Harmony Hub in 2019
New here…does the Logitec Harmony Hub still work with Home Assistant out of the box? Or is a downgrade still required as per below?
https://www.reddit.com/r/homeassistant/comments/a6u6ep/psa_harmony_hub_firmware_v415206_breaksremoves/
Cheers,
Dan
It’s fixed with a new firmware where you can enable XMPP support (developer mode):
Even without that the integration works, it just uses the code that was created when xmpp was no longer available.
I hesitate to use the phrase ‘out of the box’ though, it’ll work but won’t do much without some config at the ha end to control whatever you configure the harmony remote to do. That can be reasonably simple or as complex as you like.
