Trying this:
version: '3'
services:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- /home/HomeAssistant/config:/config
- /home/frigate/config:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
privileged: true
# network_mode: host
networks:
macvlan_iot:
ipv4_address: 192.168.20.4
# environment:
# ServerIP: 192.168.20.4
# WEBPASSWORD: "kjahsd7asidasmduae7876"
# DNS1: 127.0.0.1
# DNS2: 1.1.1.1
networks:
macvlan_iot:
driver: macvlan
driver_opts:
parent: eno1
ipam:
config:
- subnet: 192.168.20.0/24
gateway: 192.168.20.1
ip_range: 192.168.20.4/32
However it does not work and I get this errors in the log:
s6-rc: info: service legacy-services successfully started
2023-09-19 11:25:33.743 ERROR (Thread-5) [pychromecast.socket_client] [Bedroom Display(192.168.20.56):8009] Failed to connect to service ServiceInfo(type='mdns', data='google-nest-hub-220015da2323da5406e50407810f2d2f._googlecast._tcp.local.'), retrying in 5.0s
2023-09-19 11:25:33.744 ERROR (Thread-4) [pychromecast.socket_client] [Kitchen Display(192.168.20.133):8009] Failed to connect to service ServiceInfo(type='mdns', data='google-nest-hub-aa53b3b5b0e6426d7024a349b9ea910e._googlecast._tcp.local.'), retrying in 5.0s
2023-09-19 11:25:33.745 ERROR (Thread-6) [pychromecast.socket_client] [Office Display(192.168.20.145):8009] Failed to connect to service ServiceInfo(type='mdns', data='google-nest-hub-c975dce30eed835d290ed2de9ae283fa._googlecast._tcp.local.'), retrying in 5.0s
2023-09-19 11:25:35.690 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Error requesting homeassistant_alerts data: Cannot connect to host alerts.home-assistant.io:443 ssl:default [Try again]
