I installed Hass.io on the fresh installation of Ubuntu 18.04.1 server following these instructions: https://www.home-assistant.io/hassio/installation/
It has been working almost fine since I installed it (2 months ago), but from the very beginning one thing puzzles me: Home Assistant never starts automatically when I reboot the host OS (Ubuntu).
When I login into Ubuntu and check what containers are running I get nothing:
max@maxnotaserver:~$ sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
But if I restart the docker:
max@maxnotaserver:/usr/local/bin$ sudo systemctl restart docker.service
[sudo] password for max:
And check in a couple of minutes I get everything running successfully:
max@maxnotaserver:/usr/local/bin$ sudo docker ps
9876645a5e14 homeassistant/amd64-addon-configurator "/run.sh" 4 minutes ago Up 4 minutes 0.0.0.0:3218->3218/tcp addon_core_configurator
8fab92314bfe hassioaddons/log-viewer "/init" 4 minutes ago Up 4 minutes 0.0.0.0:4277->4277/tcp addon_a0d7b954_logviewer
1cb208c06346 homeassistant/qemux86-64-homeassistant "/bin/entry.sh pytho…" 5 minutes ago Up 5 minutes homeassistant
faa1814752ce homeassistant/amd64-addon-samba "/run.sh" 5 minutes ago Up 5 minutes addon_core_samba
6d6c7204ac44 homeassistant/amd64-addon-rpc_shutdown "/usr/bin/entry.sh /…" 5 minutes ago Up 5 minutes addon_core_rpc_shutdown
1e8f1a61be2a homeassistant/amd64-hassio-supervisor "python3 -m hassio" 3 weeks ago Up 5 minutes hassio_supervisor
I would be happy to get any clues to where should I look into!
I ended up setting up a script to restart the docker service in 5 minutes after boot, which works, but is quite ugly
I inspected logs with journalctl -u hassio-supervisor.service -b and I see that the daemon repeatedly reports the error and tries to restart indefinately:
Jan 05 13:42:55 maxnotaserver systemd[1]: Starting Hass.io supervisor...
Jan 05 13:42:59 maxnotaserver systemd[1]: Started Hass.io supervisor.
Jan 05 13:42:59 maxnotaserver docker[1676]: hassio_supervisor
Jan 05 13:43:03 maxnotaserver hassio-supervisor[1830]: Error response from daemon: error while creating mount source path '/usr/share/hassio': mkdir /usr/share/hassio: read-only file system
Jan 05 13:43:03 maxnotaserver hassio-supervisor[1830]: hassio_supervisor
Jan 05 13:43:06 maxnotaserver hassio-supervisor[1830]: docker: Error response from daemon: error while creating mount source path '/usr/share/hassio': mkdir /usr/share/hassio: read-only file system.
Jan 05 13:43:06 maxnotaserver hassio-supervisor[1830]: time="2019-01-05T13:43:06+03:00" level=error msg="error waiting for container: context canceled"
Jan 05 13:43:06 maxnotaserver systemd[1]: hassio-supervisor.service: Main process exited, code=exited, status=125/n/a
Jan 05 13:43:06 maxnotaserver systemd[1]: hassio-supervisor.service: Failed with result 'exit-code'.
Jan 05 13:43:11 maxnotaserver systemd[1]: hassio-supervisor.service: Service hold-off time over, scheduling restart.
Jan 05 13:43:11 maxnotaserver systemd[1]: hassio-supervisor.service: Scheduled restart job, restart counter is at 1.
Jan 05 13:43:11 maxnotaserver systemd[1]: Stopped Hass.io supervisor.
Jan 05 13:43:11 maxnotaserver systemd[1]: Starting Hass.io supervisor...
Jan 05 13:43:12 maxnotaserver docker[1976]: hassio_supervisor
Jan 05 13:43:12 maxnotaserver systemd[1]: Started Hass.io supervisor.
Jan 05 13:43:14 maxnotaserver hassio-supervisor[1997]: time="2019-01-05T13:43:14+03:00" level=error msg="error waiting for container: context canceled"
Jan 05 13:43:14 maxnotaserver hassio-supervisor[1997]: Error response from daemon: error while creating mount source path '/usr/share/hassio': mkdir /usr/share/hassio: read-only file system
Jan 05 13:43:15 maxnotaserver hassio-supervisor[1997]: hassio_supervisor
Jan 05 13:43:18 maxnotaserver hassio-supervisor[1997]: docker: Error response from daemon: error while creating mount source path '/usr/share/hassio': mkdir /usr/share/hassio: read-only file system.
Jan 05 13:43:18 maxnotaserver hassio-supervisor[1997]: time="2019-01-05T13:43:18+03:00" level=error msg="error waiting for container: context canceled"
Jan 05 13:43:18 maxnotaserver systemd[1]: hassio-supervisor.service: Main process exited, code=exited, status=125/n/a
Jan 05 13:43:18 maxnotaserver systemd[1]: hassio-supervisor.service: Failed with result 'exit-code'.
Jan 05 13:43:23 maxnotaserver systemd[1]: hassio-supervisor.service: Service hold-off time over, scheduling restart.
Jan 05 13:43:23 maxnotaserver systemd[1]: hassio-supervisor.service: Scheduled restart job, restart counter is at 2.
Jan 05 13:43:23 maxnotaserver systemd[1]: Stopped Hass.io supervisor.
Jan 05 13:43:23 maxnotaserver systemd[1]: Starting Hass.io supervisor...
Jan 05 13:43:23 maxnotaserver docker[2119]: hassio_supervisor
Jan 05 13:43:23 maxnotaserver systemd[1]: Started Hass.io supervisor.
