I was trying to install HACS and I have having the issue of downloading the the HACS install zip. I had to add the google (8.8.8.8) namserver to the /etc/resolv.conf file, and I was able to download the zip. Then I had the issue of authenticating with github. Every time I try to authenticate, it says:
To confirm this isn’t an issue with HACS, I also tried installing the github integration, and the same issue occurs. I see the following error messages in the log.
2023-12-09 22:16:45.070 ERROR (MainThread) [custom_components.hacs] Request exception for 'https://github.com/login/device/code' with - Cannot connect to host github.com:443 ssl:default [Try again]
2023-12-09 22:16:59.905 ERROR (MainThread) [homeassistant.components.github] Request exception for 'https://github.com/login/device/code' with - Cannot connect to host github.com:443 ssl:default [Try again]
Here’s my system information.
| Version | core-2023.12.1 |
| Installation Type | Home Assistant OS |
| Development | false |
| Supervisor | true |
| Docker | true |
| User | root |
| Virtual Environment | false |
| Python Version | 3.11.6 |
| Operating System Family | Linux |
| Operating System Version | 6.1.63-haos |
| CPU Architecture | x86_64 |
| Configuration Directory | /config |
I’ve been looking for solutions to this across the the community pages, github and on reddit and I’ve found people facing similar issues, but no clear way to solve it.
I can ping github.com and get a response, but it I ping github.com/login/device/code, I get the following:
ping: bad address 'github.com/login/device/code'
I followed the comment by kheno in this link, but it did not solve my issues.
I do have a pihole as my local dns, but even if I disable blocking (or turn it off entirely), it seems to have no effect on home assistant.
The only other source I found was this: HACS - Communication issue? - Could not authenticate with GitHub - #3 by Segullah
and while I used balena etcher to write my HAOS onto my NUC, it didn’t lag at 31%, so I don’t think this is an issue that applies to me?
Anyone have any ideas of something else I could try?
