It would be great to be able to specify the version number of an add-on when installing.
Currently, the API consist in a request to the following url: POST https://<hostname>/api/hassio/addons/<addon_slug>/install with a json-empty payload {}.
It would be great to be able to specify the version number in the payload like that: {"version": "0.1.2"}
Since the version is simply translated into a repository tag, it would simply request this tag instead of the one supplied in the config.json file. Obviously, it can only work with pre-built docker images, but it would allow the following scenarios:
Downgrade a faulty add-on to a known good version without loosing the settings.
QA test a new published version before updating the config.json of the add-on on Github.
Give users a way to test special builds for feature branches, etcâŚ
Obviously, it should be also available on the update endpoint: POST https://<hostname>/api/hassio/addons/<addon_slug>/update.
ANYWAY itâs already âkind-ofâ available when youâre restoring a package from a backup⌠just let us do as if it were restored from a backup.
After that we can add the following hassio's CLI parameter:
hassio addons update superaddon --version 1.2.3
It could/should be an advanced feature only available on command-line.
