Managed to get HA to detect my harmony hub and it created the config files , i then test and could get HA to control the harmony hub.
Since then HA has never managed to detect the hub again (logs indicate its taking to long so gives up), can i force HA to load the harmony hub even though it doesnt think it can find it ?
Thanks used that to help me setup in the first place.
Problem i have is that although it detected once (and tested and fully working), it hasn’t detected since , which i guess means it hasn’t loaded the interface needed to talk to the hub
no you do not, do you have anything new on your network like maybe a new router or something that is not allowing it to connect? Is it on a separate vlan or something?
i strongly suspect the problem is the HUB not the HA install as have always found harmony to be flakey , router is dualband 2.4 and 5GHZ (no network isolation)
I have another PI running HarmonHubControl which sits on wifi and that can control harmony hub
very frustrating as starting to see the potential of HA but control of harmony hub central to my requirments
hmm maybe try a factory reset on your harmony hub and restore the settings? i have 2 hubs that get detected just fine. both are only paired to 2.4 ghz and very close to the router.
haha yea harmony in general can be a pain…i have an issue where sometimes my remotes dont work…this morning my harmony keyboard lost parts of its configuration and certain keys were not working lol
I had a similar issue whe I first started using HA and was still getting to grips with everything. What I ended up doing was discovery set up the one it found then the one I manually configured but named slightly differently (because I thought it wasn’t found again) created a second but because they had the same up address there was a conflict.
When you say the page to interact with the hub doesnt appear what do you mean? What appears in the list of entities under remote.harmonyhubname?
I think you are right some of the problem is that i am still trying to understand exactly how this all works
when i started , my hue was discovered automatically and configured itself, i added my Yamaha amp manualy and that worked no problems. Then added kodi box which also worked ok
With my harmony hub i couldn’t get it to work, then randomly on a reboot, it picked up the hub, created the config file harmony_xxx.conf. I realised it had worked as it created an entry in the overview tab. I then tested it using the developer tool service and could send a command to the hub and could see it was working fine.
Once i rebooted again the harmony hub doesn’t appear on the overview tab and although it still appears in the developer tools (services) any commands send to it dont work
i have the following entry in configuration.yaml
remote:
platform: harmony
name: XXXXXX (have x out the real hub name)
host: 192.168.0.20
If you have the hub in auto discovery you don’t need anything in the config.yaml. If you want to configure it manually make sure you exclude it from auto discovery - that’s how I ended up with 2 hubs. Also make sure if you do configure manually you use exaclty the same hub name you defined in the harmony app.
I think you also have to delete the harmony_your_hub_.conf file to force rediscovery.
Remove your manual config and turn auto discovery off delete the harmony.conf file plus any other references in groups or customize yaml files. Restart home assistant. Then re enable auto discovery and restart home assistant. Hopefully the conf file will reappear as harmony_name_of_your_hub.conf which means it has auto discovered it again. Also you will need to add remote.your_harmony_hub to the front end via groups but no need for any manual changes in config file.
