Vayain
(Vayain)
1
i’m looking for a solution to use Homegear (https://forum.homegear.eu/c/English-Forums) inside Hass.io for connecting Homematic devices. Works like a charm in Home-Assistant, but not in Hass.io.
Homegear is already available as a docker container (https://hub.docker.com/r/homegear/homegear/), is there a way to connect Hass.io with this additional docker container?
Thanks in advance!
hijinx
(James)
2
There is no official add-on but you can create your own easily.
- Install samba addon (for ease)
- In the addons dir create a new folder “Homegear”
- In the Homegear dir create a file “config.json”, and paste this into in and save:
"name": "Homegear",
"version": "latest",
"slug": "homegear",
"image": "homegear/homegear",
"description": "Homegear",
"url": "https://hub.docker.com/r/homegear/homegear/",
"startup": "before",
"boot": "auto",
"ports": {
"2001/tcp": 2001,
"2002/tcp": 2002,
"2003/tcp": 2003
"environment": {
"arch": ["amd64"],
"options": {
"schema": {
You may need to change arch if on RPi - I am on x86
Save the file, open hassio store and you should see local addon.
Install it and start it…
Works for me at http://hassio.local:2001
Hi did anyone manage to get homegear on a raspberry pi3 running?
I always get error:
standard_init_linux.go:187: exec user process caused "exec format error"
QSL
4
Using homegear/rpi-homegear
instead of homegear/homegear
works on my raspberry. (https://hub.docker.com/r/homegear/rpi-homegear/)
How would one mount Homegears configuration volumes with hassio?
The requiriered volumes are:
/etc/homegear
/var/lib/homegear
/var/log/homegear
I can think of two ways to get them:
- bind mount them to /data inside the container
- use some option for docker volumes outside of the container (like -v for docker)
I’d prefer the second option as it wouldn’t require me to build a derivative image.
To access homematic devices one would also need a physical serial port passed through.
jansh
(Jan)
5
You can add "devices": ["/dev/ttyAMA0:/dev/ttyAMA0:rwm"]
to your config.json
I’m still thinking about how to get /etc/homegear
mounted from the host…
I’m also looking to add Homegear to my Hass.io.
Any update on this, regarding the volume /etc/homegear
jansh
(Jan)
7
I’ve packaged up what I have and published it here:
Let me know if that works for you!
Klagio
(Klagio)
8
Ah! Thanks a lot, just installed it on a NUC HASSIO and seems to work
