Has anyone had any experience with these?
I’m wondering if they can be used with the Sonoff RF Bridge to be a switch available for use in Home Assistant.
It would be great to have a physical switch that could run scripts or automations!
I have found one a bit cheaper on UK eBay.
https://www.ebay.co.uk/itm/183332111357
Might buy one and give it a go.
nice work! I am thinking the same - Do you have a Sonoff RF Bridge? I have one on order from China.
Yes I have one flashed with Tasmota firmware.
Not really done anything with it yet another than read a status of a door sensor when it changes from Open to Closed. Not made any automations yet.
Cool! I’ll be keen to see what happens - I might order one of these two - See who’s gets here first!
My two Switches came today.
They pretty much behave the same as the RF Door Sensors I documented here:
They only seem to send one command though as you would expect and the command gets sent when you release your finger. (There might be a low battery command?)
To use them with a Sanoff Bridge you would do something along the lines of
- alias: Trigger Something
platform: mqtt
topic: tele/sonoffBridge/RESULT
condition:
condition: template
value_template: '{{ trigger.payload_json.RfReceived.Data == "123456" }}'
- service: homeassistant.turn_off
entity_id: group.AllLights
That’s great news! I’m still waiting on mine, but I’m glad to know they can be used in that way! Thanks for updating!
