I’m just in the process of downgrading my config to 0.69.1 because I just updated to 0.70 and now I’m getting a RFXTRX error:
018-05-29 00:39:07 ERROR (MainThread) [homeassistant.setup] Error during setup of component rfxtrx
File "/usr/lib/python3.6/site-packages/serial/serialposix.py", line 244, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-RFXCOM_RFXtrx433_A11I6NWQ-if00-port0'
File "/usr/lib/python3.6/site-packages/RFXtrx/__init__.py", line 606, in connect
self.serial = serial.Serial(self.port, 38400, timeout=0.1)
File "/usr/lib/python3.6/site-packages/serial/serialutil.py", line 182, in __init__
self.open()
File "/usr/lib/python3.6/site-packages/serial/serialposix.py", line 247, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A11I6NWQ-if00-port0: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-RFXCOM_RFXtrx433_A11I6NWQ-if00-port0'
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 146, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/rfxtrx.py", line 101, in setup
rfx_object = rfxtrxmod.Connect(device, None, debug=debug)
File "/usr/lib/python3.6/site-packages/RFXtrx/__init__.py", line 718, in __init__
self.transport = transport_protocol(device, debug)
File "/usr/lib/python3.6/site-packages/RFXtrx/__init__.py", line 601, in __init__
self.connect()
File "/usr/lib/python3.6/site-packages/RFXtrx/__init__.py", line 609, in connect
port = glob.glob('/dev/serial/by-id/usb-RFXCOM_*-port0')[0]
IndexError: list index out of range
2018-05-29 00:39:07 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of light.rfxtrx. Setup failed for dependencies: rfxtrx
2018-05-29 00:39:07 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform light.rfxtrx: Could not setup all dependencies.
2018-05-29 00:39:07 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.rfxtrx. Setup failed for dependencies: rfxtrx
2018-05-29 00:39:07 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.rfxtrx: Could not setup all dependencies.
