Has anyone got a Sonoff Mini Code that you could share?
Hi
I have been able to OTA the new Sonoff Mini with ESPhome. I have just done the minimal to have it appear online and connected to HA.
https://www.itead.cc/sonoff-mini.html
I would like to have it as a switch, would anyone have a code they could share so I can test it further. I have other Sonoff Basics but I am unsure of GPIO pins etc.
Thanks in Advance.
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "NoT_WIFI"
  password: "Notpassword"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
If no one replies you can decode the GPIO from the Tasmota template:
{"NAME":"Sonoff Mini","GPIO":[17,0,0,0,9,0,0,0,21,56,0,0,255],"FLAG":0,"BASE":1}
Thanks Tom
I got it working 80% with your suggestions.
The sonoff mini works as a switch, I just need to work out the code to have it toggle rather than switch on/off
[18:28:28][C][api:104]:   Address: sonoff_mini.local:6053
[18:28:34][D][binary_sensor:033]: 'Sonoff Mini Switch': Sending state ON
[18:28:34][D][switch:029]: 'Sonoff Mini relay' Toggling OFF.
[18:28:34][D][switch:045]: 'Sonoff Mini relay': Sending state OFF
[18:28:42][D][binary_sensor:033]: 'Sonoff Mini Switch': Sending state OFF
[18:28:44][D][binary_sensor:033]: 'Sonoff Mini Switch': Sending state ON
[18:28:44][D][switch:029]: 'Sonoff Mini relay' Toggling ON.
[18:28:44][D][switch:045]: 'Sonoff Mini relay': Sending state ON
[18:28:49][D][binary_sensor:033]: 'Sonoff Mini Switch': Sending state OFF
Share the… code
toggle is a standard home assistant function.
After update the firmaware with esphome the 3-function still working? Thanks
Can you share the code you have?
I think I’ve sorted this now. Great device, really cheap, initial update OTA via Sonoff DIY mode. Easy as.
Here’s the code:
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: !secret wifi_SSID
# Enable logging
logger:
substitutions:
  hostname: "sonoff_mini"
api:
  password: !secret default_password
ota:
# used just for testing, otherwise no need for it
#web_server:
#  port: 80
# tasmota template: {"NAME":"Sonoff Mini","GPIO":[17,0,0,0,9,0,0,0,21,56,0,0,255],"FLAG":0,"BASE":1}
# template decoded: GPIO: GPIO00 17 Button1, GPIO04 9 Switch1, GPIO12 21 Relay1, GPIO13 56 Led1i, GPIO16 255 userdef; BASE: Sonoff Basic
status_led:
  pin:
    number: GPIO13
    inverted: true
binary_sensor:
  - platform: gpio
    pin: GPIO00
    internal: true
    filters:
      - invert:
      - delayed_off: 10ms
    on_press:
      - switch.toggle:
  - platform: gpio
    pin: GPIO04
    on_press:
      then:
        - switch.turn_on:
    on_release:
      then:
        - switch.turn_off:
switch:
  - platform: gpio
    icon: "mdi: lightbulb_outline"
    pin: GPIO12
    restore_mode: restore_default_off
Btw. the sonoff mini uses a esp8285…
So the start would be:
esphome:
  platform: esp8266
  board: esp8285
Very informative thank you. Can anyone advise what GPIO connections are tied to the S1 and S2 connecting points on the Sonoff Mini. I’m writing my own firmware and want to encompass the external switch option. TIA Paul
Switch input is GPIO04 and Ground
Is the button in parallel with S1 and S2 though, or are S1 and S2 separate GPIO inputs?
orange-assistant Thank you, that worked well. tom_l The button is on GPIO0 and the S1/S2 is as orange-assistant says:- GPIO4 and Ground.
Hi, can I just ask, is your yaml the same as above? If different, can you please post. Thanks
To be totally correct:
Sonoff Mini S1 Input is Ground
Sonoff Mini S2 Input is GPIO4
This can be important if you plan a shared ground!
How do you get the sonoff mini in diy mode for initial ota flashing?
FYI this is from Drzzs youtube example:
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: !secret wifi
  password: !secret wifi_pw
# Enable logging
logger:
api:
ota:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    name: "Main Bathroom Button"
    on_press:
      - switch.toggle: relay
  - platform: gpio
    pin:
      number: GPIO4
      mode: INPUT_PULLUP
      inverted: True
    name: "Main Bathroom Switch"
    on_press:
switch:
  - platform: gpio
    name: "Main Bathroom Relay"
    pin: GPIO12
status_led:
  pin:
    number: GPIO13
    inverted: yes
Hi Immo,
I used the procedure documented at https://github.com/arendst/Sonoff-Tasmota/wiki/Sonoff-DIY . So got Tasmota Basic on it, then used that web interface to upload compiled ESPHome code.
Apologies to ask a potentially stupid question, but perhaps someone in this thread can help me - is it possible to use the sonoff mini S1/S2 input to read the state of an up / down switch for my roller shutters? I kind of understand that it’s only one GPIO so probably not possible, just wanted to check :slight_smile:
