Hadashboard V2 Competition
updated the dark_flower github files to fix my hard coded clock font sizing so it should display better for those not using a 3x2 clock widget. I then just used the date_style and time_style config items on the clock widget to set my preferred font size.
where is the rain sensor in dark sky?
Hey your designs are really awesome! Thanks for sharing.
Can you share how to get the news section into the design.
and how did you got the bulb into the slider?
I also would like to show an task or shopping list - is this possible?
kind regards
Sascha
I donā€™t get values shown when I try to access from outside my local network
U can maybe add Google calendar for shopping list as sensor ā€¦ this is what Iā€™d try
outside lan isnt supported in this version.
it is on the development list for after beta.
Thanks! The news section is some custom jquery i wrote to display news from my local newspaper. I posted the code link/info in the beta2 forum but it most likely wonā€™t work for any source and would have to be adjusted. With that said I believe aimc is working to get something similar added into beta3.
The bulb is just a different icon loaded via the widget definition, I believe the beta docs specify how to change the icons.
Here some screenies:
Why dont i see the icon:
this is my config:
lamp_sleeping_room:
  widget_type: light
  title: Lamp
  title2: Sleeping Room
  entity: light.color_lamp_sleeping_room
  icon_on: lightbulb-on-outline
  icon_off: lightbulb-outline
icon should start with fa- or with mdi-
thanksā€¦ figured it out :slight_smile:
Jeez thatā€™s not fair - whoā€™s gonna beat that?
Does this mean you canā€™t use other icons? eg icon files on your own system.
As far as I know u have no choice to use own icons. Please someone correct me if Iā€™m wrong !
U like the skin? Will upload it and u can use it :wink:
at this moment you can use the FA icons and the MDI icons.
Andrew has in his to do list to create the option to use your own icons in a future version.
Neat idea using round buttons!
Thanksā€¦Playing around with design .Wanna create an awesome skinā€¦Unfortunately u must configure widgets directly in dashboard itself instead of variables
