")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueResponse value="<DPTArray value="[0xd,0x14]" />" />" />" />" />
2022-07-26 09:59:21 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.144" destination_address="4/3/125" payload="<GroupValueResponse value="<DPTArray value="[0xd,0x14]" />" />" />
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200015041000002e00bce013012b67010000
2022-07-26 09:59:21 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822361.8870773:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_CON" src_addr="IndividualAddress("1.3.1")" dst_addr="GroupAddress("5/3/103")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueRead />" />" />" />
2022-07-26 09:59:23 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 5/3/103
2022-07-26 09:59:23 WARNING (MainThread) [xknx.log] Could not sync group address '5/3/103' (WC Lautstärke setzen - Value)
2022-07-26 09:59:58 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822398.6166391:
2022-07-26 09:59:58 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 0610020800081000
2022-07-26 09:59:58 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822398.618176:
2022-07-26 10:00:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 10:00:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822404.6213417:
2022-07-26 10:00:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
KNX Log Part 3:
2022-07-26 10:01:04 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0130600040300800040
2022-07-26 10:01:04 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822464.617712:
2022-07-26 10:01:04 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.6" destination_address="0/0/4" payload="<GroupValueWrite value="<DPTArray value="[0x0,0x40]" />" />" />
2022-07-26 10:01:08 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822468.624113:
2022-07-26 10:01:18 DEBUG (KNX Interface) [xknx.log] Error: KNX bus did not respond in time (10 secs) to request of type 'ConnectionState'
2022-07-26 10:01:18 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822478.6354024:
2022-07-26 10:01:18 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce0137823640300802562
2022-07-26 10:01:18 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822478.883743:
2022-07-26 10:01:18 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.120" destination_address="4/3/100" payload="<GroupValueWrite value="<DPTArray value="[0x25,0x62]" />" />" />
2022-07-26 10:01:28 DEBUG (KNX Interface) [xknx.log] Error: KNX bus did not respond in time (10 secs) to request of type 'ConnectionState'
2022-07-26 10:01:28 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822488.646632:
2022-07-26 10:01:38 DEBUG (KNX Interface) [xknx.log] Error: KNX bus did not respond in time (10 secs) to request of type 'ConnectionState'
2022-07-26 10:01:38 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822498.6574748:
2022-07-26 10:01:38 DEBUG (KNX Interface) [xknx.raw_socket] Received via tcp: 061004200017041000002900bce01378236403008025a1
2022-07-26 10:01:38 DEBUG (KNX Interface) [xknx.knx] Received from 10.10.2.2:3671/tcp at 1658822498.8894708:
 body="<TunnellingRequest communication_channel_id="16" sequence_counter="0" cemi="<CEMIFrame code="L_DATA_IND" src_addr="IndividualAddress("1.3.120")" dst_addr="GroupAddress("4/3/100")" flags="1011110011100000" tpci="TDataGroup()" payload="<GroupValueWrite value="<DPTArray value="[0x25,0xa1]" />" />" />" />" />
2022-07-26 10:01:38 DEBUG (MainThread) [xknx.telegram] <Telegram direction="Incoming" source_address="1.3.120" destination_address="4/3/100" payload="<GroupValueWrite value="<DPTArray value="[0x25,0xa1]" />" />" />
2022-07-26 10:01:48 DEBUG (KNX Interface) [xknx.log] Error: KNX bus did not respond in time (10 secs) to request of type 'ConnectionState'
2022-07-26 10:01:48 WARNING (KNX Interface) [xknx.log] Heartbeat to KNX bus failed. No answer from tunneling server.
2022-07-26 10:01:48 DEBUG (KNX Interface) [xknx.knx] Sending to 10.10.2.2:3671/tcp at 1658822508.6703882:
<KNXIPFrame <KNXIPHeader HeaderLength="6" ProtocolVersion="16" KNXIPServiceType="DISCONNECT_REQUEST" Reserve="0" TotalLength="16" />
 body="<DisconnectRequest communication_channel_id="16" control_endpoint="0.0.0.0:0/tcp" />" />
2022-07-26 10:01:48 DEBUG (MainThread) [xknx.state_updater] StateUpdater stopping
2022-07-26 10:01:49 DEBUG (KNX Interface) [xknx.log] Error: KNX bus did not respond in time (1.0 secs) to request of type 'Disconnect'
2022-07-26 10:01:49 DEBUG (KNX Interface) [xknx.log] Tunnel disconnected (communication_channel: 16)
2022-07-26 10:01:49 DEBUG (KNX Interface) [xknx.log] Closing TCP transport. None
2022-07-26 10:02:01 DEBUG (KNX Interface) [xknx.log] Could not establish connection to KNX/IP interface. OSError: [Errno 113] Connect call failed ('10.10.2.2', 3671)
[... repeats]
Hi :wave:!
How do you usually resolve this issue? Restart HA or the router or both…?
If it is unavailable in HA, can you connect from eg. ETS to it or is this then also not possible?
I haven’t tried to connect via ETS.
HTTP and KNX Tunnels are no longer available.
To temporary solve this problem, I have disconnected the power and plugged it in again (it’s currently a WIP installation like a test board).
MDT answered me, that they do not know any issues with Home Assistant and their IP Routers.
They suggested to downgrade to a June version, but I think that is not the solution because the June versions had the same problem.
I will add now a secondary (offline) network to test if the connection is stable if there is no VLAN / SDN / special Network included.
If this helps, I will keep the second network for KNX IP only. Not my favorite because it need more cables from second floor to the basement which is currently used for a WiFI Access Point with PoE and the switch on the second floor does not have PoE (The switch with PoE has a very noisy fan).
Kind regards,
Daxi
I wouldn’t know of any such problems with MDT devices with HA. So I’d be curious if the Router also hangs if you don’t use HA at all, but the rest of your installation unchanged. Of course this is tricky to test as you said it happens at random intervals.
Maybe it would help (MDT support) if you could do a tcpdump of when the problem occurs. But I guess same problem applies and the tcpdump would probably grow huge.
Or maybe you just have a defective device (hardware problem).
An update:
I have added a second physical network and do not use the omada network to handle KNX traffic.
My server where Home Assistant is running on has two interfaces. One is connected to the omada network and the second one to a network which uses an old fritz box router.
Since this change, I have no problems anymore with the KNX integration.
To be honest I like and dislike this solution.
On one hand there is a physical separation of both networks now, but it means also that I have to use two lan cables from the second floor to the basement where the second knx line is located in future.
I have not found any solution at omada to change it to work as intended.
Hm :thinking: this really sounds like an incompatibility between something on your main network and the mdt router. I wonder what that is, but since the router seems to deadlock I guess it’s MDTs turn to fix that. Have you contacted them?
Yes, I have contacted them but they told me that there is no known issue.
But I had similar issues with a MagentaTV box (freezing image after some seconds) because of multicast traffic.
I believe that this issue is more on side of tp-link.
When I have more time to play around I will contact them, for now I will keep the second network to make progress on other smart home things which are otherwise blocked.
An update from my side:
I had some connection issues with the physical second network too.
The issues were much less (once every month instead of once every some days).
It seems that the MDT IP Router does not work properly at my network and HA connected.
The newest device in my network is now the Timberwolf Server from ElabNet.
This device seems to be much more stable than the MDT interface. Until now, I had no connection issue with it.
Kind regards,
Daxi
