remote.harmony_hub the name of the harmony hub entity
devices
Array
Optional
a list of devices to add custom commands to. See below for more info.
activities
Array
Optional
a list of activities. Note this will override the default activities shown
vibrate
Boolean
Optional
true vibrate on button push
showPad
Boolean
Optional
true show D-Pad
leftPad
String
Optional
DirectionLeft command sent for the left pad
rightPad
String
Optional
DirectionRight command sent for the right pad
upPad
String
Optional
DirectionUp command sent for the up pad
downPad
String
Optional
DirectionDown command sent for the down pad
centerPad
String
Optional
OK command sent for the center pad
devices Options:
Name
Type
Requirement
Description
name
string
Required
the name of the device you want custom commands on
commands
string
Required
the name of the command in your harmony.conf file for this device. Can be a simple list or a list of objects with name and command properties. Can also be a service call with service, domain, data options
icon
string
Optional
show an icon for the device
hide_name
boolean
Optional
hide the name of the device
activites Options:
Name
Type
Requirement
Description
activity
string
Required
the name of the activity. Must match the exact name in the harmony.conf file
name
string
Optional
custom name of the activity
icon
string
Optional
show an icon for the activity
hide_name
boolean
Optional
hide the name of the activity
entity
string
Optional
set the entity name for the activity
commands Options:
Name
Type
Requirement
Description
name
string
Required
the custom name of the command
icon
string
Optional
show an icon for the command
hide_name
boolean
Optional
hide the name of the command
command
string
Optional
the name of the command in your harmony.conf file.
service
string
Optional
the name of the service call
domain
string
Optional
the domain of the service call
data
object
Optional
the data for the service call
Example config:
type: custom:harmony-remote-card
entity: remote.harmony_hub
activities:
- activity: PC
icon: mdi:laptop
hide_icon: true
- activity: XBox
- activity: PS5
- activity: Shield
devices:
- name: Media Room Shield
commands:
- Mute
- Home
- name: Power Off
command: PowerOff
- name: LG TV
icon: mdi:television
hide_icon: true
commands:
- Mute
- Info
- name: InputHdmi1
command: InputHdmi1
show_pad: false
- name: Denon AV Receiver
commands:
- Mute
- Info
- InputTVAudio
- InputGame
- name: Volume Down
command: VolumeDown
- name: Volume Up
command: VolumeUp
- name: Lights
service: toggle
domain: lights
- entity_id: light.main_lights
Fairly new to Home Assistant. Have installed via HACS, how would I switch my one and only āWATCH TVā activity? Which card in Lovelace dashboards do I use and how would I code it? I donāt need it to do anything other than run the activity.
I donāt know why the card isnāt showing in HACS. However, if all you need to do is stop / start the activity
then you donāt need any custom cards as many of the built-in cards can be used. Th simplest way is to enable that switch youāve got configured, then you can put it in an entities card, or button card, or glance card.
Iāve added this through HACS and it is showing in the HACS list of Frontend add-ons.
Iāve also checked and the files have been downloaded to config/www/community/harmony-remote-card
When I try to use it though it doesnāt appear in the list of cards when trying to edit the dashboard, and if I try to enter the code manually it says, āCustom element does not existā.
(Iāve tried both custom:harmony-hub-card as per the example on Github and also custom:harmony-remote-card as per the docs).
For me, the situation was: i installed the card through HACS, it was showing in the list of cards in HACS Front End-section. But when editing a dashboard, it did not show in the list of available cards. I restarted my HA-instance, which did not solve the problem. But i switch of (with a smart plug) my settop-box (and harmony hub) during the night & day-until-the-afternoon: as soon as i powered the hub and the Harmony finished booting, HA showed the status of the Harmony Hub entity online and the card i added manually (so: edit dashboard, add card, at the bottom there is a manual option, paste the example config from the developer (using the entity name of your hub) āsprang to liveā/populated.
Having the same issue as tk3, Activities work, but individual commands do not. Have tried with and without command names as shown in example. Can also manually send command with no issues. Much prefer your layout and would like to get it working.
devices:
- name: Family Room TV
commands:
- name: HDMI 1
command: InputHdmi1
- name: Surround Sound
commands:
- name: Volume Up
command: VolumeUp
- name: Volume Down
command: VolumeDown
- name: HDMI 1
command: InputHdmi1
Have also tried with various quotes just in case. No dice. Logs error Harmony hub: Missing required argument: device. Tried adding id: from Harmony config, no dice.
What is the logic behind the order in which devices and activities are showing in the card. I thought it might be the order they are in the Harmony.conf-file in HA, but thatās not it. Doesnāt seem to be the id of the device/activity in that file either⦠Would be nice if we could manage the order in which activities and devices are shown on the cardā¦
@ t3k,@ sadsephiroth, @ psawerf
found a solution:
-open file āharmony-remote-card.jsā in Folder www\community\harmony-remote-card\ in an Texteditor
-Scroll to the End of the file, line 8844
-Replace: data: { command: e, device: n.device },
with: data: { command: e, device: n },
so remove the ā.deviceā
-not sure if necessary: delete file harmony-remote-card.js.gz in the same folder
-restart HA
-delete Cache in your Browser
-delete Cache on your Mobile HA App if you are using it
@ ljmerza
can you please check this on your end?
And many Thanks for this Card
Please really ensure that the Cache of the Browser was cleared and everything was new transfered from for HA Server.
You can check this with your Browser.
Click on the Button F12, then the Dev Tools are openend.
Here you should have the possiblilty to see all loaded scripts and the content of the Scripts:
Ah ok think Iāve identified the issue which is slightly different. I was testing using the activity āTV (Humax)ā when the device buttons were not responding. But it you look at the image below, although Iām actual using āTV (Humax)ā, its not highlighted on the HA card as being the current activity (its highlighted the Amazon Fire TV Stick device). When I selected the āFirestickā activity, the buttons worked (and the āFirestickā activity was highlighted). So looks like for some reason when Iām using the āTV (Humax)ā activity maybe HA / card doesnt know so isnt sending the right commands?
