HA wont start since update to 80.2
After the update my homeassistant shows no web interface, i’ve enabled debug loggin and its repaeting the following
2018-10-20 15:30:53 DEBUG (MainThread) [hangups.event] Fired Event(‘Channel.on_receive_array’)
2018-10-20 15:30:55 DEBUG (SyncWorker_19) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-10-20 15:31:00 DEBUG (SyncWorker_19) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-10-20 15:31:05 DEBUG (SyncWorker_19) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-10-20 15:31:10 DEBUG (SyncWorker_19) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-10-20 15:31:15 DEBUG (SyncWorker_19) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-10-20 15:31:20 DEBUG (SyncWorker_19) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2018-10-20 15:31:20 DEBUG (Vera Poll Thread) [pyvera.subscribe] Poll returned
2018-10-20 15:31:20 DEBUG (Vera Poll Thread) [pyvera.subscribe] Event: Front Room double, state -1, {“altid”: “3”, “id”: “14”, “subcategory”: “3”, “room”: “2”, “parent”: “1”, “status”: “0”, “watts”: “0.0”, “kwh”: “0.8000”, “commFailure”: “0”, “light”: “0”, “state”: “-1”, “comment”: “”}
2018-10-20 15:31:21 DEBUG (Vera Poll Thread) [pyvera.subscribe] Polling for Vera changes
2018-10-20 15:31:21 DEBUG (Vera Poll Thread) [pyvera] get_changed_devices() requesting payload {‘timeout’: 30, ‘minimumdelay’: 200, ‘loadtime’: 1540044414, ‘dataversion’: 44414175, ‘id’: ‘lu_sdata’}
2018-10-20 15:31:22 DEBUG (MainThread) [hangups.channel] Received chunk: b’17\n[[7,[“noop”]\n]\n]\n’
2018-10-20 15:31:22 DEBUG (MainThread) [hangups.channel] Chunk contains data array with id 7: [‘noop’]
2018-10-20 15:31:22 DEBUG (MainThread) [hangups.event] Fired Event(‘Channel.on_receive_array’)
Did you go through? Especially the step where you make sure configuration.yaml is not the problem. You could also try to downgrade: How to downgrade versions .
I’ve only just mamanged to sort it by renaming the .storage and .cloud folders appending.old then re-registering, seems strange but upon restoring them the system will not start again
