Updating SBFspot from 2022.10.2 to 2022.10.3 failed with the following error message:
Pulled image Package aarch64-addon-haos-sbfspot · GitHub failed on content-trust verification!
Any suggestions?
Any suggestions?
Hi @Ghs
I hadn’t seen this post, @tropfen alerted me to it.
The problem is I created a bug trying to sign the addon with codenotary. It doesn’t seem to like multi layer addons.
If you had it installed, it updated the previous version, however I had to remove the signing to allow new installs… Which means you can’t update from signed to unsigned…
The solution is:
Copy your haos-sbfspot options
uninstall the old version of haos-sbfspot
install the new version of haos-sbfspot
Paste your options back in.
(technically the base image is still signed).
Thanks, that worked. I am on 2022.10.3 now.
