I have a few Qubino’s and unless they are broken, I don’t see HA receiving an event when I press any of the 2 physical switches: I can’t find anything in the logs on the timestamp that I press the buttons so I assume nothing really comes in. The only thing that comes in are meter reports.
I can switch each relay individually through HA, so that works.
I added the Qubino Flush 2 Relays as a secure node in HA, so HA should have every info. I will add a brand new Flush 2 Relays to make sure they’re not malfunctioning.
What can I do to fix this ? What could it be ? I assume that others have this working without issues ? Or am I the only one having this problem ?
Many thanks !
2020-05-24 20:25:43.818 Detail, Node007, Received: 0x01, 0x17, 0x00, 0x04, 0x00, 0x07, 0x11, 0x60, 0x06, 0x01, 0x32, 0x02, 0x21, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xb8
2020-05-24 20:25:43.818 Info, Node007, Received a MultiInstanceEncap from node 7, instance 1, for Command Class COMMAND_CLASS_METER
2020-05-24 20:25:43.818 Detail, Node007, Refreshed Value: old value=false, new value=false, type=bool
2020-05-24 20:25:43.818 Detail, Node007, Changes to this value are not verified
2020-05-24 20:25:43.818 Info, Node007, Received Meter report from node 7: Power=0.0W
2020-05-24 20:25:43.818 Detail, Node007, Refreshed Value: old value=0.0, new value=0.0, type=decimal
2020-05-24 20:25:43.818 Detail, Node007, Notification: ValueChanged
2020-05-24 20:25:43.819 Detail, Node007, Notification: ValueChanged
2020-05-24 20:25:43.935 Detail, Node007, Received: 0x01, 0x17, 0x00, 0x04, 0x00, 0x07, 0x11, 0x60, 0x06, 0x02, 0x32, 0x02, 0x21, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbb
2020-05-24 20:25:43.935 Info, Node007, Received a MultiInstanceEncap from node 7, instance 2, for Command Class COMMAND_CLASS_METER
2020-05-24 20:25:43.935 Detail, Node007, Refreshed Value: old value=false, new value=false, type=bool
2020-05-24 20:25:43.935 Detail, Node007, Changes to this value are not verified
2020-05-24 20:25:43.935 Info, Node007, Received Meter report from node 7: Power=0.0W
2020-05-24 20:25:43.935 Detail, Node007, Refreshed Value: old value=0.0, new value=0.0, type=decimal
2020-05-24 20:25:43.935 Detail, Node007, Notification: ValueChanged
2020-05-24 20:25:43.936 Detail, Node007, Notification: ValueChanged
2020-05-24 20:25:44.052 Detail, Node007, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x07, 0x0a, 0x32, 0x02, 0x21, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc3
2020-05-24 20:25:44.052 Detail, Node007, Refreshed Value: old value=false, new value=false, type=bool
2020-05-24 20:25:44.052 Detail, Node007, Changes to this value are not verified
2020-05-24 20:25:44.052 Info, Node007, Received Meter report from node 7: Power=0.0W
2020-05-24 20:25:44.052 Detail, Node007, Refreshed Value: old value=0.0, new value=0.0, type=decimal
2020-05-24 20:25:44.052 Detail, Node007, Notification: ValueChanged
2020-05-24 20:25:44.053 Detail, Node007, Notification: ValueChanged
