Hi all,
I am still a newbie, trying to get some helpful things working.
I completely reinstalled hass.io after making some batery levels from mobiles show up via Owntracks etc.
My 1st try to get 2 aqara sensors to work with zigbee2mqtt leaves me frustrated -
This is a new start after 1 month rest
I bought a Conbee II Stick, plugged it in one USB port on board the Raspi 3+.
I installed deCONZ - looked up the SYSTEM devices, whre following is shown for my Conbee Stick: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2122187-if00
Then I changed the NULL in the deCONZ config to
Ā“/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2122187-if00Ā“
But the ADD-ON will not start.
Can someone help to get this Add-on running?
Regards,
Joerg
I have the deconz add-on running. Although I too see the /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2122187-if00 thingy in the hardware section of hassio, I had to use the tty serial port: ā/dev/ttyACM0ā
Thanks a lotā¦
I read about this issue and some people workarounds like yours.
I tried it as wellā¦but it doesnāt work.
When I trigger the start button it has a colour change to red and nothing happens.
My Hardware info shows:
serial:
/dev/ttyAMA0
/dev/ttyACM0
/dev/serial/by-id/usb-dresdenā¦
(Sorry I do not understand which signs to use to quote text on german keyboardā¦)
I have 4 USB ports on the Rasperry 3+ boardā¦which direct interface names can I try as well?
Is it
I tried with keeping the Password empty.
No change in behaviour - will not start.
I now added a Password. No change either.
After pushing start button, red color appears and add-on is still stopped.
To start debugging I added the
"dbg_aps": 1
But where can I see the debugging information?
If I click on āRefresh Logā at the deCONZ add-on page, there is absolutely nothing shown.
Is it somewhere else?
that has been exactly my 1st setup - although I left the password empty.
it seems there are several users with this issue.
Since Version 3.4 there are issues.
There seems as well that there are several work arounds:
Addressing the device via i.e. /dev/ttyACM0 ādirectlyā - for me it doesnt fix the issue.
connecting the USB to another port ( I have 4 on my Raspi board) - not working for me
So without help I am stuck in another dead-end.
To help myself I wanted to have a look in the debugging log.
By the wayā¦the Hassio Log gives following error:
19-11-23 08:12:39 ERROR (SyncWorker_8) [hassio.docker] Canāt create container from addon_core_deconz: 404 Client Error: Not Found (āNo such image: homeassistant/armhf-addon-deconz:3.8ā)
Does that help?
Again:
I have not forwarded any port actually for deCONZ (just in case this is required)
I have not used the āInstall Codeā on the packing box of Conbee II Stick
it is directly connected to the USB, since I do believe using a longer cable will only help to have better transmission to sensorsā¦no installation issue should be triggered by this.
Still waiting for helpā¦
By the way: The Github issue launched did not get any feedback at all. I am new on Github, so not sure if I posted it in the right āwayā
Click the HassIO menu (left)
The choose the deConz add-on to view its options.
Scroll down till you see docker options textbox, below that will be the network ports mapping.
ok thanks,
unfortunately no change.
On DISCORD support platform, @frenck: assumes that I am out of disk spaceā¦It is a new installed 32GB Card with 2GB image flashed.
So actually I try to follow that traceā¦
Agreed, it should be automatic with HassIO, assuming you have the image for it. docker ps will reveal that. docker ps | grep homeassistant if thereās too much output.
If you can get a normal or privileged web terminal you can sanity check via docker pull homeassistant/armhf-addon-deconz:3.8 to at least make it available or get the error
I had a second 32GB SD Card waiting for another project. I flashed that one with the same image by Elena batcher.
No SSH add-on or mosquitto add-in now.
Direct install of deCONZ including the /dev/serialā¦ Text copied to config the deCONZ add-on.
ā¦
Install successfulā¦!
Yeah, shakalaka !!
The 1st SD Card is new as well, bit it has been flashed twice before. Maybe problem? I will check later.
Got the exact same problem as the TS, running HassOS 2.12 and Home Assistant 0.102.2 with an Aeotech Z-stick and a Conbee II USB-stick. Deconz is installed from the addon store. Got 3 additional add-ons installed:
Configurator
Letās Encrypt
SSH server
(and ofcourse deCONZ)
Iāve also tried many of the same things as the TS, including:
Playing around with the device setting (/dev/ttyACM0 or the longer /dev/serialā¦)
Tried setting another VNC port
Swapped power supply from a POE splitter to the original 2.5A charger
Checked available space (after seeing the post on the Discord channel, answering Joerg)
19-11-26 20:52:26 ERROR (SyncWorker_5) [hassio.docker] Canāt create container from addon_core_deconz: 404 Client Error: Not Found (āNo such image: homeassistant/armhf-addon-deconz:3.8ā)
Does any developer want to dive further into this? Or do I have to clean install like the TS?
Iām getting the same error ([hassio.docker] Can't create container from addon_core_deconz: 404 Client Error: Not Found ("No such image: homeassistant/armhf-addon-deconz:3.8"))
Iām running hassOS so I think that I canāt access docker commands? Thank you so much for any help you can give!
Iām running into the same issue, the only thing I havenāt tried is using a bigger SD card - but Iām currently using a 64GB SD card. Can anyone validate whether this is big enough?
