Does anyone know if I can use the addon? Can someone help me ?
When that repoās maintainer, @ericleb010, asked if you could provide more log detail, I believe he was asking for the relevant entries in your home-assistant.log
file. If you post them here, he or others may be able to help you further.
Friend, I held it. Itās giving that is not compatible. What log will indicate? Dev could tell me if the addon is raspberry compatible. But so far he hasnāt asked for anything ā¦ Anyway ā¦ Iāll wait ā¦
As you can see in this thread, there are plenty of people using Raspberry Pi, including myself. So it is compatible. And yes, as Jeff mentioned, I need to see your logs to know what is going on. Without them, I canāt help.
Ok. Thanks for helping me out! Come on.
removed and added again, see the log. What more do you need?
System log
19-10-25 17:56:55 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-10-25 18:30:15 INFO (MainThread) [hassio.host.info] Update local host information
19-10-25 18:30:15 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-10-25 18:30:17 INFO (MainThread) [hassio.host.services] Update service information
19-10-25 18:30:17 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-10-25 18:30:17 INFO (MainThread) [hassio.host.network] Update local network DNS information
19-10-25 18:30:17 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
19-10-25 19:56:55 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/ericleb010/hassio-addons repository
19-10-25 19:56:55 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
19-10-25 19:56:55 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
19-10-25 19:56:55 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hunterjm/hassio-addons repository
19-10-25 19:56:55 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-10-25 19:56:57 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove
19-10-25 20:36:55 INFO (MainThread) [hassio.host.info] Update local host information
19-10-25 20:36:55 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-10-25 20:36:58 INFO (MainThread) [hassio.host.services] Update service information
19-10-25 20:36:58 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-10-25 20:36:58 INFO (MainThread) [hassio.host.network] Update local network DNS information
19-10-25 20:36:58 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
19-10-25 20:59:37 INFO (MainThread) [hassio.store.git] Remove custom add-on repository https://github.com/ericleb010/hassio-addons
19-10-25 20:59:38 INFO (MainThread) [hassio.store] Load add-ons from store: 62 all - 0 new - 1 remove
19-10-25 20:59:50 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/ericleb010/hassio-addons repository
19-10-25 20:59:57 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 1 new - 0 remove
Nothing else? That doesnāt really indicate that anything out of the ordinary happened.
Is it possible to push this addon to HACS?
No idea. My Home Assistant is decommissioned right now so I havenāt had any motivation to look into how to improve this add-on. Further development on this will require help from others here.
Bashing my head against the wall hereā¦ ive tried multiple fixes but i keep running into this errorā¦ anyone solve this?
Iām seeing these in the HA log when attempting to power the xbox on.:
2019-11-07 07:57:56 ERROR (SyncWorker_18) [custom_components.xboxone.media_player] Failed to poweroff FD004A03EC4BD7AB
2019-11-07 07:58:05 ERROR (SyncWorker_0) [custom_components.xboxone.media_player] Failed to poweroff FD004A03EC4BD7AB
2019-11-07 07:58:12 ERROR (SyncWorker_15) [custom_components.xboxone.media_player] Failed to poweroff FD004A03EC4BD7AB
Seeing this in the add-on log when powering down:
127.0.0.1 - - [2019-11-07 08:02:11] "GET /device/FD004A03EC4BD7AB/poweroff HTTP/1.1" 200 125 0.003140
127.0.0.1 - - [2019-11-07 08:02:11] "GET /versions HTTP/1.1" 200 317 0.031143
127.0.0.1 - - [2019-11-07 08:02:11] "GET /auth HTTP/1.1" 200 5751 0.000534
[2019-11-07 08:02:11,166] DEBUG in protocol: Received DiscoverResponse from 192.168.3.103
[2019-11-07 08:02:11,668] DEBUG in protocol: Received DiscoverResponse from 192.168.3.103
[2019-11-07 08:02:11,669] DEBUG in protocol: Received DiscoverResponse from 192.168.3.103
[2019-11-07 08:02:12,169] DEBUG in protocol: Received DiscoverResponse from 192.168.3.103
[2019-11-07 08:02:12,171] DEBUG in protocol: Received DiscoverResponse from 192.168.3.103
[2019-11-07 08:02:13,678] WARNING in consolewrap: Failed to import NanoManager (depends on xbox-smartglass-nano). /nano endpoint will not work!
127.0.0.1 - - [2019-11-07 08:02:13] "GET /device?addr=192.168.3.103 HTTP/1.1" 200 513 2.515564
127.0.0.1 - - [2019-11-07 08:02:13] "GET /device/FD004A03EC4BD7AB HTTP/1.1" 200 491 0.000559
127.0.0.1 - - [2019-11-07 08:02:13] "GET /auth HTTP/1.1" 200 5751 0.000595
Xbox does power down, but does not respond to power up from the HA UI. ubuntu 18.04 on i3 NUC, HA 101.2, Hassio add-on install.
UPDATE: Following a couple HA restarts, upgrading to 0.101.3, these errors and the On/Off issue have resolved themselves.
UPDATE2: After updating to 102.1, the add-on can no longer connect to the xbox. Back to square one.
For anyone looking for a fix for this problem you need to create the required files in a ācomponentā folder not custom_components.
I have exactly the same problem as youā¦
Where did you put the file exactly ?
You need to put the ācomponentā in your config directory similar to āCustom_Componentsā
That is exactly what i didā¦ But still have the error message :
I aslo try to add a sub folder but it didnt work.
Maybe this information is important; my home assistant is running on a debian vm (so not hassio)
Hi!
I have moved my Xbox to a IoT network and allowed all trafic from Xbox to HA but access, unable to Retrieve the live ID. My XBoX app on iPad not working either even when all traffic allowed there as well.
Any ideas?
Br
Hi guys, Im trying to install this addone but getting an error:
[hassio.docker.interface] Can't install hunterjm/hassio-armv7-xboxone:2.0.0 -> 404 Client Error: Not Found ("pull access denied for hunterjm/hassio-armv7-xboxone, repository does not exist or may require 'docker login'").
Do you know what can be the issue ?
Thx.
hi,
when Iām test the configuration server after make configuration, Iām obtain this error:
Platform error media_player.xboxone - Integration 'xboxone' not found.
Iām use hassio method.
in my custom_components this installation make one directory name āxboxoneā with in the file name āmedia_player.pyā.
Who I make one bug off this configuration?
hi, trying to get this up and running, when i add the Add On Store, it onlyi shows TensorFlow Installer, not xboxone, any ideas ?
