HA SwitchPlate HASPone: DIY In-Wall Touchscreen Home Assistant Controller
Hey @Gagan_Kochar these are great. Love the idea of being able to change the fronts.
Are you able to share any of the plans you made in making these stencils?
Hey @luma
Just catching up again.
Actually what I wanted to do was add a temp and humidity sensor to the Spare pins on the wemos and send that data over mqtt.
Any advice or suggestions on where to start?
Cheers
@jezzard
hi thank you for appreciating, i havenā€™t got time so havenā€™t shared the designs yet its just in 2 piece front and frame i like to call it , i guess by stencil you are referring to the front facia
A question that might already have been answered.
For every switch plate I get a link on my sidebar but the links are just blank pages for me? Did I forget to set something up that would put content on these pages?
in the packages sub folders you have your HA switchplate folders
look in the *_components.yaml file for the panel_iframe: section
mine look like this
 panel_iframe:
   plate01:
     title: "plate01"
     url: "http://plate01"
     icon: "mdi:cellphone-text"
just # it out
# panel_iframe:
#   plate01:
#     title: "plate01"
#     url: "http://plate01"
#     icon: "mdi:cellphone-text"
do a config check and a restart fix
Hi, would you by any chance still have the Node-Red flow and still be willing to share it? It would be awesome for me to have a template to start withā€¦ Thank you! :slight_smile:
That will require modification to the Arduino side of the project. I donā€™t currently have any plans for adding arbitrary sensor libraries to the project.
To add some context to this: if youā€™re using SSL the iframe wonā€™t work. I donā€™t think there is any workaround for this, so using @myleā€™s suggestion to remove the iframe is probably your best course of action.
Hi everyone,
Iā€™m quite new with HA SwitchPlate, and Iā€™m now learning to play around with the different components.
My first trial was to use the page 4 dimmers to control the position of some roller shutters (cover in HA).
However, I donā€™t understand why:
  1. only one of the 3 covers is working when I move the slider on the display
  2. when I chenge page on HASP and go back to the page with the sliders, they go back to the middle-position (50%)
  3. the sliders do not ā€œsyncā€ with the sliders in lovelace
    Iā€™m quite sure thereā€™s something obvious that Iā€™m doing wrong, but I really cannot figure out!
    I have started from the default set of settings provided from @lumaā€™s github repository and modified as follows.
Below is the code for the automations (the default one, modified at my best):
# Automations to configure slider controls on page 4 as light dimmers
automation:
  - alias: hasp_displ_entrance_p4_DimmersInit
    - platform: state
      entity_id: 'binary_sensor.displ_entrance_connected'
      to: 'on'
    - platform: homeassistant
      event: start
    - service: mqtt.publish
        topic: 'hasp/displ_entrance/command/p[4].b[4].txt'
        payload: '"Living left"'
        topic: 'hasp/displ_entrance/command/p[4].b[5].txt'
        payload: '"Living right"'
        topic: 'hasp/displ_entrance/command/p[4].b[6].txt'
        payload: '"Bedroom"'
  # when the user moves the slider, change the light in Hass
  - alias: hasp_displ_entrance_p4_Dimmer7UpdateHass
    - platform: mqtt
      topic: 'hasp/displ_entrance/state/p[4].b[7].val'
    - service: cover.set_cover_position
      data_template:
        entity_id: cover.tapparella_salotto_sinistra
        position: '{{ trigger.payload }}'
  # When the light is changed in Hass, update HASP to move the dimmer
  - alias: hasp_displ_entrance_p4_Dimmer7UpdateHASP
    - platform: state
      to: 'on'
      event: start
    - platform: state
      data_template:
        topic: 'hasp/displ_entrance/command/p[4].b[7].val'
        payload_template: '{{states.cover.tapparella_tapparella_salotto_sinistra.attributes.position|default(0)|int}}'
  - alias: hasp_displ_entrance_p4_Dimmer8UpdateHass
