Hassio (addon: Bluetooth BCM43xx) Bluetooth Tracker messing with Yeelight bulbs! Help please
Same problem in my setup. Any ideas? Please help.
Are you controlling your Yeelight bulbs directly from HASS via Bluetooth? If so, how on earth are you doing that? The link to the bluetooth_bcm43xx addon seems to be dead (https://www.home-assistant.io/addons/bluetooth_bcm43xx/) so i’m not sure if you’re using that or something else.
Thanks for any help!
