activityEntity: select.harmony_hub_activities
activities:
- activity: OTA
- activity: Watch Roku
You need to add the activityEntity: select.harmony_hub_activities.
activities:
Yes, that did it, thank you!
I second the suggestion to add this to the first post and example config.
Thanks again.
It did in the images I posted, good catch, but I corrected that soon after. I was missing the activityEntity line.
Hi all, I am new with Home Assistant and want to get started with these harmony remote cards.
I have searched and searched again but I can’t figure out where to begin.
In what config file do I add info and how can I get the card to add to my dashboard.
I hope someone can help get started with this.
Thanks.
Hi. In your HA, go to the dashboard/view you want the card to be on, choose Edit (dashboard) at top right, choose Add card at bottom right, choose ‘Manual’ (card) (at the bottom), paste in the code at the top of this thread and go from there…
In case you need more help, maybe share specifics about versions etc of HA and your remote.
Okay, that simple .
I will go and work with that and if I need more help I will come back here.
Thanks a lot.
Hi there, new to HA but I got this to work quite well with all my devices.
The only thing I don’t seem to get to work is the OK command.
It’s in the config and to be sure I also added an extra ok button to my TV configuration in which I tried other confirmation terms like “enter” and “confirm” and things like “ok_key” etc.
I just can’t seem to get it to work, and as someone else stated earlier the Hub isn’t responding to the commands either.
I hope someone can help.
Do you have a line with ‘showPad: true’, or show_Pad? In this thread you can read about a plan to change it to show_Pad, but for now, my config (the yaml for the card in the UI) reads showPad, and this works for me.
I did have a line with show_Pad: somewhere.
I’ve now changed it to showPad: true and added the line to all installations.
I did see another line in the thread you linked (that included a term that I hadn’t tried)
showPad: true
**centerPad: Select**
I’ve added this to the sctript and I’ll try them when I get home later.
Thanks for the help so far, I’ll report again with news.
[edit]
Ì did a definitive test, works like a charm!
Adding my current script (Still WiP) so it may help others.
type: custom:harmony-remote-card
entity: remote.harmony_hub
showPad: true
centerPad: select
activities:
- activity: Tv kijken
icon: mdi:television
- activity: Een film kijken
icon: mdi:audio-video
devices:
- name: Samsung Tv
friendly_name: TV
commands:
- name: Menu
command: SmartHub
- name: Source
command: source
- name: Back
command: return
- name: Exit
command: exit
- name: Ziggo Box
command: InputHdmi1
- name: PS5
command: InputHdmi2
icon: mdi:sony-playstation
- name: AVR
command: InputHdmi3
icon: mdi:speaker
- name: null
hide_name: true
- name: Play
hide_name: true
command: play
icon: mdi:play
- name: Pause
hide_name: true
command: pause
icon: mdi:pause
- name: Stop
hide_name: true
command: stop
icon: mdi:stop
- name: null
hide_name: true
- name: Rewind
hide_name: true
command: rewind
icon: mdi:rewind
- name: Skipback
hide_name: true
command: skipbackward
icon: mdi:skip-backward
- name: SkipForward
hide_name: true
command: skipforward
icon: mdi:skip-forward
- name: FForward
hide_name: true
command: fastforward
icon: mdi:fast-forward
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- name: CH
command: channelDown
icon: mdi:menu-down
- 9
- 0
- name: CH
command: channelUp
icon: mdi:menu-up
- name: Volume Down
hide_name: true
command: VolumeDown
icon: mdi:volume-minus
- name: Mute
hide_name: true
command: mute
icon: mdi:volume-mute
- name: Volume Up
hide_name: true
command: VolumeUp
icon: mdi:volume-plus
- name: Ziggo DVR
friendly_name: Ziggo Box
icon: mdi:play-network
commands:
- name: Home
command: home
- name: TV Gids
command: Guide
- Menu
- Info
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- name: CH
icon: mdi:menu-down
- 9
- 0
- name: CH
command: channelUp
icon: mdi:menu-up
