I am having a problem with activities. I can’t see them on the remote.
I can see the devices and commands.
I am on v2.0.11.
Here is a shortened config:
You did see this note (see post at top of this thread): “activity string Required the name of the activity. Must match the exact name in the harmony.conf file” ? Does it match?
I have a problem with the centerPad entry.
5 of the 6 activities (devices) have OK commands, and they work.
The Watch TV activity device is a Dish Network Hopper 3.
I has a Select command, but not an OK.
Is there a way around that?
Hi all, I am new with Home Assistant and want to get started with these harmony remote cards.
I have searched and searched again but I can’t figure out where to begin.
In what config file do I add info and how can I get the card to add to my dashboard.
Hi. In your HA, go to the dashboard/view you want the card to be on, choose Edit (dashboard) at top right, choose Add card at bottom right, choose ‘Manual’ (card) (at the bottom), paste in the code at the top of this thread and go from there…
In case you need more help, maybe share specifics about versions etc of HA and your remote.
Hi there, new to HA but I got this to work quite well with all my devices.
The only thing I don’t seem to get to work is the OK command.
It’s in the config and to be sure I also added an extra ok button to my TV configuration in which I tried other confirmation terms like “enter” and “confirm” and things like “ok_key” etc.
I just can’t seem to get it to work, and as someone else stated earlier the Hub isn’t responding to the commands either.
Do you have a line with ‘showPad: true’, or show_Pad? In this thread you can read about a plan to change it to show_Pad, but for now, my config (the yaml for the card in the UI) reads showPad, and this works for me.
Now with a question of a cosmetic nature.
Is it possible to hide buttons or create spacing between them?
Right now I placed some empty buttons to get a good layout on the dashboard which hosts the remote, but I wonder if it’s possible to place lines laid out as the volume buttons at the bottom.
