I recently enabled bluetooth and the bluetooth component on my hassio install and since then have been seeing regular freezes (about once a day) where I cannot get HTTP or SSH access to my raspberry pi. This originally started to happen with 0.60.1 but is also happening with the latest 0.61.1
In the logs I see semi-regular errors saying
2018-01-20 18:25:44 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
And occasional failures to reach some HTTP services which I hadn’t noticed before.
I don’t seen any excessive RAM or CPU usage in the logs (from the system monitor component). It just seems that it stops working.
Has anyone seen this before? I’m thinking that maybe the bluetooth is somehow interfering with the WiFi on the card causing it to stop.
What bluetooth services are you using in hassio? There is has been a general problem on the Pi3 with using BLE (low energy bluetooth) for presence detection, but not basic bluetooth.
I’m running pretty much the same settings, although my Pi3 is not using wifi. With the .60 release of hassio, I found I was getting a lot fewer of the timer sync errors.
I’ve disabled the bluetooth addon and the bluetooth tracker component and not had a freeze in the 3 days since. There is definitely something strange going on when it’s in use.
Where I currently have the PI doesn’t have an ethernet connection. I could either move it for a test or put it through some powerline adapters to push ethernet to it’s current position
Same story goes for me. Enabled Bluetooth on Pi3 and started using it for tracking and experienced regular freezes. Disabled bluetooth and everything is fine. Also using Pi3 connected through wifi.
You need to disable the on-board Bluetooth since the board requires the use of the hardware UART (and there’s only one on the Pi3). You do this by following the instructions in the device specific page