    - platform: mqtt
      topic: 'hasp/displ_entrance/state/p[4].b[8].val'
    - service: cover.set_cover_posiiton
      data_template:
        entity_id: cover.tapparella_salotto_destra
  - alias: hasp_displ_entrance_p4_Dimmer8UpdateHASP
    - platform: state
      to: 'on'
      event: start
    - platform: state
      entity_id: light.light_2
      data_template:
        topic: 'hasp/displ_entrance/command/p[4].b[8].val'
        payload_template: '{{states.cover.tapparella_salotto_destra.attributes.position|default(0)|int}}'
  - alias: hasp_displ_entrance_p4_Dimmer9UpdateHass
    - platform: mqtt
      topic: 'hasp/displ_entrance/state/p[4].b[9].val'
      data_template:
        entity_id: cover.tapparella_camera
  - alias: hasp_displ_entrance_p4_Dimmer9UpdateHASP
    - platform: state
      to: 'on'
      event: start
    - platform: state
      data_template:
        topic: 'hasp/displ_entrance/command/p[4].b[9].val'
        payload_template: '{{states.cover.tapparella_camera.attributes.position|default(0)|int}}'
Here is the normal configuration.yaml for the covers involved that I use in HA:
cover:
  -  platform: mqtt
     state_topic: "shellies/shellyswitch-32B81B/roller/0"
     command_topic: "shellies/shellyswitch-32B81B/roller/0/command"
     position_topic: "shellies/shellyswitch-32B81B/roller/0/pos"
     set_position_topic: "shellies/shellyswitch-32B81B/roller/0/command/pos"
     payload_open: "open"
     payload_close: "close"
     payload_stop: "stop"
     retain: false
     optimistic: false
     qos: 1
     position_open: 100
     position_closed: 0
  -  platform: mqtt
     name: "Tapparella salotto destra"
     state_topic: "shellies/shellyswitch-32BABB/roller/0"
     command_topic: "shellies/shellyswitch-32BABB/roller/0/command"
     position_topic: "shellies/shellyswitch-32BABB/roller/0/pos"
     set_position_topic: "shellies/shellyswitch-32BABB/roller/0/command/pos"
     retain: false
     optimistic: false
     qos: 1
     position_open: 100
     position_closed: 0
  -  platform: mqtt
     name: "Tapparella salotto sinistra"
     state_topic: "shellies/shellyswitch-32BBE7/roller/0"
     command_topic: "shellies/shellyswitch-32BBE7/roller/0/command"
     position_topic: "shellies/shellyswitch-32BBE7/roller/0/pos"
     set_position_topic: "shellies/shellyswitch-32BBE7/roller/0/command/pos"
     retain: false
     optimistic: false
     qos: 1
     position_open: 100
     position_closed: 0
Thanks a lot to anybody who can help!
Thanks @Gagan_Kochar
I seem to have some time on my hands. Any tips for creating the two part frame? I see your inside is slimmer/smaller than the outer case.
Iā€™ve spent the last couple of weeks preparing for a LoRaWAN event I was presenting for a local startup accelerator which had the HASP project on the back burner. To nobodyā€™s surprise, that event got cancelled with everything else, and now Iā€™m flat out of excuses to be working on HASP :smiley:
Todayā€™s experiment was to try replacing FontAwesome with Material Design icons to better align w/ Home Assistant. The result is a huge number of icons available (5118 all together), which you can preview here.
Iā€™m only mentioning this because several folks are digging into the dev build and I wanted to make sure those folks are aware that any customization you might be working on w/ the FA fontset is going to need to be changed over to Material. I hope to have an updated dev build available for testers within a day or three.
edit: sadly, the entire experiment is a bust :frowning: Too many icons in the set to make it fit on a Nextion. Back to font awesome!
So I ended up not customizing my design since the screen does not have a great viewing angle the black on white simplistic design is the most readable. With that said I have a couple of requests that might be useful to users
ā€¢ a simple color picker for colored lights. Maybe itā€™s more like 9 buttons you can manually add colors to and then 1 slider at the bottom due to the screens limitations.
