When using the Home Assistant web interface on mobile devices / devices with touch screens, you cannot pinch to zoom. This is just annoying and I am sure this is a really easy thing to fix.
This would be great, I use the camera component with a ZoneMinder server, the camera feeds load much quicker in HA than ZMninja and the pinch and zoom is the only thing stopping me using HA instead of ZMNinja to look at the Zoneminder camera feeds.
I noticed this as well and reverted back to 116 because of this and an issue with how markdown card is changed.
Pinch to zoom on mobile makes absolutely no sense to me whatsoever. On mobile the UI is tailored to fit the screen. I experienced zoom by double tapping some areas (like button cards with double_tap action) or when hold the phone and having accidental touch inputs with more than one finger. This totally ruins the experience on mobile.
Currently Iām back on 116 but I hope 118 will revert thisā¦
Why not use the option to increase page zoom within HA app? This way you can increase all content size by default. This is on iOS at least, not sure if itās on Android.
The pinch to zoom isnāt an issue per se btw. But double tapping to zoom is. You have to use two fingers to zoom out every time.
Iām not finding a zoom option in the android app. Iāve tried both pinch and taps. However zoom works with Chrome. I guess I wonāt be using the app.
Hi all, this should actually work on many browsers, or you can check the option in iOS app for example. But I noticed it didnāt work on Fully Kiosk Browser, for example. To fix that you can do the following:
Put this in a file called zoom-enable.js in your config/www folder
I would love this feature for the HA Android app. Pinch to zoom for cameras etc.
This functionality would essentialy render the āofficialā camera apps totally obsolete and I could do basically everything from Home Assistant!
