HA Management Console
One thing I’ve struggled with is the seeming lack of an Operations or Management Console for HA. I’ve started to throw some things together, but still have a long ways to go. My console so far lists
  1. running automations
  2. disabled automations
  3. running scripts
  4. hardware stats (CPU, memory, disc utilization etc)
  5. restart HA
Planned additions are:
  1. kill a running automation / script
  2. reboot
  3. HA Core updates available (maybe)
I’m curious what other people have developed to oversee / manage their HA implementation
In general Open your Home Assistant instance and show your settings menu.
But the beauty is that you can do what you want :slight_smile:
I use a markdown card with this code to keep track of when automations have fired, maybe something you would like?
|D|H|M||Name|
{% for state in states.automation
   |selectattr('attributes.last_triggered', 'defined')
   |selectattr('attributes.last_triggered')
   |sort(attribute='attributes.last_triggered', reverse=true) -%}
  {%- set t = now() - state.attributes.last_triggered -%}
  {%- set days = t.days if t.days > 0 else ' ' -%}
  {%- set hrs = t.seconds//3600 %}
  {%- set hrs = hrs if hrs > 0 else ' ' -%}
  |{{days}}|{{hrs}}|{{(t.seconds//60)%60}}||_{{state.name}}_|
{% endfor %}
That’s a great addition - I have added it! Because I have over 200 automations though - it was a bit long so I added a scroll bar.
I notice that if an automation has never been triggered, it will not show up in the list. Any thoughts on how to make that show up? I made a version of this card to show scripts - and that’s where I noticed that 2 of my scripts didn’t show up because they had never run - which, when I identified that, was good information as I can then look at them to determine why not? Are they needed? I find sometimes I have stuff sitting around that I wrote long ago and is no longer necessary (typically as I learn more about HA, I realize that the way I wrote stuff a year ago was not that great!)
type: markdown
content: |-
  |D|H|M||Name|
  {% endfor %}
card_mod:
  style: |
    ha-markdown {
      max-height: 300px;
      overflow-y: auto;
Sorry, no idea how to make it display automations that have not run, I have some automations that I do not want to run my self (water leak sensors), but these I test from time to time.