ā€¢ a dimmer page, this page would be dynamic depending on what light was selected previously. I have a very big living room so it has a ton of lights. Beside from having scenes sometimes people like to adjust them manually and right now if you are dimming you are limited to 3 lights, so with a dynamic dimmer page you could have 8 lights and when tapping each light you get 1 dimmer page that has 1 vertical slider on it.
ā€¢ for the media page it would be nice, if possible, if there is no media playing another page will take its place So you could have a radio station selector for example. Right now the media page is blank and then serves no purpose and you eliminate the chance to have another screen in its place.
I got 3 of these installed now and I am planning to add 3 more in the next coming week.
:clap::clap::clap:
Hi All, my name is Simon, I have been following this project for a while and decided to get involved, I have purchased Nextron screen and `ESP8266 etc, I read through the posts here and wow so much work has gone into this so impressed, can someone give me a pointer on where to start with configuring things, I am running the latest HA through lovelace UI, using HASSIO, any assistance would be grateful
I live in Scotland, and now with lockdown imminent I will have heaps of time on my hands to do this and other projects I have not been able to fine time with
Hey @luma,
I havenā€™t got much further with the sensors yet but saw your post regarding the icons.
Would this be the same if we could access the pro version of font awesome?
Cheers
Ross
If anything the pro set (being ~6x the size of the free set) makes the problem worse :frowning:
I think weā€™re OK w/ the free set, I was more trying to make Material Design icons work just to get in alignment w/ the rest of Home Assistant. The result is too big to fit into the project, while the FA set just barely works. That will do, and I think it still looks good for our purposes.
iā€™ve found the tjc tft for 0.40 beta, iā€™m trying to upload it via sd card but it seams to be stuck at 90%
Thanks for the headā€™s up @Superimo88! Just pushed all the TJC stuff out yesterday, but hadnā€™t tested it fully yet. Iā€™ll take a deeper look into this.
iā€™m now uploading it via ftdi, it will take a lot of time but will see if it works
Thank you very much luma!
The hour now shows correctly, for the temperature I think that the problem is that Iā€™m using Celsius instead of Fahrenheitā€¦ How can I export a log file?
Thank you again!
Best regards
Simone
HASP v0.40 release
New fonts, new pages, new automations, new models, and some core code improvements
Nextion HMI
This release marks the first major update the Nextion HMI used by the HASP project.
  • Proportional fonts - Noto Sans has been added in 6 different sizes and styles
  • Anti-aliased fonts - The existing Consolas and Wingdings fonts, as well as the new Noto Sans font are now all anti-aliased.
  • FontAwesome icons - All free FontAwesome icon codepoints have been added to the Noto Sans fonts in the project, allowing mixed used of text and icons anywhere text is allowed.
  • Removed page 9 with graph component - A poll of users suggested this wasnā€™t being used and we gained a lot of RAM by removing it.
  • Added new page 9 with HVAC control demonstration
  • Added new page 10 with Ceiling Fan control demonstration
  • Added new page 11 with one large, blank button for future use
  • Removed QR code from page 0 - again, a memory saving feature. WiFi setup QR is now a static picture object.
  • Upgraded to Nextion firmware 1.60 - latest release as of this writing
Home Assistant Automations
Nearly too many to list but here are the major points:
  • Full compatibility with Lovelace UI
  • Color ā€œthemeā€ support with pull-down list of included themes
  • Interactive color select UI
  • Font select UI for page select buttons
  • Icons added to several pages
  • New automations for HVAC control
  • New automations for Ceiling Fan control
  • General compatibility and code cleanup
ESP8266 code v0.40
  • Improvement in WiFi performance and stability by disabling power save modes
  • Updates to better utilize new QR image and icon fonts
  • Add support for haptic or audio feedback device, thanks @benmprojects!
  • Add backlight reset button in web UI
  • Updated ESP8266 Arduino core to 2.6.3
Home Assistant Update Procedure
Run the deployhasp.sh script to pull down the updated automations using one of the guides below:
Links for more HASP info
