I think you’ll have to look up the custom button for Lovelace. It allows buttons that can be sized without text (icon only).
If I have no network enabled Receiver connected to Harmony, how would I send volume up/down commands to it through some nicer UI, like switch or something?
I am able to do this from script, like below, but how do I integrate it to something nicer?
reciever_volume_up:
alias: Volume up
sequence:
service: remote.send_command
entity_id: remote.living_room
command:
- VolumeUp
device: 59394436
you can call the script from a button. You won’t be able to make a slider if you don’t have a way of knowing the current volume level. So your only option with harmony is to repeat commands. I.E. call the volume up command 5 times.
Yes, sure, I understand it, I only control the Receiver through IR, so no slider of course.
I don’t even need 5 to repeat, 1 is enough.
I was able to create the scripts and add them to group, which is fine and working (see the screen), however this “EXECUTE” does not look good. If I could somehow put all 3 of them on one row/switch and customize each with an icon, that would be much better. And I could not find a way to define any working switch template for that.
You can’t do anything else unless you use Lovelace. Unfortunately you are limited with the native UI unless you use custom UI.
I might have a solution to your problem. I also don’t have a network controlled receiver yet and have been using this as a workaround in the meantime. It’s not perfect but it does look nicer than using scripts on the frontend.
What I did was created an input_number like so…
denon_volume:
initial: 5
min: 0
max: 10
step: 5
mode: slider
Then I created two automations; one that when the slider is moved up it turns the volume up and then resets the slider back to the middle position. Then another automation that does the opposite like so…
- id: denon_vol_down
alias: Denon Volume Down
platform: state
entity_id: input_number.denon_volume
to: '0.0'
- service: input_number.set_value
value: '5.0'
- service: remote.send_command
device: '46571740'
command: 'VolumeDown'
num_repeats: '10'
- id: denon_vol_up
alias: Denon Volume Up
platform: state
to: '10.0'
value: '5.0'
device: '46571740'
command: 'VolumeUp'
num_repeats: '10'
Thanks!
Well, I have used the glance card for that in lovelace ui and that sort of made it look better as well.
Hi petro, is it possible for a link to the png images, going to have a go at this later and have nearly the same setup, even the amp. Many thanks, this looks great!
Yes, here they are
Many thanks, will be working on this tonight!
I’ve been using this card: Lovelace: Button card
to create this:
And this is the corresponding code in ui-lovelace.yaml:
- title: Radio
icon: mdi:radio
cards:
- type: vertical-stack
cards:
- type: "custom:button-card"
style:
# - color: rgb(44, 109, 214)
- font-size: 19px
# - font-weight: bold
- type: horizontal-stack
cards:
color_type: icon
color_off: rgb(44, 109, 214)
icon: attribute
entity: script.radio_10
color_type: icon
icon: attribute
entity: script.radio_sky
cards:
color_type: icon
icon: attribute
entity: script.radio_npo3
color_type: icon
icon: attribute
entity: script.radio_frl
- type: entities
title: Volume
show_header_toggle: false
entities:
- input_number.slider1
cards:
entity: script.receiver_volume_up
color_type: icon
icon: mdi:volume-plus
color_type: icon
icon: mdi:volume-minus
entity: script.receiver_volume_down
color_type: icon
icon: attribute
entity: script.radio_off
This is such a great documentation. Thanks for that! I have one question regarding the receiver switches. I have an activity on my harmony called “Listen to Music”. Obviously it only turns on the receiver. From looking at the code it seems the switch status and the volume sliders are only displayed correct if the status of the receiver is “on”. But when only listening to music it is either “idle” or “playing”. I did not manage to adapt the code respectively and I’d be happy about some help. Thanks folks.
Hm okay. It was so much easier than expected… Just didn’t realize I need to restart HA in order for switch.yaml changes to take effect. It is a simple ‘or’ like this:
"{{ is_state('media_player.yamaha_receiver_family_room', 'on') or is_state('media_player.yamaha_receiver_family_room', 'idle') or is_state('media_player.yamaha_receiver_family_room', 'playing') }}"
I was able to get this up and running but not 100% (but enough to where i have the activity displaying and working), is there any way to make the image stand out more? it’s kind of hard to see for my “music” activity
on the far right there is a speaker but it’s really faint
I think the only way to make it stand out more is to use a custom theme, adjust the background color, or possibly use the card modder (a custom card).
Same colors w/ black background
Update: I see I have the same idea as sMauldaeschle
I found a small improvement for the volume slider, this removes an error from the HA log when the receiver is turned off. Use:
condition:
condition: and
conditions:
- condition: template
value_template: "{{ not states.media_player.receiver.state == 'off' }}"
value_template: "{{ not is_state_attr('media_player.receiver', 'volume_level', states('input_number.slider1') | int / 100) }}"
Instead of:
condition:
Adapt the names, etc. as used in your system.
Could you elaborate on this a bit please?
How do you show what you’re doing on Xbox, all I see with the Xbox component is online or offline?
Mine does, it will say what app / game is being played.
yep, you’re right, its one of the sensor attributes.
my bad
No biggie. I actually don’t really enjoy the component to be honest. I just implemented it to see what it was like. I always reach the max api limit and it doesn’t update fast enough without requiring payment.
