My system became super unstable since I’ve updated to OS 7.2 a couple of days ago.
It works pretty well after each reboot, but then after a few minutes it becomes slow to the point it’s unusable, sometimes it takes several seconds to respond to an action (like turn on a light), sometimes I’m not even able to navigate on the web or phone app (it says it’s reconnecting many times).
System Health
version
core-2021.12.10
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.9.7
os_name
Linux
os_version
5.10.63-v8
arch
aarch64
timezone
Europe/Stockholm
Home Assistant Community Store
GitHub API
ok
Github API Calls Remaining
4422
Installed Version
1.20.0
Stage
running
Available Repositories
1012
Downloaded Repositories
48
Home Assistant Cloud
logged_in
true
subscription_expiration
20 February 2022, 01:00
relayer_connected
true
remote_enabled
false
remote_connected
false
alexa_enabled
true
google_enabled
true
remote_server
eu-west-2-4.ui.nabu.casa
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
Home Assistant Supervisor
host_os
Home Assistant OS 7.2
update_channel
stable
supervisor_version
supervisor-2021.12.2
docker_version
20.10.9
disk_total
57.8 GB
disk_used
15.7 GB
healthy
true
supported
true
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
Duck DNS (1.14.0), Let’s Encrypt (4.12.0), Studio Code Server (4.1.0), Home Assistant Google Drive Backup (0.105.2), NGINX Home Assistant SSL proxy (3.1.1), Signal Messenger (0.55.0), Eufy Security Add-on (0.7.0), RTSP Simple Server Add-on (v0.17.6)
Lovelace
dashboards
1
resources
41
views
11
mode
storage
Spotify
api_endpoint_reachable
ok
I cannot see anything unusual on the host statistics:
I’ve originally suspected of ZHA integration, as I’ve also installed this a few days ago, but the system still unreliable even after removing all Zigbee integrations.
I’ve rebooted the systems many times, removed everything that is not important, but no luck.
Seeing similar problems but not as severe. Overnight the z-wave seems to crap out. I have had to reboot every morning after the upgrade to get HA functioning again. I just installed watchman (HACS) and it found some issues (missing entities in automations etc) so will see tomorrow if that fixes it.
I had this same issue left week, after making the update to 7.2.
Each time a log was involved (add-ons, or supervisor), it would block main part of HA add-ons, in particular deconz or node red.
I even reverted to 7.1 but it did not correct.
It seems, in my case to have triggered ah issue with my SSD.
I applied the solution here
And now, no issue.
See if you have the same symptoms.
The whole story is on the French forum
I KNOW that some people here, will say, that what I am about say, “is really DUMB”. But I am going to say it any way! There are times, I have seen Issues Go away, after REBOOTing the whole system 2 or 3 times.
Not dumb, just your experience. The question is what is happening during the multiple reboots that is fixing the problem. Something hung in hardware that takes time to clear??? I wish I knew.
@AllHailJ I’m thinking, when we update the HA Core, on reboot, maybe an Add-ON or Intergration, doesn’t sync-up properly. So I would reboot the Core, and if that didn’t fix the issue, I would rebooot the HOST(the whole system). But, now it is just a habit, after HA reboots from the Core, I will force a reboot of the HOST.
Just an added note. the last time that I had to reimage the the system, was about 1 year ago. When my SD Card died. At that point, I replaced the SD Card with a SSD, and sofar, it all working nicely.
Into March and this still seems to be an issue. I am rebooting several times a day at this point. Trying to get logs has been difficult but will open a bug once I have something solid. Stability has gone way down unfortunately.
Sorry for the delay. Negative, things have definitely settled down. I never did track down the root cause but whatever it was seems to have stabalized.
