According to my DHCP Client List the ip should be 10 hassio ************** 192.168.0.113
But http://192.168.0.113:8123 gives
This site can’t be reached
I think you and I are in the same boat for now. I’ve trying to have it installed on my RPi3 since Wednesday afternoon and I’m still stuck with this screen.
For explanation: You can’t directly attach a monitor to your pi. That doesn’t work with Hassio @mistrovly. You have to connect via your local network. Via hassio.local:8123. If that doesn’t work try ipofyourpi:8123. Are both your devices directly connected to the same router ?
Are you connected via Wifi or Ethernet? Did you provide details in the resin-example file, as is mentioned [here] (https://home-assistant.io/hassio/installation/) for wifi? Optional - Setup the WiFi or static IP: On the SD-card, edit the system-connections/resin-sample file and follow the ResinOS howto.
In your router there can be a setting that’s forbids local devices to connect to each other, maybe this can be the problem. In my TP-Link router it is named: Enable AP Isolation. This has to be turned off maybe?
Maybe a very strange thought, but disconnect the cable and let the Pi use the wifi? Maybe the wifi and ethernet cause trouble? If you have SSID broadcasting in the router enabled, in the resin-example file you have to adjust the value of, I think it’s called hidden to false.
Ok, to recap. In the router you see your Pi has an ip. But with your laptop you can’t access it and also with your phone you can’t access it, not on ip:8123 and not on hassio.local:8123. Your laptop and phone are both connected via wifi to your router where also your Pi is connected to?
