Hass.io kills Wifi
Hi HA forum,
I have an issue with my home assistant running on a RPi 3. Observations:
  • If I activate max eq3 in my config yaml, I get an error that the connection times out
  • I regularly get warnings on Xiaomi Plant monitor update taking longer than expected
  • my wifi breaks after a while (devices can no longer connect to the wifi) and I need to restart the router. My guess for the cause of this issue is HA.
I have read
where HA caused a similar problem. However, I do not have a bluetooth tracker activated (I had it activated in the past though).
What can I do to fix this issue? Any help is really appriciated.
Same here, ever found answer?
No longer have the issues, but unfortunately don’t know why — sorry.