- name: Play
hide_name: true
command: play
icon: mdi:play
- name: Pause
hide_name: true
command: pause
icon: mdi:pause
- name: Stop
hide_name: true
command: stop
icon: mdi:stop
- Back
- name: Denon AV-ontvanger
friendly_name: Versterker
icon: mdi:speaker
commands:
- name: Xbox
command: inputDVD
- name: Blu Ray
command: inputBlu-ray
- name: Switch
command: inputMediaplayer
- name: TV
command: inputTVAudio
- name: Volume Down
hide_name: true
command: VolumeDown
- name: Mute
hide_name: true
command: mute
- name: Volume Up
hide_name: true
command: VolumeUp
- name: Panasonic Blu-ray Player
friendly_name: DVD Speler
icon: mdi:play-box
commands:
- name: Power
hide_name: true
command: PowerToggle
icon: mdi:power
- name: Home
hide_name: true
command: home
icon: mdi:home
- Menu
- name: Top
command: top
- name: Play
hide_name: true
command: play
icon: mdi:play
- name: Pause
hide_name: true
command: pause
icon: mdi:pause
- name: Stop
hide_name: true
command: stop
icon: mdi:stop
- name: Eject
hide_name: true
command: eject
icon: mdi:eject
- name: Skipback
hide_name: true
- name: SkipForward
hide_name: true
- name: Rewind
hide_name: true
command: rewind
icon: mdi:rewind
- name: FForward
hide_name: true
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 0
Hi, me again.
Now with a question of a cosmetic nature.
Is it possible to hide buttons or create spacing between them?
Right now I placed some empty buttons to get a good layout on the dashboard which hosts the remote, but I wonder if it’s possible to place lines laid out as the volume buttons at the bottom.
Hello everyone,
i am very new here and i am stuck. i have the following code
centerPad: select
showPad: false
activities:
- activity: Fernsehen
- activity: Apple TV sehen
name: Apple TV sehen
and this is what i get
What am I doing wrong?
Can anyone help me?
Did you carefully read the top post, all options, and check out the example config at Harmony Remote Card ? Is what is shown in the picture you share, all your config for the Harmony card? If so, seems you’re missing stuff, see sample config in top post. Also take not where ‘harmony_xxxxxx.conf’ is mentioned in that 1st post: you need to check out that file which should be in your HA-root, since what you add in the yaml config of the card needs to correspond to what is present in the harmony_xxxxx.conf file
Hi, I hope I have read everything and inserted it accordingly.
here is my new code - the devices are displayed, but the activities are not:
activities:
devices:
- name: Amazon Fire TV
commands:
- Menu
- Back
- name: Apple TV
commands:
- Menu
- Back
- name: Panasonic-Fernseher
commands:
- Mute
- Menu
- Back
- name: HDMI 1
command: InputHdmi1
- name: HDMI 2
command: InputHdmi2
- name: HDMI 3
command: InputHdmi3
showPad: false
centerPad: select
Screenshot:
and here the code of the harmony_11975725.conf:
"Activities": {
"-1": "PowerOff",
"51004413": "Fernsehen",
"51007044": "Apple TV sehen"
I can’t find the error.
Not sure, but fyi my harmony…conf: (can’t get indention right, but for you idea)
“Activities”: {
“-1”: “PowerOff”,
“30885419”: “Living lights on”,
“40545999”: “WatchTV”,
“40546052”: “Netflix etc”,
“47798256”: “Youtube”,
“50987994”: “TV on only”
“Devices”: {
“Arris DVR”: {
“commands”: [
“PowerToggle”,
“0”,
“1”,
snipped for readability…
“SlowPrev”,
“Start”,
“Time”
“id”: “50956617”
So i wonder why your harmony…conf is that short and doesn’t contain commands.
Maybe you can try to delete your harmony…conf file and rebooting HA (real proper reboot, not the quick ones), just like someone with a similar sounding problem here
Sorry, I just sent you an extract. My conf file looks like yours above with activities, devices etc.
The part with the devices does work, but the activities are not displayed - only an “off”-Button.
Did you already try to reboot HA (again, not one of the quick 2 quick reboot options, but a proper reboot) and see if that changes anything?
Yes, but the problem still exists.
Sorry to hear. I’ve run out of ideas, hope someone else will step in and try to make it work for you…
