Hass.io Xiaomi Sensor show nothing
If you are at home then just use a browser (chrome is good) to connect to your_ip_addr:8123
If outside your network, you’ll need to use ssl and duckdns and letsencrypt, see here…
yes i have build me a duckdns domain but than i hang by the letsencrypt addon
Sorry I don’t have any idea as I don’t use it :frowning:
Thats ok you help me enough :wink: I make that but can you say me how i can set a alarm for the moisture when its under 30%?
In automations.yaml place something like the following…
# Notify me on my mobile phone of an event that affects my plants                             #
#          Water/Battery/Food        #
  alias: 'Plant Water Check'
  initial_state: 'off'
    platform: numeric_state
    entity_id: sensor.miflora_bird_of_paradise_moisture, sensor.miflora_trailing_plant_bathroom_moisture
    below: 30
    - condition: sun
      after: sunset
    - condition: time
      after:  '18:00:00'
      before: '18:01:00'
     # Actions are scripts so can also be a list of actions
    - service: notify.mypushbullet
      data_template:
        message: >
          '{{ trigger.from_state.attributes.friendly_name }} NEEDS Water!'
  alias: 'Plant Battery Check'
  initial_state: off
    entity_id: sensor.miflora_bird_of_paradise_battery, sensor.miflora_trailing_plant_bathroom_battery
    below: 5
    above: 1
    - condition: sun
      after: sunset
    - condition: time
      after:  '18:00:00'
      before: '18:01:00'
      data_template:
        message: >
          '{{ trigger.from_state.attributes.friendly_name }} NEEDS a new Battery!'
  alias: 'Plant Food Check'
    entity_id: sensor.miflora_bird_of_paradise_conductivity, sensor.miflora_trailing_plant_bathroom_conductivity
    below: 100
    - condition: sun
      after: sunset
    - condition: time
      after:  '18:00:00'
      before: '18:01:00'
      data_template:
        message: >
          '{{ trigger.from_state.attributes.friendly_name }} NEEDS Feeding!'
The above will notify me via pushbullet on my mobile at around 18:00 (6pm) if any of the plants I have need water, or batty is low or need feeding. You will need to setup pushbullet (notify component) and the sensor names to whatever yours are called.
You are the best much thanks i test it tomorrow
