Hass.io Menu
I am new to home assistant, and I am running Home Assistant 0.56.2 on a Windows 10 machine. I am working through some YouTube videos on using home assistant which have made me realize I don’t have the Hass.io Menu bar on the left.
Searching through old threads indicates that you need to have discovery: or hassio: in your configuration.yaml file. I have discovery: enabled and I don’t see the Hass.io bar. If I add hassio:, I get the following error in my home-assistant.log:
2017-11-05 11:18:02 ERROR (MainThread) [homeassistant.components.hassio] No HassIO supervisor detect!
2017-11-05 11:18:02 ERROR (MainThread) [homeassistant.setup] Setup failed for hassio: Component failed to initialize.
Any idea of what I need to do? I am completely lost.
Thanks,
Jeremy
Hi @RonJ103, Welcome to HA.
If your HA runs on Windows it is not Hass.io, and so there’s no menu.
https://home-assistant.io/blog/2017/07/25/introducing-hassio/
