HA looses connection with Insteon Hub 2
I have HA configured to connect to my Insteon Hub 2. The integration works great most of the time, but with no rhyme or reason, HA will disconnect from the Insteon Hub and the only way to resolve it is to reboot both the HA server and the Insteon Hub. Once both of those come back online, they will resume normal operation. I am paying for the Insteon cloud service along with using it side by side with the HA instance. During the Insteon server shut down, I never had the problem, but now that the server is online, I have to reboot the whole system at least once a week. When the servers did come back online, I did find that I could block the internet from Insteon Hub would keep things online, but now that I have taken that block has been taken of my home router, I have to reboot things once a week. Is there a workaround that has been found other than blocking the internet from the Insteon Hub from connecting to its servers?
@teharris1
There is a known issue where the Hub will lose connectivity to Home Assistant if its allowed to talk to the internet. Block that access on your router/ firewall, or remove the gateway from DHCP for it.
That being said, I am back here once again searching Insteon as mine is loosing connectivity again. I think its different this time, as restarting HA will fix it, for now…
Just a thought as I do not use Insteon Cloud. How are you setting IP address on hub? Could it be that some Insteon update causes it to change? Although that would not explain it coming back on restart.
Or maybe it would if you have a reserved IP address. Insteon update gets applied, device gets new address, device is online but that should not require HA reboot.
Yea…I know of the block the internet access to the hub trick and it does work, but I am also paying for the Insteon Cloud service, so if I were to block access, that would make that not work. Posted to see if there is a fix to the bug causing the issue.
My home router is setting the IP address, but it is a static IP address. It usually happens 1-2 times a week and I have not found the pattern as to when/why it happens. It appears random from what I can see.
Insteon is currently working on a fix for HA losing connection to the Hub 2. It is currently in test.
As @RSlick mentioned, we have been working on a fix for the connectivity issue discussed in this thread. If you would like to help test this new firmware, please fill out the form here and mention Home Assistant testing in the ā€˜about me’ section Become an Insteon Beta Tester — Insteon
Thank you all for your patience and support.
Just filled it out…although I think I have filled it out before in the past.
I’m curious if anyone has received the beta hub firmware and if it has resolved the hanging connection / connection loss with the Insteon Hub? Would also love to know a rough estimate for when Insteon might fully release the firmware. We have been stuck with rev 1019 for over four years - Insteon Hub 2 (2245-222) Firmware Release Notes — Insteon
We are about to start beta testing. If you’re interested in participating, please sign up here; Become an Insteon Beta Tester — Insteon Please be sure to mention you are interested in testing new hub firmware in the ā€˜about me’ section.
Has this connectivity issue been resolved?
I’m considering replacing my Universal Devices Polisy Insteon Controller with the Insteon Hub 2. The Polisy works okay with HA but it’s getting old and is being phased out with their new EISY controller.
It has been fixed in the beta version that I was allowed to test and make sure it is working. I am not sure if it has been pushed out to everyone yet.
All testing has gone well and we are getting ready to release the update to the public.
Thank you to all that participated in this beta!
Everyone, the update ā€œ1020ā€ has been released. You can find the release notes here: Insteon Hub 2 (2245-222) Firmware Release Notes
This update will only apply to Hub 2 model # 2245-222. Note that to receive the update, the hub needs an associated Insteon account. It does not require an active subscription.
To view which version you are on, open the Director app and tap on Settings > Hub Info and under Version Info, the Hub Firmware Version should read 1020. If the version is not at 1020, you can tap the Check for Update button to initiate the update.
If you do not use Director, you can also check the firmware version by visiting Insteon - Log in - and after logging in, scroll to the bottom of the page and you can find it under System Info, Hub Ethernet Firmware version.
There’s also a third option that doesn’t require logging into an account. While on the same network as your Insteon Hub 2, visit Get Insteon Hub Info
If your hub 2 has not received the update, or if you’re having trouble logging into Director, please reach out to [email protected] and refer to this thread.
-Isaac
