HA version 0.65.5, errors with yeelight bulb light
Today i updated HA from version 0.56.2 to 0.65.5. After run it, i opened, web interface, and asked about my password. Once i intoruduced, web iu just is loading data, and that’s all, not enter.
here are my logs
2018-03-18 20:17:30 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 180, in _step
    result = coro.send(None)
  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 252, in _async_add_entity
    msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: automation.sensorpuertacerrado
    msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: automation.sensorpuertaabierto
    msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: automation.mama_llega_a_casa
2018-03-18 20:17:33 ERROR (MainThread) [homeassistant.components.binary_sensor] Error while setting up platform netatmo
  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 82, in async_setup
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 243, in result
    raise self._exception
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/src/app/homeassistant/components/binary_sensor/netatmo.py", line 75, in setup_platform
    if not data.get_camera_names():
  File "/usr/src/app/homeassistant/components/netatmo.py", line 84, in get_camera_names
    self.update()
  File "/usr/src/app/homeassistant/util/__init__.py", line 319, in wrapper
    result = method(*args, **kwargs)
  File "/usr/src/app/homeassistant/components/netatmo.py", line 115, in update
    self.camera_data = lnetatmo.CameraData(self.auth, size=100)
  File "/usr/local/lib/python3.6/site-packages/smart_home/Camera.py", line 78, in __init__
    self.default_camera = list(self.cameras[self.default_home].values())[0]
IndexError: list index out of range
2018-03-18 20:17:33 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform netatmo
    return fut.result()
  File "/usr/src/app/homeassistant/components/climate/netatmo.py", line 51, in setup_platform
    for module_name in data.get_module_names():
  File "/usr/src/app/homeassistant/components/climate/netatmo.py", line 165, in get_module_names
    for module in self.thermostatdata.modules[self.device].values():
KeyError: 'relay_T'
2018-03-18 20:17:43 ERROR (MainThread) [homeassistant.components.camera] Error while setting up platform netatmo
    return fut.result()
  File "/usr/src/app/homeassistant/components/camera/netatmo.py", line 42, in setup_platform
    for camera_name in data.get_camera_names():
    self.update()
2018-03-18 20:18:02 WARNING (SyncWorker_3) [netdisco.ssdp] Found malformed XML at http://192.168.1.99:9080: status=ok
2018-03-18 20:19:53 ERROR (MainThread) [homeassistant.loader] Unable to find component broadlink
2018-03-18 20:19:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/src/app/homeassistant/components/websocket_api.py", line 472, in get_services_helper
    descriptions = await async_get_all_descriptions(self.hass)
  File "/usr/src/app/homeassistant/helpers/service.py", line 152, in async_get_all_descriptions
    missing.add(domain_yaml_file(domain))
  File "/usr/src/app/homeassistant/helpers/service.py", line 131, in domain_yaml_file
    component_path = path.dirname(get_component(domain).__file__)
AttributeError: 'NoneType' object has no attribute '__file__'
2018-03-18 20:20:36 ERROR (MainThread) [homeassistant.loader] Unable to find component broadlink
2018-03-18 20:20:36 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
Any help?
thanks
Go check the change logs for breaking changes. You skipped lots of updates…
Thanks for reply. I solved this problem, and now works more or less all.
The problem that i have now, is with yeelight white bulbs and cover over mqtt.
With yeelight HA, makes the autodiscover, and detects all lights. when they are switched on, i can turn off, but when i want to turn on, switch turn on, but after 1 second, turn off automatically.
here logs when i did this option:
2018-03-27 16:04:44 WARNING (MainThread) [homeassistant.components.light] Setup of platform yeelight is taking over 10 seconds.
2018-03-27 16:16:26 ERROR (SyncWorker_5) [homeassistant.components.light.yeelight] Unable to turn the bulb on: {'code': -5000, 'message': 'general error'}
2018-03-27 16:16:32 ERROR (SyncWorker_6) [homeassistant.components.light.yeelight] Unable to turn the bulb on: {'code': -5000, 'message': 'general error'}
2018-03-27 16:16:37 ERROR (SyncWorker_11) [homeassistant.components.light.yeelight] Unable to turn the bulb on: {'code': -5000, 'message': 'general error'}
Anyone, have the same problem? Something changed?
Please update the firmware of your yeelights! HA 0.65.5 uses the most recent yeelight API. Old firmware versions doesn’t handle the new messages properly.
Solved.
After updated as @syssi told.
thanks
