Ive never had a problem updating. Following the OP guide worked flawlessly.
However, Im having trouble with Zigbee2Mqtt addon. I cannot start it (Zigbee2mqtt Addon install failed) I opened this thread looking for assistance and another user suggested it might be an issue with permission and it could be due my installation. Does anybody have experience with Zigbee2Mqtt addon?
Is there a way where you can host the file system on your cache drive, say /mnt/user/appdata/hassio and have the qcow2 image reference this file structure? From what I have seen, the files seem to be hosted within the VM, which I really do not want.
Ultimately, i’d like to be able to access the files that hassio uses from the unraid platform for various reasons. Is this possible? I know that the SMB plugin is an option, but looking for something a little more direct.
The Home Assistant container from Unraid’s app store does this, but that is a plain Home Assistant install. You would not have the ecosystem with a supervisor and the add-ons, but a lot of those can be found in the Unraid app store anyway.
VMs of any kind are always going to be isolated machines. It’s like asking if any other real computer on your network can host files in that same path on your Unraid box (without making use of smb or something else).
i found this thread by accident… and i think the docker version home assistant is a tease as there is no disclaimer saying this is not the home assistant you want… as i was trying to run that for hours trying to get it to work before i find now you want the raspberry pi hass version running… as a docker is much better uses less resources but what can ya do
so i got this running as a VM i installed the node red but its broken
i get 02 bad gate way… i have uninstalled and re installed several times… but getting frustrated as its not working as easy as the youtube videos… you load the up the vm you wait the 20 min for it setup log in goto add ons add nodered goto load it and bang your in well bang i get bad gateway…
how i fix that? wish there was like 1 video or a setup video that was flawless
The docker app in Unraid was available long before HA OS was a thing. It’s not a tease, but an alternative way of running HA.
It should not take 20 minutes to set up the VM in unRaid. One of the main benefits of moving from a pi to an VM was the speed. It takes less than two minutes to get up and running on my machine.
Node-Red takes a while to “spin up”. Are you waiting long enough before trying to open it? Did you check the logs for the add-on?
After a server reboot I did notice that Home Assistant did not start. I checked and it seemed started. Looked via VNC and it shows Welcome to Home Assistant, home assistant login:
Why don´t it fire up like it use to? What can I do?
Did a fresh VM and a snapshot restore and up and running, but I´m not happy if this keeps happening every time I reboot the Unraid server. So if anyone has a good idea what is causing this I´m very happy to hear.
Just curious have you tried building off of debian instead of ubuntu I think I read that is what your running it on, the reason I asked is my QCOW2 instance has been incredibly stable for 6 months now with a ton of updates and beta but I built it on a debian VM funny thing thats the only VM on unRAID that has been rock solid have always had lag issues with other attempts
Thought I´d leave a comment if anyone else faces the same problem. After several tries I tried to go back to hassos_ova-5.9.qcow2 (The newest is 5.11 but it´s not working for me)
So after trying the 5.9 version it seems to be working. Just restoring from snapshot now so hopefully it will work.
