you can change the css file from your skin if you want to change all widgets as well as the variables file.
configuring widgets on widget level in the dash is only when you want to set individual settings.
All, here is another that I quickly put together after an image i stumbled across on google images for a star wars ios app. Still working on colors a bit though.
great work but less is more i think one questions⌠would you mind telling me how to make the white edges of your widges? thaâs awesome! And how can i make those great different colors for them?
Thanks! Just adjusting the colors for the icons, so far happy with the blue, red, white and green blocks. Here is the CSS code to get the white corners:
li:before
display: block;
content: "";
width: 5px;
height: 5px;
position: absolute;
top: 0px;
left: 0px;
border-top: 1px solid #fff;
border-left: 1px solid #fff;
z-index: 999;
li:after
display: block;
content: "";
width: 5px;
height: 5px;
position: absolute;
top: 0px;
right: 0px;
border-right: 1px solid #fff;
z-index: 999;
.widget:before
display: block;
content: "";
width: 5px;
height: 5px;
position: absolute;
bottom: 0px;
left: 0px;
border-bottom: 1px solid #fff;
z-index: 999;
.widget:after
display: block;
content: "";
width: 5px;
height: 5px;
position: absolute;
bottom: 0px;
right: 0px;
z-index: 999;
Block colors are defined in variables.yaml, then on the individual widgets the widget_style line is used to target the variable. You can see it in action on github in my clear-sky and dark-flower skins.
sorry but i dont find wich file
The CSS code would go in the dashboard.css file, making sure that any of the same name are removed.
Here is one of the skin github pages and you can see the color background variables in the variables.yaml file:
Can anyone tell the exact path as i am not able to load the skins.
do we have to put any entry in dashboard.dash file also.
it seems like you have it placed at the right place.
you should be able to use your skin by:
Is your skin/dashboard free to download somewhere? I just started with hadashboard and need a solid starting point
uhh, found the examples in âŚ/conf/example_dashboards! Letâs play around!
You can always copy one of the skins I designed for the beta over to the custom_css folder, rename it and use that as a starting point too.
Got it working. Thanks.
Thanks, after some stumbling around I found the folder for skins. CSS hacking should be ok for me. Iâll have a look into the example_dashboards and the DASHBOARD.md to learn how to setup dashboards.
Just remember to always work on a copy of the existing skins in custom_css rather than on a skin directly.
Otherwise you will prevent your updates from git to work correctly.
I have been pretty busy the last week and am still hoping to get back to it and adjust some of the active/inactive icons to fit a bit better. I will try to post what I have on github today (without the wanted adjustments). I will post the the link here.
My skins are located here:
pi@homeautomation:~/.homeassistant/appdaemon_dashboard/appdaemon/conf/custom_css/
Is this the wrong place?
The readme (DASHBOARD.md) states:
Start off by creating a directory called
custom_css
in the configuration directory, at the same level as your dashboards directory. Next, create a subdirectory incustom_css
named for your skin.
I start appdaemon with:
ExecStart=/usr/bin/python3 -m appdaemon.appdaemon -c /home/pi/.homeassistant/appdaemon_dashboard/appdaemon/conf/
Thatâs the relevant part of /etc/systemd/system/appdaemon.service
In the same directory is appdaemon.conf lying around and my âdashboardsâ directory too. Permissions are set ok.
Am I wrong? Syslog yells
python3[7001]: 2017-03-20 21:43:58.427284 WARNING Skin âtestâ does not exist
If I copy custom_css to ~./homeassistant/ it all works. But thatâs not what the readme told me
@linuxlurak Here is the link to the âdeathstarâ skin. Please be sure to read the readme file:
Where can I find documentation to change sizes of text, icons etc. for specific âCardsâ? Currently im working on an example of a different widget but some properties dont work, so maybe a readthrough would help alot
Thanks a lot @lordsiris. Is there something special in the readme file? Or why the special hint? cheers!
