Hello @nickrout i have the same issue if you could please try and help me?
fresh install of HA on a proxmox hypervisor using this
“wget -qLO - https://raw.githubusercontent.com/Kanga-Who/home-assistant/master/hassos_install.sh”
I have done updates to core and supervisor
core-2021.6.4
supervisor-2021.06.0
then I installed HACS via SSH’ing to my HA virtual machine and running
wget -q -O - https://install.hacs.xyz | bash -
I then rebooted the server
Then I go into Configuration → integrations → “add integration”
select HACS and after about 5 minutes of waiting on the pop up “please wait while the integration is being installed” I get the error pop up “Config flow could not be loaded”
logs only show the one message:
“2021-06-12 21:12:24 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant”
please help HA n00b here only set up this week for the 1st time and need HACS for my vacuum
