When attempting to load the HASS.io screen it comes up white and watching requests in Fiddler the following .js file gets a 404:
http://hassio.local:8123/frontend_latest/custom-panel.js
Running 0.75.0, just installed from the 32bit image zip file available here:
Anyone else seeing this issue? suggestions on what to do to correct the issue? is there a place I can get that .js file, and place it on the PI?
heyjva
(Heyjva)
August 4, 2018, 12:46am
2
I just reinstalled hassio to migrate to hassio os. I’m having the same issue and don’t know what to do.
baldpom
(Baldpom)
August 4, 2018, 1:07am
3
I’m getting 404 on this file too (frontend_latest/custom-panel.js) - just upgraded from 0.72
Also getting this error. I’m running HassOS on a RPi 3b+ that was previously running 0.74 PERFECTLY. Just updated to 0.75 and boom…
dclobato
(Daniel Correa Lobato)
August 4, 2018, 3:39am
5
Exactly the same here. Just updated from 0.74.2 to 0.75.0 and the hassio panel is blank
zoogara
(Daryl)
August 4, 2018, 6:35am
6
Same here but I see this in the log:
Sat Aug 04 2018 16:22:44 GMT+1000 (Australian Eastern Standard Time)
Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
TimeoutError: [Errno 110] Operation timed out
Which now that I think about it may be unrelated. Just upgraded from 0.74.2 to 0.75
Darbos
(Darbos)
August 4, 2018, 8:03am
7
Im using hassio docker on ubuntu 16 vm and have the same issue after my upgrade to .75
nickrout
(Nick Rout)
August 4, 2018, 8:37am
8
Using the hassos 1.8 vmdk file in virtualbox, just upgraded to 0.75 and rebooted, working fine.
Me too, i tried clearing cache cookies, all on three different browsers-chrome, firefox, safari and my phone also, same image displayed as @houtknots , blank screens for hassio tab
howesfam
(David)
August 4, 2018, 1:12pm
13
Same here on fresh 0.75 install on pi 3+
Jefe
(Jeff)
August 4, 2018, 1:24pm
14
Same issue here. Just updated from 0.74.2 to 0.75.0 and the hassio panel is blank.
I believe there is a bug fix on the way. Might take a day to land for hassio though.
Same problem here on a fresh install. Is there anyway to do a fresh install with an older working version?
thx
Bschjoett
(Benny Schjoett)
August 4, 2018, 1:55pm
17
I have also updated to 0.75 and no issue aboit hassio, but have another problem, Configuration and IDE shows blank screen.
Any suggestion ?
There has just been released a New version of Home-Assistant so probably the Hass.io version will be released later today or tomorrow
Janne
August 4, 2018, 2:42pm
19
I run hass.io docker on Ubuntu 18.04 server, how can I update without the hass.io panel?
After the installation from scratch on RPi3 I have the same issue.
