Everytime I reboot my router HASSIO loses its connection to the network. If I unplug the network cable and reconnect it comes back on. Similarly I can reboot HASSIO and it comes back up.
Any ideas?
Do you have a fixed IP address on your router for Hassio ? If not and you are using DHCP it is possible that you will need the old MAC address in your routers ARP table to expire before Hassio and your router handshake again.
Using a fixed IP address is the best way forward - if you already have then what happens if you power cycle the router instead of a reboot as the power will always go down on a power cycle and Hassio should see that.
Yes I have a static IP set in my router. Iâve tried both a power cycle and reboot. Same result in HASSIO.
Iâm also using a wired connection as I thought it may have something to do with WIFI.
Why are you having to reboot your router so frequently? I would look into that first.
I donât think it should matter how often my router is rebooted. Iâm just trying to figure out if itâs in an issue with HASSIO or maybe my RPI3 board.
It just highlights a bigger issue.
If you know how to run a ping command start pinging your pi then reboot your router again. Once it is back up does it only reply once you reseat the lan cable?
What happens if you move to another port on your router and try again?
Does the same issue happen to other devices connected to your router when you reboot it?
HASSIO seems to be the only device affected. Below is a terminal session where I was able to ping HASSIO @ 192.168.1.9 and open ssh.
After a router reboot I can no longer ping 192.168.1.9 but I could still ssh in.
PING 192.168.1.9 (192.168.1.9): 56 data bytes
64 bytes from 192.168.1.9: icmp_seq=0 ttl=64 time=2.251 ms
64 bytes from 192.168.1.9: icmp_seq=1 ttl=64 time=3.437 ms
64 bytes from 192.168.1.9: icmp_seq=2 ttl=64 time=29.862 ms
--- 192.168.1.9 ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 2.251/11.850/29.862/12.746 ms
MacBook:~ Darren$ ssh hassio@hassio
[exited]
Connection to hassio closed.
*Router rebooted
MacBook:~ Darren$ ping 192.168.1.9
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
4 packets transmitted, 0 packets received, 100.0% packet loss
[exited]
Looks like I can still connect via IPv6 after a router reboot but not IPv4. Iâm going to try a âmy-networkâ file and see if that changes anything.
That is very strange. What router and model do you have ?
I do not have an issue like that at all - I have a TP Link Archer C2 for reference - cheap and cheerful for my cable provider but it works.
Iâm using a tp-link archer c2600 with LEDE. HASSIO on my RPI3 is the only device affected.
I used a usb to install a my-network file with my wifi config and that seems to be working fine.
Glad you got it sorted.
first post perfectly describe my issue but I have the raspberry connected via LAN, how can I solve the problem?
I had to stick with wifi to keep HASS up. Havenât tried going back to LAN since the problem started,
Same problem here. I am afraid itâs hass.io issue. Before installing hass.io the same hardware worked fine over LAN and once a week router reboot.
I am having this issue also. Does anyone have an idea of how to troubleshoot this. I could do wifi but it seems unnecessary since my pi is beside the router.
Same issue here. On an RPI 4 4gb model. I donât want to switch to WiFi when the rpi is next to the router. I want the reliability of wired connection.
My router is an ASUS RT-AC68U with latest firmware (router firmware was updated a couple of days ago but even on previous router firmware I had this same issue).
EDIT: rather stupidly, I forgot to try access the IP address of hassio rather than dns name after router reboot. I will give it a go later when the family arenât all up and on the net to see if itâs just the name that cant connect or ip address to.
UPDATR 2: Iâve rebooted router (and Linksys Velop WiFi nodes). Canât access http://hassio:8123 but I can get into it from the IP address
Iâm newbie in Home Assitant. I installed hassio on RPi3 two months ago. I immediately noticed that when rebooting or restart the router, hassio loses the network.
I set a static IP address for hassio in the router.
Then I set a static IP address for hassio (âmy-networkâ and âimport from usbâ).
I tried changing router.
Nothing helps. After rebooting the router, hassio loses the network.
I see that the problem is not only mine. Has anyone found solution?
Same here. didnât find any solution.
The only way I find to get around this issue, is by restarting Hassio if pinging the router failed for more than 10 minutes, but this is very dirty way.
I hope that I have found solution to this problem.
I configure network not using import from USB Flash, but directly in the âhassos-bootâ partition.
On SD card with Hassio, in FAT partition âhassos-bootâ, create folder âCONFIGâ, in it folder ânetworkâ, in it file âmy-networkâ with the contents of known manual, and completely reboot device.
For example my content:
[connection]
id=my-network
uuid=ee48278a-b3a2-4d6b-868e-6030c424c927
type=802-3-ethernet
[ipv4]
method=manual
address=192.168.1.120/24;192.168.1.1
dns=8.8.8.8;8.8.4.4;
[ipv6]
addr-gen-mode=stable-privacy
method=auto
I have two Raspberry Pi 3B. One as reserve. I checked this method on both.
PS: If Windows PC does not see âhassos-bootâ partition on the SD card with hassio installed, assign it the letter in âDisk Managementâ.
