It is on my GitHub. Look for my username there and you will find it.
Looking at the examples under garage what does warn: 1 mean? I looked at the documentation but canāt find anything about it.
Does it work with Lovelace? Is there any caveats?
when you ask someone who hasnt been online for over a year you probably wont get an answer
but he was talking about HAdashboard which is a webpage and lovelace is also a webpage, so i dont see why it shouldnt work for lovelace.
Iād like to wake up this wonderful hadwshboard a bit ā¦even if itās now v3 bit here some screens:
Work in progress
Ideas welcome
Do you share your setup code somewhere? For me reading otherās code helps me a lot. I canāt have anough examples to shamelessly copy from
This is my current setup
then at least check out the default skins and see how they work.
https://gitea.ddns.net/thundergreen/Hadashboard
See here just pushed on my personal git instance
Where do you think does all this come from? But not every feature is documented, and sometimes not clear to me. So seeing it āreal liveā is always big help.
seems to me that you just use the default skin.
but i meant āzen, obsidian, simplyred,etcā
if you come accros something that isnt documenred, please mention it to me.
we try to keep the docs as complete as possible.
if a feature isnt clear enough explained you can also ask me, maybe i can improve the docs based on that.
@ReneTode. Thatās correct. Iāve had a look at the other skins, but they all look, well not too good to me, to say at least I really prefer the clean look of the default skin which looks totally nice to me.
To give an example of where i struggle atm: There are widgets developed here, that find (or donāt find) the way to the release. Itās hard for me to say where we stand here.
Letās say the weather widget.
I found this here:
My setup now looks like the default one, but i donāt know where to set ādefault, OP, narrow, wide ā¦ configā. So i look up the docs here https://appdaemon.readthedocs.io/en/latest/DASHBOARD_CREATION.html# and try to find the settings i need. But i canāt find them. This doesnāt mean that they arenāt there, but just that there are not obvious for me
there is no policy about which widgets will make it into AD, except that most custom widgets wont make it.
there are a few widgets still on the to do list (input text, etc).
there is a plan to create a collection where people can upload their custom widgets. but its still a plan.
the weather widget is 1 that gets manipulated most.
the default widget has its settings here:
https://appdaemon.readthedocs.io/en/latest/DASHBOARD_CREATION.html#weather
OP is probably customised by someone (so a custom widget)
narrow and wide seem to me a weather summary, that use (2x1) or (1x2) from size
iām no real fan from default, because it is way to āthat what every one else has, and what you can create with other programsā but thats taste i like it different.
Can u give me a small hint how to make light sliders?
Sehr nice btw
off course i can.
i did even write it down
Just a small write up how to get this running would be nice too donāt know exactly where to startā¦ would also like to implement the color picker
its not new (i didnt change anything in it for 7 months)
how about the readme.md?
it says exactly what you need to do to implement it.
read it line by line (not just the picture and the last line )
Unable to get into your custom_css directory for some reason. Maybe it didnāt finish? Would really like to see how you created your custom hadashboard screens. Thanks!
